Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
As the journal log of our AGX system always sets its start date back to 2021-12-10 or also, I’m investigating the time synchronization scheme of AGX. I’m suspect the clock is set after journald started.
As far as the manual (DRIVE OS Linux) shows, it uses /etc/systemd/scripts/nv_rtc_sync.sh, but I cannot find the systemd service which calls that script.
I already know the issue but I found that I searched nv_ptp_master.service in … XavierB.
(the service is only available on XA)
I try to investigate the behavior of time settings from nv_ptp_master.service and I may additional question.
Please run the command to check if the script runs well.
$ systemctl status nv_rtc_sync.service
I don’t see the issue on 5.2.6 as below. As far as I know, 5.2.0 shouldn’t have the issue too. I saw you moved to 5.2.0 in your topic. You can have a check.
