Hello, currently I want to copy all ssd data from the already working jetson orin nano (environment, code…) to the new jetson device.
I am following the instructions README_backup_restore.txt Workflow 3: To massflash the backup image
I fixed l4t_backup_restore.func according to the instructions Backup restore, workflow #3 massflash jetson orin nano problem - #4 by nox.gias
I ran the command “sudo ./tools/backup_restore/l4t_backup_restore.sh -b -c jetson-orin-nano-devkit” but got the error “flashimg0=boot0.img
/home/myir/Videos/bootFromExternalStorage/R35.4.1/Linux_for_Tegra
Success
Cleaning up…
Finish generating flash package.
No devices to flash” (although I tried that command before and it said it was successful ~~) -
Please help me solve this problem, thank you
I read Workflow 3: Fail to make the massflash backup image, device is orin nx 8gb - #21 by HeapCorrupt
So JP 5.1.2 won’t be able to use backup images ? (I’m using JP 5.1.2 , L4T 35.4.1)
Put the entire log here.
- I followed the instructions at: Backup restore, workflow #3 massflash jetson orin nano problem
- “Please replace every instance of mmcblk0 with nvme0n1 in nvbackup_partitions.sh and nvrestore_partitions.sh and generate the image again.” (Ok)
- apply patch ( l4t_backup_restore.func)
- Run command “sudo ./tools/backup_restore/l4t_backup_restore.sh -b -c jetson-orin-nano-devkit”
Here is the log of the returned result:
log.txt (92.8 KB)
What do you get from serial console?
This is not required for 35.4.1.
You do -e nvme0n1
instead.
hi, I ran the command
"sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -b -c jetson-orin-nano-devkit " ==> created /tools/backup_restore/images/nvme0n1p1.tar.gz about 70GB of data (quite similar to the data size in ssd)
“sudo ./tools/kernel_flash/l4t_initrd_flash.sh --use-backup-image --no-flash --network usb0 --massflash 1 jetson-orin-nano-devkit nvme0n1”
here is the result: Massflash package is generated at /home/myir/Desktop/Flash_Jetson_Orin/bootFromExternalStorage/R35.4.1/Linux_for_Tegra/mfi_jetson-orin-nano-devkit.tar.gz
Success
Cleaning up…
Put device in recovery mode, run with option --flash-only to flash device -
However next step: put new jetson device and run “sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1 --network usb0”
Error result:
log2.txt (5.7 KB)
Are you able to run following commands without massflash?
sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -b jetson-orin-nano-devkit
sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -r jetson-orin-nano-devkit
At least this should work properly.
[ 0.3115 ] Sending bct_mem
[ 0.3213 ] Sending blob
[ 0.4036 ] ERROR: might be timeout in USB write.
Put the serial console log here.
I mean this one:
Hi, I used the command “sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -r jetson-orin-nano-devkit” which seems to have succeeded:
- What do I need to do next to use the restored Jetson device, I can’t ssh into it at the moment, I tried plugging in a hdmi monitor but it says “the current input timing is not supported by the monitor display”
Do this.
Sorry the jetson board has been modified by a 3rd party, I don’t know how to get the serial log as instructed, do you have any other way, I feel like this is very close to success when the steps have reported success.
Use SSH or the USB-C port gives you /dev/ttyGS0
on your host PC.
