Hi Guys,
We have a VM setup with windows 10 Professional, CXR 3.0 and Steam VR 1.20.4.
After restart of the VM, the system volume goes back to 0, here something even stranger happens:
- While the volume is still at 0, we can still hear system sounds and steamVR app sounds
- We can’t hear sound from an unreal engine build we are trying to run
- Closing the unreal engine game, and reopening it, fixes the sound - until the next reboot!
- In the SteamVR setting menu, under audio, I can see “Nvidia HDMI Out (Virtual Audio Driver WDM)” as an option and I can select it manually, but also, this is the default driver selected by windows sound device settings.
Posting the full log here, but wanted to post this line: “Send audio: Enabled, Receive audio: Disabled, Foveation: Two pass” not sure if this means that’s anything is wrong with audio, but it “sounds” like it (pun intended).
NVIDIA CloudXR v3.0 (CL# 30188084), built on Jul 14 2021 21:08:56.
[05:27:14.164] Cleaning up older files.
[05:27:14.165] VisionServerDriver::Init()
[05:27:14.165] CloudXR single instance mutex created, first one.
[05:27:17.332] VisionServerDriver::RunFrame() – creating VisionHmdDriver
[05:27:17.332] VisionHmdDriver()
[05:27:17.332] VSync to photons: 0.0200.
[05:27:17.334] Adapter 0: Description=‘NVIDIA Quadro RTX 4000’
[05:27:17.479] Direct3D setup done.
[05:27:17.479] Send audio: Enabled, Receive audio: Disabled, Foveation: Two pass
[05:27:17.481] Starting FrameServerDX11.
[05:27:18.387] Retry loading stream server dll from cxr directory
[05:27:18.670] Stream Server: Net Stream Server Instance Created
[05:27:18.670] Using an app provided render device for video processing.
[05:27:18.670] Stream Server: CloudXR video streams created
[05:27:18.670] Stream Server: Input stream created
[05:27:18.670] Stream Server: Audio send stream created
[05:27:18.683] Stream Server: streaming instance started - waiting for a client…
[05:27:18.683] VisionHmdDriver::VisionHmdDriver succeeded.
[05:27:31.314] Stream Server: configuration update packet from client streamConn= 0000024869215040
[05:27:31.630] FrameServer::OnNewConnection()
[05:27:31.630] Client connected.
[05:27:31.630] Stream type 4 connected.
[05:27:31.630] Input Stream connected.
[05:27:31.630] Stream type 2 connected.
[05:27:31.630] Audio Send Stream connected.
[05:27:31.632] Stream type 1 connected.
[05:27:31.632] netStreamServer::connectVideoStream streamSource=0x6e98e760, m_streams[VIDEO_STREAM0]=0x6e98e760 m_connectedVideoStreams=1
[05:27:31.632] netStreamServer::connectVideoStream streamSource=0x6e98f3e0, m_streams[VIDEO_STREAM1]=0x6e98f3e0 m_connectedVideoStreams=2
[05:27:31.632] All Streams connected.
[05:27:31.643] Creating audio device
[05:27:31.650] NvAudCapAudioSource: Registering virtual endpoint/s
[05:27:34.117] VisionServerDriver::Start()
[05:27:34.127] Render parameters: 1832 x 1920 @ 72.00 (max 2198 x 2304)
[05:27:34.127] Target queue time: 0.012000
[05:27:34.127] Display type: 2, IPD: 0.064000
[05:27:34.127] Projections: (-1.150368 1.150368 -1.191754 1.191754) x (-1.150368 1.150368 -1.191754 1.191754)
[05:27:34.127] Controller type: 2
[05:27:34.127] VisionServerDriver::AddedHMD
[05:27:34.127] VisionServerDriver::Added all controllers
[05:27:34.138] VisionHmdDriver::Activate(0)
[05:27:34.138] FrameServer::Start
[05:27:34.138] VisionHmdDriver::GetComponent(IVRDisplayComponent_002)
[05:27:34.138] VisionHmdDriver::GetComponent(IVRDriverDirectModeComponent_005)
[05:27:34.138] returning IVRDriverDirectModeComponent interface
[05:27:34.138] VisionHmdDriver::GetComponent(IVRCameraComponent_003)
[05:27:34.138] VisionHmdDriver::GetComponent(IVRVirtualDisplay_002)
[05:27:34.138] VisionHmdDriver::GetProjectionRaw
[05:27:34.142] VisionHmdDriver::GetComponent(IVRControllerComponent_001)
[05:27:34.142] VisionControllerDriver::Activate(1)
[05:27:34.143] VisionControllerDriver::GetComponent(IVRDisplayComponent_002)
[05:27:34.143] VisionControllerDriver::GetComponent(IVRDriverDirectModeComponent_005)
[05:27:34.143] VisionControllerDriver::GetComponent(IVRCameraComponent_003)
[05:27:34.143] VisionControllerDriver::GetComponent(IVRVirtualDisplay_002)
[05:27:34.160] VisionControllerDriver::GetComponent(IVRControllerComponent_001)
[05:27:34.160] VisionControllerDriver::Activate(2)
[05:27:34.160] VisionControllerDriver::GetComponent(IVRDisplayComponent_002)
[05:27:34.160] VisionControllerDriver::GetComponent(IVRDriverDirectModeComponent_005)
[05:27:34.160] VisionControllerDriver::GetComponent(IVRCameraComponent_003)
[05:27:34.160] VisionControllerDriver::GetComponent(IVRVirtualDisplay_002)
[05:27:34.169] VisionControllerDriver::GetComponent(IVRControllerComponent_001)
[05:27:34.169] Handling defered client chaperone setup from RunFrame.
[05:27:34.169] Programming client Chaperone
[05:27:34.226] DestroyAllSwapTextureSets(pid=8572)
[05:27:36.169] CreateSwapTextureSet(pid=8756, res=2196 x 2304)
[05:27:36.170] CreateSwapTextureSet(pid=8756, res=2196 x 2304)
[05:27:36.216] Exchanging the sync texture 0000000000000000 with 0000000040000982.
[05:27:36.300] DestroyAllSwapTextureSets(pid=7396)
[05:27:36.355] DestroyAllSwapTextureSets(pid=9056)
[05:27:36.356] Set a chaperone with origin type 1 and area 1.500 x 1.500 m.
[05:27:36.404] DestroyAllSwapTextureSets(pid=6060)
[05:27:37.203] DestroyAllSwapTextureSets(pid=8768)
[05:27:44.043] CreateSwapTextureSet(pid=8708, res=1832 x 1920)
[05:27:44.049] CreateSwapTextureSet(pid=8708, res=1832 x 1920)
[05:27:44.204] Exchanging the sync texture 0000000040000982 with 0000000040000FC2.
[05:27:44.216] Exchanging the sync texture 0000000040000FC2 with 0000000040000982.
[05:27:44.697] Exchanging the sync texture 0000000040000982 with 0000000040000FC2.
[05:27:44.749] Recreating the composition texture for eye 0. From 0 x 0 to 2196 x 2304. Source res: 2196 x 2304.
[05:27:44.761] Recreating the composition texture for eye 1. From 0 x 0 to 2196 x 2304. Source res: 2196 x 2304.
[05:27:55.500] Exchanging the sync texture 0000000040000FC2 with 0000000040000982.
[05:27:55.578] Exchanging the sync texture 0000000040000982 with 0000000040000FC2.
[05:27:58.294] Exchanging the sync texture 0000000040000FC2 with 0000000040000982.
[05:27:58.619] Exchanging the sync texture 0000000040000982 with 0000000040000FC2.
[05:27:59.834] Failed to acquire the surface mutex, 102
[05:27:59.834] Exchanging the sync texture 0000000040000FC2 with 0000000040000982.
[05:28:10.227] Exchanging the sync texture 0000000040000982 with 0000000040000FC2.
[05:29:17.176] Failed to acquire the surface mutex, 102
[05:29:17.176] Exchanging the sync texture 0000000040000FC2 with 0000000040000982.
[05:29:17.322] Exchanging the sync texture 0000000040000982 with 0000000040000FC2.
[05:29:22.356] Failed to acquire the surface mutex, 102
[05:29:22.356] Exchanging the sync texture 0000000040000FC2 with 0000000040000982.
[05:29:22.506] Exchanging the sync texture 0000000040000982 with 0000000040000FC2.
[05:29:26.531] Failed to acquire the surface mutex, 102
[05:29:26.531] Exchanging the sync texture 0000000040000FC2 with 0000000040000982.
[05:29:26.667] Exchanging the sync texture 0000000040000982 with 0000000040000FC2.
[05:29:40.219] Failed to acquire the surface mutex, 102
[05:29:40.219] Exchanging the sync texture 0000000040000FC2 with 0000000040000982.
[05:29:43.218] DestroyAllSwapTextureSets(pid=8708)
[05:29:59.707] Stream type 1 stopped.
[05:29:59.707] Stream type 4 stopped.
[05:29:59.707] All streams stopped.
[05:29:59.707] Stream type 2 stopped.
[05:29:59.707] Client disconnected.
[05:29:59.709] Skipping nvstPushStreamData for eye 0 because the connection has been torn down.
[05:30:02.681] DestroyAllSwapTextureSets(pid=8712)
[05:31:28.865] VisionServerDriver::EnterStandby()
[05:31:28.974] VisionServerDriver::LeaveStandby()
[05:31:28.974] DestroyAllSwapTextureSets(pid=7204)
[05:31:29.052] DestroyAllSwapTextureSets(pid=3728)
[05:31:29.145] DestroyAllSwapTextureSets(pid=3524)
[05:31:29.146] DestroyAllSwapTextureSets(pid=3796)
[05:31:29.150] DestroyAllSwapTextureSets(pid=9552)
[05:31:29.152] DestroyAllSwapTextureSets(pid=3756)
[05:31:29.152] DestroyAllSwapTextureSets(pid=3584)
[05:31:29.186] DestroyAllSwapTextureSets(pid=8988)
[05:31:29.248] DestroyAllSwapTextureSets(pid=8756)
[05:31:29.338] VisionControllerDriver::Deactivate
[05:31:29.338] VisionHmdDriver::Deactivate
[05:31:29.338] deactivated
[05:31:29.506] VisionServerDriver::Cleanup()
[05:31:29.506] FrameServer::End
[05:31:29.506] NvAudCapAudioSource: Could not get audio frame (error 10)
[05:31:29.659] Stream Server: stopped the server instance
[05:31:29.659] CloudXR single instance mutex released and closed.
[05:31:29.659] DLL_PROCESS_DETACH
