Can someone assist me with setting up CloudXR for same network with server behind a router?
I have been trying to get sample client for unity working with CloudXR and i have failed to get the connection from Client’s end. I can see the SteamVR log and streamer log indicating the server is running, but i have drafted this to maybe port forwarding issues or SteamVR connectivity issues ( as i have not connected even once, so i get " Headset not Detected " message.
I have attached server logs from SteamVR, and if any more details required, please do let me know.
Thanks in advance.
Streamer log :
(I)[2024-06-24 05:40:26,016]=11:10:26=00000{4020} Starting task executor
(I)[2024-06-24 05:40:26,016]=11:10:26=00000{4020} Build Information:
(M)[2024-06-24 05:40:26,017]=11:10:26=00000{4020} Name: unnamed
(M)[2024-06-24 05:40:26,017]=11:10:26=00000{4020} DVS Branch: gcomp/rel/gs_04_55
(M)[2024-06-24 05:40:26,017]=11:10:26=00000{4020} DVS P4VirtualChangelist: 33337988
(I)[2024-06-24 05:40:26,046]=11:10:26=00029{4020} Windows 10.0.22621.3672, DD version 555.85: using NvAPI_Coproc_GetCoprocInfo workaround.
(I)[2024-06-24 05:40:26,047]=11:10:26=00000{4020} GPU’s = {
(I)[2024-06-24 05:40:26,047]=11:10:26=00000{4020} {
(I)[2024-06-24 05:40:26,047]=11:10:26=00000{4020} FriendlyName=NVIDIA GeForce GTX 1660 SUPER
(M)[2024-06-24 05:40:26,047]=11:10:26=00000{4020} Is GPU in local Game Streaming Whitelist=1
(I)[2024-06-24 05:40:26,047]=11:10:26=00000{4020} }
(I)[2024-06-24 05:40:26,047]=11:10:26=00000{4020} Nvidia GPU count: 1, Non Nvidia GPU count: 0, Coproc: FALSE
(I)[2024-06-24 05:40:26,047]=11:10:26=00000{4020} Head DeviceName: \.\DISPLAY1, DeviceString: NVIDIA GeForce GTX 1660 SUPER, AttachedToDesktop, MonitorConnected
(I)[2024-06-24 05:40:26,047]=11:10:26=00000{4020} Head DeviceName: \.\DISPLAY2, DeviceString: NVIDIA GeForce GTX 1660 SUPER
(I)[2024-06-24 05:40:26,047]=11:10:26=00000{4020} Head DeviceName: \.\DISPLAY3, DeviceString: NVIDIA GeForce GTX 1660 SUPER
(I)[2024-06-24 05:40:26,048]=11:10:26=00000{4020} Head DeviceName: \.\DISPLAY4, DeviceString: NVIDIA GeForce GTX 1660 SUPER
(I)[2024-06-24 05:40:26,048]=11:10:26=00000{4020} Adapter vendor id: 0x10de, device name: \.\DISPLAY1
(M)[2024-06-24 05:40:26,048]=11:10:26=00000{4020} Using: OpenSSL 1.1.1q 5 Jul 2022
(M)[2024-06-24 05:40:26,049]=11:10:26=00000{4020} RND is initialized
(I)[2024-06-24 05:40:26,049]=11:10:26=00000{4020} Enumerating network adapters on this system
(E)[2024-06-24 05:40:26,053]=11:10:26=00004{4020} Network Address To String: invalid parameters 000000302BF580C0, 000000302BF580E0, 48
(M)[2024-06-24 05:40:26,053]=11:10:26=00000{4020} — …: … / …
(I)[2024-06-24 05:40:26,053]=11:10:26=00000{4020} Selected non-preview NvEnc version with enum value: 4
(M)[2024-06-24 05:40:26,053]=11:10:26=00000{4020} Computing SPS/PPS headers.
(W)[2024-06-24 05:40:26,053]=11:10:26=00000{4020} Couldn’t find VideoFrameContext for this thread.
(M)[2024-06-24 05:40:26,053]=11:10:26=00000{4020} Initializing Adapter context
(I)[2024-06-24 05:40:26,105]=11:10:26=00051{4020} UpscaleState ignored for D3D9 video adapter.
(I)[2024-06-24 05:40:26,105]=11:10:26=00000{4020} Using D3D9 Adapter Context
(M)[2024-06-24 05:40:26,105]=11:10:26=00000{4020} Initialized context for adapter 0: 1920 x 1080 @ 144.0 Hz
(M)[2024-06-24 05:40:26,105]=11:10:26=00000{4020} Driver version is 555.85, branch is r555_79.
(M)[2024-06-24 05:40:26,105]=11:10:26=00000{4020} System is NOT co-proc.
(I)[2024-06-24 05:40:26,105]=11:10:26=00000{4020} Found a match at [21]
(M)[2024-06-24 05:40:26,105]=11:10:26=00000{4020} Initializing NvEnc12VideoEncoder.
(M)[2024-06-24 05:40:26,105]=11:10:26=00000{4020} Using NvEnc header version 12.0.
(I)[2024-06-24 05:40:26,135]=11:10:26=00030{4020} Generating SPS/PPS header for 1280x720@30 FPS in video format H.264.
(I)[2024-06-24 05:40:26,136]=11:10:26=00000{4020} Encoder maxLumaPixelsPerSec[0] 1890908928
(I)[2024-06-24 05:40:26,136]=11:10:26=00000{4020} Encoder maxLumaPixelsPerSec[1] 1182938368
(I)[2024-06-24 05:40:26,137]=11:10:26=00001{4020} SPS/PPS LUT match, idx 0
(I)[2024-06-24 05:40:26,138]=11:10:26=00000{4020} Generating SPS/PPS header for 1280x720@60 FPS in video format H.264.
(I)[2024-06-24 05:40:26,138]=11:10:26=00000{4020} SPS/PPS LUT match, idx 3
(I)[2024-06-24 05:40:26,138]=11:10:26=00000{4020} Generating SPS/PPS header for 1920x1080@30 FPS in video format H.264.
(I)[2024-06-24 05:40:26,139]=11:10:26=00000{4020} SPS/PPS LUT match, idx 1
(I)[2024-06-24 05:40:26,139]=11:10:26=00000{4020} Generating SPS/PPS header for 1920x1080@60 FPS in video format H.264.
(I)[2024-06-24 05:40:26,140]=11:10:26=00000{4020} SPS/PPS LUT match, idx 4
(I)[2024-06-24 05:40:26,140]=11:10:26=00000{4020} Generating SPS/PPS header for 3840x2160@30 FPS in video format H.264.
(I)[2024-06-24 05:40:26,140]=11:10:26=00000{4020} SPS/PPS LUT match, idx 2
(I)[2024-06-24 05:40:26,140]=11:10:26=00000{4020} Generating SPS/PPS header for 3840x2160@60 FPS in video format H.264.
(I)[2024-06-24 05:40:26,141]=11:10:26=00000{4020} SPS/PPS LUT match, idx 5
(I)[2024-06-24 05:40:26,148]=11:10:26=00006{4020} Generating SPS/PPS header for 1280x720@30 FPS in video format HEVC.
(I)[2024-06-24 05:40:26,149]=11:10:26=00001{4020} SPS/PPS LUT match, idx 6
(I)[2024-06-24 05:40:26,149]=11:10:26=00000{4020} Generating SPS/PPS header for 1280x720@60 FPS in video format HEVC.
(I)[2024-06-24 05:40:26,150]=11:10:26=00000{4020} SPS/PPS LUT match, idx 9
(I)[2024-06-24 05:40:26,150]=11:10:26=00000{4020} Generating SPS/PPS header for 1920x1080@30 FPS in video format HEVC.
(I)[2024-06-24 05:40:26,151]=11:10:26=00000{4020} SPS/PPS LUT match, idx 7
(I)[2024-06-24 05:40:26,151]=11:10:26=00000{4020} Generating SPS/PPS header for 1920x1080@60 FPS in video format HEVC.
(I)[2024-06-24 05:40:26,152]=11:10:26=00000{4020} SPS/PPS LUT match, idx 10
(I)[2024-06-24 05:40:26,152]=11:10:26=00000{4020} Generating SPS/PPS header for 3840x2160@30 FPS in video format HEVC.
(I)[2024-06-24 05:40:26,153]=11:10:26=00000{4020} Encoder supports encoding 10 bit
(I)[2024-06-24 05:40:26,153]=11:10:26=00000{4020} SPS/PPS LUT match, idx 8
(I)[2024-06-24 05:40:26,153]=11:10:26=00000{4020} Generating SPS/PPS header for 3840x2160@60 FPS in video format HEVC.
(I)[2024-06-24 05:40:26,154]=11:10:26=00000{4020} SPS/PPS LUT match, idx 11
(I)[2024-06-24 05:40:26,154]=11:10:26=00000{4020} Generating SPS/PPS header for 1280x720@30 FPS in video format AV1.
(W)[2024-06-24 05:40:26,154]=11:10:26=00000{4020} Failed to read the Av1Disable regkey (CONFIG_STATUS result = 1); using default value of 0.
(W)[2024-06-24 05:40:26,155]=11:10:26=00000{4020} Skipping unsupported/disallowed format.
(I)[2024-06-24 05:40:26,155]=11:10:26=00000{4020} Generating SPS/PPS header for 1280x720@60 FPS in video format AV1.
(I)[2024-06-24 05:40:26,156]=11:10:26=00000{4020} Generating SPS/PPS header for 1920x1080@30 FPS in video format AV1.
(W)[2024-06-24 05:40:26,156]=11:10:26=00000{4020} Skipping unsupported/disallowed format.
(I)[2024-06-24 05:40:26,156]=11:10:26=00000{4020} Generating SPS/PPS header for 1920x1080@60 FPS in video format AV1.
(W)[2024-06-24 05:40:26,157]=11:10:26=00000{4020} Skipping unsupported/disallowed format.
(I)[2024-06-24 05:40:26,157]=11:10:26=00000{4020} Generating SPS/PPS header for 3840x2160@30 FPS in video format AV1.
(W)[2024-06-24 05:40:26,158]=11:10:26=00000{4020} Skipping unsupported/disallowed format.
(I)[2024-06-24 05:40:26,158]=11:10:26=00000{4020} Generating SPS/PPS header for 3840x2160@60 FPS in video format AV1.
(W)[2024-06-24 05:40:26,159]=11:10:26=00000{4020} Skipping unsupported/disallowed format.
(I)[2024-06-24 05:40:26,166]=11:10:26=00007{4020} Deinitialized context for adapter 0
(W)[2024-06-24 05:40:26,167]=11:10:26=00000{4020} VideoEncoder was not deinitialized prior to destruction!
(M)[2024-06-24 05:40:26,167]=11:10:26=00000{4020} Finished computing SPS/PPS headers.
(I)[2024-06-24 05:40:26,167]=11:10:26=00000{4020} Ip version provided externally.
(I)[2024-06-24 05:40:26,167]=11:10:26=00000{4020} Setting IPv4 for this session.
(I)[2024-06-24 05:40:26,170]=11:10:26=00002{4020} DTLS: server: local dtlsfingerprint 65:DE:2A:1B:7C:29:8A:F7:BB:8B:58:1A:A7:D8:BF:79:BF:5C:AD:E6:A5:D8:E9:7D:24:FB:A5:4D:F6:3A:CD:C4
(I)[2024-06-24 05:40:26,170]=11:10:26=00000{4020} Server has been asked to start.
(I)[2024-06-24 05:40:26,170]=11:10:26=00000{4020} Server has been asked to add a stream.
(I)[2024-06-24 05:40:26,170]=11:10:26=00000{4020} Adding a video stream.
(I)[2024-06-24 05:40:26,170]=11:10:26=00000{4020} Adding input stream.
(I)[2024-06-24 05:40:26,170]=11:10:26=00000{4020} Adding audio stream.
(I)[2024-06-24 05:40:26,174]=11:10:26=00003{4020} Head DeviceName: \.\DISPLAY1, DeviceString: NVIDIA GeForce GTX 1660 SUPER, AttachedToDesktop, MonitorConnected
(I)[2024-06-24 05:40:26,174]=11:10:26=00000{4020} Head DeviceName: \.\DISPLAY2, DeviceString: NVIDIA GeForce GTX 1660 SUPER
(I)[2024-06-24 05:40:26,174]=11:10:26=00000{4020} Head DeviceName: \.\DISPLAY3, DeviceString: NVIDIA GeForce GTX 1660 SUPER
(I)[2024-06-24 05:40:26,175]=11:10:26=00000{4020} Head DeviceName: \.\DISPLAY4, DeviceString: NVIDIA GeForce GTX 1660 SUPER
(I)[2024-06-24 05:40:26,175]=11:10:26=00000{4020} Adapter vendor id: 0x10de, device name: \.\DISPLAY1
(I)[2024-06-24 05:40:26,175]=11:10:26=00000{4020} Using 2 streams.
(I)[2024-06-24 05:40:26,176]=11:10:26=00000{4020} RTSP Server: RtspServerWebSocket instance
(I)[2024-06-24 05:40:26,176]=11:10:26=00000{4020} Allow signaling server ACKs: yes
(I)[2024-06-24 05:40:26,176]=11:10:26=00000{4020} Enable unsecured connection in Signaling server.
(M)[2024-06-24 05:40:26,176]=11:10:26=00000{4020} Signaling server started.
(I)[2024-06-24 05:40:26,176]=11:10:26=00000{4020} Successfully started server.
(I)[2024-06-24 05:40:26,176]=11:10:26=00000{4020} Server is now in state: Started
CloudXR Server - SteamVR Log 2024-06-24 11.10.21.txt (2.4 KB)
CloudXR Server - SteamVR Log 2024-06-24 11.10.16.txt (972 Bytes)
