Closing pipe SteamVR_Namespace because it was broken from the other end in SteamVR Logs
Cannot connect Oculus Quest 2 to SteamVR on Windows desktop.
Here is the entire log of vrclient_CloudXRClient.txt found in C:\Program Files (x86)\Steam\logs
Mon Aug 02 2021 12:23:23.402 - CloudXRClient.exe 1.19.4 startup with PID=12344, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:23:23.402 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:23:23.405 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:23:23.407 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:23:23.407 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:23:23.407 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:23:23.407 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:23:23.407 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:23:23.407 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:23:23.408 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:23:23.413 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:23:23.417 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 12:23:23.417 - CSharedResourceNamespaceClient::Init(): received namespace data 10800
Mon Aug 02 2021 12:23:23.417 - Client (VR_ServerPipe_10800) app container state: 1
Mon Aug 02 2021 12:23:23.971 - Received success response from vrserver connect
Mon Aug 02 2021 12:23:23.974 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:23:23.974 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:23:23.982 - Client (VR_CompositorPipe_10800) app container state: 1
Mon Aug 02 2021 12:23:23.989 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:23:23.989 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:23:23.989 - Attempting to load initial input config
Mon Aug 02 2021 12:23:23.992 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 12:23:24.117 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 12:23:24.118 - /user/hand/left is 1
Mon Aug 02 2021 12:23:24.118 - /user/hand/right is 2
Mon Aug 02 2021 12:23:24.118 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 12:23:24.118 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 12:23:24.118 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:23:24.168 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:23:24.169 - Capturing Scene Focus
Mon Aug 02 2021 12:24:05.287 - //==============================================================================================
Mon Aug 02 2021 12:24:05.287 - ================================================================================================
Mon Aug 02 2021 12:24:05.287 - CloudXRClient.exe 1.19.4 startup with PID=21900, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:24:05.287 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:24:05.290 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:24:05.292 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:24:05.292 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:24:05.292 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:24:05.293 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:24:05.293 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:24:05.294 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:24:05.294 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:24:05.300 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:24:05.303 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 12:24:05.303 - CSharedResourceNamespaceClient::Init(): received namespace data 10800
Mon Aug 02 2021 12:24:05.303 - Client (VR_ServerPipe_10800) app container state: 1
Mon Aug 02 2021 12:24:05.842 - Received success response from vrserver connect
Mon Aug 02 2021 12:24:05.844 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:24:05.844 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:24:05.851 - Client (VR_CompositorPipe_10800) app container state: 1
Mon Aug 02 2021 12:24:05.858 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:24:05.858 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:24:05.858 - Attempting to load initial input config
Mon Aug 02 2021 12:24:05.861 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 12:24:05.978 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 12:24:05.978 - /user/hand/left is 1
Mon Aug 02 2021 12:24:05.978 - /user/hand/right is 2
Mon Aug 02 2021 12:24:05.979 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 12:24:05.979 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 12:24:05.979 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:24:06.027 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:24:06.029 - Capturing Scene Focus
Mon Aug 02 2021 12:27:58.404 - //==============================================================================================
Mon Aug 02 2021 12:27:58.404 - ================================================================================================
Mon Aug 02 2021 12:27:58.404 - CloudXRClient.exe 1.19.4 startup with PID=25632, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:27:58.405 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:27:58.407 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:27:58.408 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:27:58.408 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:27:58.408 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:27:58.408 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:27:58.409 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:27:58.409 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:27:58.409 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:27:58.415 - Starting vrserver process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrserver.exe
Mon Aug 02 2021 12:27:58.416 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 12:27:58.416 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 12:27:58.526 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:27:58.541 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 12:27:58.541 - CSharedResourceNamespaceClient::Init(): received namespace data 23480
Mon Aug 02 2021 12:27:58.650 - Client (VR_ServerPipe_23480) app container state: 1
Mon Aug 02 2021 12:27:58.990 - Received success response from vrserver connect
Mon Aug 02 2021 12:27:58.991 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:27:58.991 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:27:59.003 - Starting vrcompositor process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrcompositor.exe
Mon Aug 02 2021 12:27:59.118 - Client (VR_CompositorPipe_23480) app container state: 1
Mon Aug 02 2021 12:27:59.630 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:27:59.630 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:27:59.630 - Attempting to load initial input config
Mon Aug 02 2021 12:27:59.633 - No controllers detected. Not waiting for config.
Mon Aug 02 2021 12:27:59.633 - /user/hand/left is FFFFFFFF
Mon Aug 02 2021 12:27:59.633 - /user/hand/right is FFFFFFFF
Mon Aug 02 2021 12:27:59.633 - TrackedControllerRole_LeftHand (FFFFFFFF)->
Mon Aug 02 2021 12:27:59.633 - Skipping role TrackedControllerRole_LeftHand because the device is invalid
Mon Aug 02 2021 12:27:59.633 - TrackedControllerRole_RightHand (FFFFFFFF)->
Mon Aug 02 2021 12:27:59.633 - Skipping role TrackedControllerRole_RightHand because the device is invalid
Mon Aug 02 2021 12:27:59.633 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:27:59.643 - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrdashboard.exe with pid 9060
Mon Aug 02 2021 12:27:59.654 - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\vrwebhelper.exe with pid 13836
Mon Aug 02 2021 12:27:59.669 - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrmonitor.exe with pid 488
Mon Aug 02 2021 12:27:59.742 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:27:59.746 - Capturing Scene Focus
Mon Aug 02 2021 12:28:35.318 - //==============================================================================================
Mon Aug 02 2021 12:28:35.318 - ================================================================================================
Mon Aug 02 2021 12:28:35.318 - CloudXRClient.exe 1.19.4 startup with PID=19460, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:28:35.318 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:28:35.322 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:28:35.323 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:28:35.324 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:28:35.324 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:28:35.324 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:28:35.324 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:28:35.324 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:28:35.325 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:28:35.330 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:28:35.335 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 12:28:35.335 - CSharedResourceNamespaceClient::Init(): received namespace data 23480
Mon Aug 02 2021 12:28:35.335 - Client (VR_ServerPipe_23480) app container state: 1
Mon Aug 02 2021 12:28:35.880 - Received success response from vrserver connect
Mon Aug 02 2021 12:28:35.882 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:28:35.882 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:28:35.889 - Client (VR_CompositorPipe_23480) app container state: 1
Mon Aug 02 2021 12:28:35.897 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:28:35.897 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:28:35.898 - Attempting to load initial input config
Mon Aug 02 2021 12:28:35.901 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 12:28:36.022 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 12:28:36.022 - /user/hand/left is 1
Mon Aug 02 2021 12:28:36.022 - /user/hand/right is 2
Mon Aug 02 2021 12:28:36.023 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 12:28:36.023 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 12:28:36.023 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:28:36.070 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:28:36.072 - Capturing Scene Focus
Mon Aug 02 2021 12:29:06.263 - //==============================================================================================
Mon Aug 02 2021 12:29:06.264 - ================================================================================================
Mon Aug 02 2021 12:29:06.264 - CloudXRClient.exe 1.19.4 startup with PID=7940, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:29:06.264 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:29:06.267 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:29:06.268 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:29:06.268 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:29:06.268 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:29:06.269 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:29:06.269 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:29:06.269 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:29:06.270 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:29:06.275 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:29:06.284 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 12:29:06.284 - CSharedResourceNamespaceClient::Init(): received namespace data 23480
Mon Aug 02 2021 12:29:06.284 - Client (VR_ServerPipe_23480) app container state: 1
Mon Aug 02 2021 12:29:06.832 - Received success response from vrserver connect
Mon Aug 02 2021 12:29:06.833 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:29:06.833 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:29:06.842 - Client (VR_CompositorPipe_23480) app container state: 1
Mon Aug 02 2021 12:29:06.844 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:29:06.844 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:29:06.845 - Attempting to load initial input config
Mon Aug 02 2021 12:29:06.848 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 12:29:06.969 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 12:29:06.969 - /user/hand/left is 1
Mon Aug 02 2021 12:29:06.969 - /user/hand/right is 2
Mon Aug 02 2021 12:29:06.969 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 12:29:06.969 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 12:29:06.969 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:29:07.024 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:29:07.027 - Capturing Scene Focus
Mon Aug 02 2021 12:34:00.417 - //==============================================================================================
Mon Aug 02 2021 12:34:00.417 - ================================================================================================
Mon Aug 02 2021 12:34:00.417 - CloudXRClient.exe 1.19.4 startup with PID=11652, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:34:00.417 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:34:00.423 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:34:00.424 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:34:00.425 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:34:00.425 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:34:00.425 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:34:00.425 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:34:00.426 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:34:00.426 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:34:00.432 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:34:00.435 - CSharedResourceNamespaceClient::Init(): received namespace data 23480
Mon Aug 02 2021 12:34:00.435 - Client (VR_ServerPipe_23480) app container state: 1
Mon Aug 02 2021 12:34:00.977 - Received success response from vrserver connect
Mon Aug 02 2021 12:34:00.978 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:34:00.979 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:34:00.988 - Client (VR_CompositorPipe_23480) app container state: 1
Mon Aug 02 2021 12:34:00.996 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:34:00.996 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:34:00.997 - Attempting to load initial input config
Mon Aug 02 2021 12:34:01.000 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 12:34:01.130 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 12:34:01.130 - /user/hand/left is 1
Mon Aug 02 2021 12:34:01.130 - /user/hand/right is 2
Mon Aug 02 2021 12:34:01.130 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 12:34:01.130 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 12:34:01.130 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:34:01.178 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:34:01.181 - Capturing Scene Focus
Mon Aug 02 2021 12:35:01.748 - //==============================================================================================
Mon Aug 02 2021 12:35:01.749 - ================================================================================================
Mon Aug 02 2021 12:35:01.749 - CloudXRClient.exe 1.19.4 startup with PID=26900, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:35:01.749 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:35:01.753 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:35:01.755 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:35:01.755 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:35:01.755 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:35:01.755 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:35:01.755 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:35:01.755 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:35:01.756 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:35:01.762 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:35:01.772 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 12:35:01.772 - CSharedResourceNamespaceClient::Init(): received namespace data 23480
Mon Aug 02 2021 12:35:01.772 - Client (VR_ServerPipe_23480) app container state: 1
Mon Aug 02 2021 12:35:02.332 - Received success response from vrserver connect
Mon Aug 02 2021 12:35:02.334 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:35:02.334 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:35:02.343 - Client (VR_CompositorPipe_23480) app container state: 1
Mon Aug 02 2021 12:35:02.353 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:35:02.353 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:35:02.354 - Attempting to load initial input config
Mon Aug 02 2021 12:35:02.357 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 12:35:02.473 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 12:35:02.473 - /user/hand/left is 1
Mon Aug 02 2021 12:35:02.473 - /user/hand/right is 2
Mon Aug 02 2021 12:35:02.473 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 12:35:02.473 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 12:35:02.473 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:35:02.520 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:35:02.523 - Capturing Scene Focus
Mon Aug 02 2021 12:40:12.774 - //==============================================================================================
Mon Aug 02 2021 12:40:12.774 - ================================================================================================
Mon Aug 02 2021 12:40:12.774 - CloudXRClient.exe 1.19.4 startup with PID=26288, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:40:12.774 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:40:12.777 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:40:12.778 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:40:12.778 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:40:12.778 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:40:12.779 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:40:12.779 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:40:12.779 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:40:12.780 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:40:12.784 - Starting vrserver process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrserver.exe
Mon Aug 02 2021 12:40:12.795 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 12:40:12.795 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 12:40:12.901 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:40:12.917 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 12:40:12.917 - CSharedResourceNamespaceClient::Init(): received namespace data 608
Mon Aug 02 2021 12:40:13.025 - Client (VR_ServerPipe_608) app container state: 1
Mon Aug 02 2021 12:40:13.362 - Received success response from vrserver connect
Mon Aug 02 2021 12:40:13.364 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:40:13.364 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:40:13.374 - Starting vrcompositor process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrcompositor.exe
Mon Aug 02 2021 12:40:13.477 - Client (VR_CompositorPipe_608) app container state: 1
Mon Aug 02 2021 12:40:13.999 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:40:13.999 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:40:13.999 - Attempting to load initial input config
Mon Aug 02 2021 12:40:14.003 - No controllers detected. Not waiting for config.
Mon Aug 02 2021 12:40:14.003 - /user/hand/left is FFFFFFFF
Mon Aug 02 2021 12:40:14.003 - /user/hand/right is FFFFFFFF
Mon Aug 02 2021 12:40:14.003 - TrackedControllerRole_LeftHand (FFFFFFFF)->
Mon Aug 02 2021 12:40:14.003 - Skipping role TrackedControllerRole_LeftHand because the device is invalid
Mon Aug 02 2021 12:40:14.003 - TrackedControllerRole_RightHand (FFFFFFFF)->
Mon Aug 02 2021 12:40:14.003 - Skipping role TrackedControllerRole_RightHand because the device is invalid
Mon Aug 02 2021 12:40:14.003 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:40:14.011 - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrdashboard.exe with pid 26780
Mon Aug 02 2021 12:40:14.019 - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\vrwebhelper.exe with pid 27104
Mon Aug 02 2021 12:40:14.029 - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrmonitor.exe with pid 19292
Mon Aug 02 2021 12:40:14.087 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:40:14.098 - Capturing Scene Focus
Mon Aug 02 2021 12:41:14.343 - //==============================================================================================
Mon Aug 02 2021 12:41:14.343 - ================================================================================================
Mon Aug 02 2021 12:41:14.343 - CloudXRClient.exe 1.19.4 startup with PID=4576, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:41:14.344 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:41:14.346 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:41:14.348 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:14.348 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:14.348 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:14.348 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:14.348 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:14.349 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:14.349 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:41:14.355 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:41:14.356 - CSharedResourceNamespaceClient::Init(): received namespace data 608
Mon Aug 02 2021 12:41:14.356 - Client (VR_ServerPipe_608) app container state: 1
Mon Aug 02 2021 12:41:14.901 - Received success response from vrserver connect
Mon Aug 02 2021 12:41:14.902 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:41:14.902 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:41:14.909 - Client (VR_CompositorPipe_608) app container state: 1
Mon Aug 02 2021 12:41:14.917 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:41:14.917 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:41:14.918 - Attempting to load initial input config
Mon Aug 02 2021 12:41:14.920 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 12:41:15.037 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 12:41:15.037 - /user/hand/left is 1
Mon Aug 02 2021 12:41:15.038 - /user/hand/right is 2
Mon Aug 02 2021 12:41:15.038 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 12:41:15.038 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 12:41:15.038 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:41:15.093 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:41:15.096 - Capturing Scene Focus
Mon Aug 02 2021 12:41:23.120 - //==============================================================================================
Mon Aug 02 2021 12:41:23.120 - ================================================================================================
Mon Aug 02 2021 12:41:23.120 - CloudXRClient.exe 1.19.4 startup with PID=24436, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 12:41:23.121 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 12:41:23.123 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 12:41:23.124 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:23.125 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:23.125 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:23.125 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:23.125 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:23.125 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 12:41:23.126 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 12:41:23.132 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 12:41:23.136 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 12:41:23.136 - CSharedResourceNamespaceClient::Init(): received namespace data 608
Mon Aug 02 2021 12:41:23.136 - Client (VR_ServerPipe_608) app container state: 1
Mon Aug 02 2021 12:41:23.163 - Received success response from vrserver connect
Mon Aug 02 2021 12:41:23.165 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 12:41:23.165 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 12:41:23.172 - Client (VR_CompositorPipe_608) app container state: 1
Mon Aug 02 2021 12:41:23.178 - Received success response from vrcompositor connect
Mon Aug 02 2021 12:41:23.178 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 12:41:23.179 - Attempting to load initial input config
Mon Aug 02 2021 12:41:23.183 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 12:41:23.299 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 12:41:23.299 - /user/hand/left is 1
Mon Aug 02 2021 12:41:23.299 - /user/hand/right is 2
Mon Aug 02 2021 12:41:23.300 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 12:41:23.300 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 12:41:23.300 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 12:41:23.354 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 12:41:23.356 - Capturing Scene Focus
Mon Aug 02 2021 13:14:59.059 - //==============================================================================================
Mon Aug 02 2021 13:14:59.059 - ================================================================================================
Mon Aug 02 2021 13:14:59.059 - CloudXRClient.exe 1.19.4 startup with PID=23660, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 13:14:59.059 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 13:14:59.062 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 13:14:59.064 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 13:14:59.064 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 13:14:59.064 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 13:14:59.064 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 13:14:59.064 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 13:14:59.065 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 13:14:59.066 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 13:14:59.073 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 13:14:59.082 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 13:14:59.082 - CSharedResourceNamespaceClient::Init(): received namespace data 608
Mon Aug 02 2021 13:14:59.083 - Client (VR_ServerPipe_608) app container state: 1
Mon Aug 02 2021 13:15:01.706 - Received success response from vrserver connect
Mon Aug 02 2021 13:15:01.708 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 13:15:01.708 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 13:15:01.715 - Client (VR_CompositorPipe_608) app container state: 1
Mon Aug 02 2021 13:15:01.725 - Received success response from vrcompositor connect
Mon Aug 02 2021 13:15:01.725 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 13:15:01.726 - Attempting to load initial input config
Mon Aug 02 2021 13:15:01.728 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 13:15:01.855 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 13:15:01.855 - /user/hand/left is 1
Mon Aug 02 2021 13:15:01.855 - /user/hand/right is 2
Mon Aug 02 2021 13:15:01.856 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 13:15:01.856 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 13:15:01.856 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 13:15:01.904 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 13:15:01.908 - Capturing Scene Focus
Mon Aug 02 2021 13:19:47.692 - //==============================================================================================
Mon Aug 02 2021 13:19:47.692 - ================================================================================================
Mon Aug 02 2021 13:19:47.692 - CloudXRClient.exe 1.19.4 startup with PID=11756, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 13:19:47.692 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 13:19:47.694 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 13:19:47.696 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 13:19:47.696 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 13:19:47.696 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 13:19:47.696 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 13:19:47.696 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 13:19:47.696 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 13:19:47.697 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 13:19:47.706 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 13:19:47.711 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 13:19:47.711 - CSharedResourceNamespaceClient::Init(): received namespace data 608
Mon Aug 02 2021 13:19:47.711 - Client (VR_ServerPipe_608) app container state: 1
Mon Aug 02 2021 13:19:50.332 - Received success response from vrserver connect
Mon Aug 02 2021 13:19:50.334 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 13:19:50.334 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 13:19:50.342 - Client (VR_CompositorPipe_608) app container state: 1
Mon Aug 02 2021 13:19:50.346 - Received success response from vrcompositor connect
Mon Aug 02 2021 13:19:50.347 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 13:19:50.347 - Attempting to load initial input config
Mon Aug 02 2021 13:19:50.349 - Failed to find device container 100000001. Waiting some more.
Mon Aug 02 2021 13:19:50.463 - After initial config load, app appears to be using legacy input
Mon Aug 02 2021 13:19:50.463 - /user/hand/left is 1
Mon Aug 02 2021 13:19:50.463 - /user/hand/right is 2
Mon Aug 02 2021 13:19:50.463 - TrackedControllerRole_LeftHand (1)->
Mon Aug 02 2021 13:19:50.463 - TrackedControllerRole_RightHand (2)->
Mon Aug 02 2021 13:19:50.463 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 13:19:50.510 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 13:19:50.513 - Capturing Scene Focus
Mon Aug 02 2021 13:37:53.473 - //==============================================================================================
Mon Aug 02 2021 13:37:53.473 - ================================================================================================
Mon Aug 02 2021 13:37:53.473 - CloudXRClient.exe 1.19.4 startup with PID=28232, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 13:37:53.474 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 13:37:53.477 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 13:37:53.478 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 13:37:53.478 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 13:37:53.478 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 13:37:53.478 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 13:37:53.478 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 13:37:53.479 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 13:37:53.479 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 13:37:53.484 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 13:37:53.487 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 13:37:53.487 - CSharedResourceNamespaceClient::Init(): received namespace data 22672
Mon Aug 02 2021 13:37:53.487 - Client (VR_ServerPipe_22672) app container state: 1
Mon Aug 02 2021 13:37:56.631 - Received success response from vrserver connect
Mon Aug 02 2021 13:37:56.633 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 13:37:56.633 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 13:37:56.639 - Client (VR_CompositorPipe_22672) app container state: 1
Mon Aug 02 2021 13:37:56.645 - Received success response from vrcompositor connect
Mon Aug 02 2021 13:37:56.645 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 13:37:56.645 - Attempting to load initial input config
Mon Aug 02 2021 13:37:56.649 - No controllers detected. Not waiting for config.
Mon Aug 02 2021 13:37:56.649 - /user/hand/left is FFFFFFFF
Mon Aug 02 2021 13:37:56.649 - /user/hand/right is FFFFFFFF
Mon Aug 02 2021 13:37:56.649 - TrackedControllerRole_LeftHand (FFFFFFFF)->
Mon Aug 02 2021 13:37:56.649 - Skipping role TrackedControllerRole_LeftHand because the device is invalid
Mon Aug 02 2021 13:37:56.649 - TrackedControllerRole_RightHand (FFFFFFFF)->
Mon Aug 02 2021 13:37:56.649 - Skipping role TrackedControllerRole_RightHand because the device is invalid
Mon Aug 02 2021 13:37:56.649 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 13:37:56.699 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 13:37:56.702 - Capturing Scene Focus
Mon Aug 02 2021 13:38:21.880 - //==============================================================================================
Mon Aug 02 2021 13:38:21.880 - ================================================================================================
Mon Aug 02 2021 13:38:21.880 - CloudXRClient.exe 1.19.4 startup with PID=23828, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 13:38:21.881 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 13:38:21.884 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 13:38:21.886 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 13:38:21.886 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 13:38:21.886 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 13:38:21.886 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 13:38:21.886 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 13:38:21.887 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 13:38:21.887 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 13:38:21.894 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 13:38:21.895 - CSharedResourceNamespaceClient::Init(): received namespace data 22672
Mon Aug 02 2021 13:38:21.895 - Client (VR_ServerPipe_22672) app container state: 1
Mon Aug 02 2021 13:38:26.069 - Received success response from vrserver connect
Mon Aug 02 2021 13:38:26.070 - Not looking for a good app key because Steam didn’t start this app
Mon Aug 02 2021 13:38:26.070 - App key after connect message:system.generated.cloudxrclient.exe
Mon Aug 02 2021 13:38:26.077 - Client (VR_CompositorPipe_22672) app container state: 1
Mon Aug 02 2021 13:38:26.086 - Received success response from vrcompositor connect
Mon Aug 02 2021 13:38:26.086 - Initializing the limited version of CVRCompositorClient
Mon Aug 02 2021 13:38:26.086 - Attempting to load initial input config
Mon Aug 02 2021 13:38:26.088 - No controllers detected. Not waiting for config.
Mon Aug 02 2021 13:38:26.088 - /user/hand/left is FFFFFFFF
Mon Aug 02 2021 13:38:26.088 - /user/hand/right is FFFFFFFF
Mon Aug 02 2021 13:38:26.090 - TrackedControllerRole_LeftHand (FFFFFFFF)->
Mon Aug 02 2021 13:38:26.090 - Skipping role TrackedControllerRole_LeftHand because the device is invalid
Mon Aug 02 2021 13:38:26.091 - TrackedControllerRole_RightHand (FFFFFFFF)->
Mon Aug 02 2021 13:38:26.091 - Skipping role TrackedControllerRole_RightHand because the device is invalid
Mon Aug 02 2021 13:38:26.091 - TrackedControllerRole_Invalid (0)->
Mon Aug 02 2021 13:38:26.140 - Action Manifest Path set to C:\Program Files\NVIDIA Corporation\CloudXR\Client\cxr_controller_actions.json
Mon Aug 02 2021 13:38:26.143 - Capturing Scene Focus
Mon Aug 02 2021 13:55:42.160 - //==============================================================================================
Mon Aug 02 2021 13:55:42.160 - ================================================================================================
Mon Aug 02 2021 13:55:42.160 - CloudXRClient.exe 1.19.4 startup with PID=5864, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 13:55:42.160 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 13:55:42.163 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 13:55:42.164 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 13:55:42.164 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 13:55:42.164 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 13:55:42.165 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 13:55:42.165 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 13:55:42.165 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 13:55:42.166 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 13:55:42.170 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 13:55:42.178 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 13:55:42.178 - CSharedResourceNamespaceClient::Init(): received namespace data 19332
Mon Aug 02 2021 13:55:42.178 - Client (VR_ServerPipe_19332) app container state: 1
Mon Aug 02 2021 13:55:42.198 - Received connect response VRInitError_Init_HmdNotFound. Giving up.
Mon Aug 02 2021 13:57:24.790 - //==============================================================================================
Mon Aug 02 2021 13:57:24.791 - ================================================================================================
Mon Aug 02 2021 13:57:24.791 - CloudXRClient.exe 1.19.4 startup with PID=1896, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 13:57:24.791 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 13:57:24.793 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 13:57:24.795 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:24.795 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:24.795 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:24.795 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:24.795 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:24.796 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:24.796 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 13:57:24.800 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 13:57:24.802 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 13:57:24.802 - CSharedResourceNamespaceClient::Init(): received namespace data 17756
Mon Aug 02 2021 13:57:24.802 - Client (VR_ServerPipe_17756) app container state: 1
Mon Aug 02 2021 13:57:24.826 - Received connect response VRInitError_Init_HmdNotFound. Giving up.
Mon Aug 02 2021 13:57:39.605 - //==============================================================================================
Mon Aug 02 2021 13:57:39.605 - ================================================================================================
Mon Aug 02 2021 13:57:39.605 - CloudXRClient.exe 1.19.4 startup with PID=11072, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 13:57:39.606 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 13:57:39.608 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 13:57:39.610 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:39.610 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:39.610 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:39.610 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:39.610 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:39.610 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 13:57:39.611 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 13:57:39.615 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 13:57:39.623 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 13:57:39.623 - CSharedResourceNamespaceClient::Init(): received namespace data 17756
Mon Aug 02 2021 13:57:39.623 - Client (VR_ServerPipe_17756) app container state: 1
Mon Aug 02 2021 13:57:39.645 - Received connect response VRInitError_Init_HmdNotFound. Giving up.
Mon Aug 02 2021 14:13:55.864 - //==============================================================================================
Mon Aug 02 2021 14:13:55.864 - ================================================================================================
Mon Aug 02 2021 14:13:55.864 - CloudXRClient.exe 1.19.4 startup with PID=9512, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 14:13:55.865 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 14:13:55.867 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 14:13:55.868 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 14:13:55.869 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 14:13:55.869 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 14:13:55.869 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 14:13:55.869 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 14:13:55.869 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 14:13:55.870 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 14:13:55.874 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 14:13:55.876 - CSharedResourceNamespaceClient::Init(): received namespace data 22656
Mon Aug 02 2021 14:13:55.876 - Client (VR_ServerPipe_22656) app container state: 1
Mon Aug 02 2021 14:13:55.901 - Received connect response VRInitError_Init_HmdNotFound. Giving up.
Mon Aug 02 2021 15:15:20.154 - //==============================================================================================
Mon Aug 02 2021 15:15:20.154 - ================================================================================================
Mon Aug 02 2021 15:15:20.155 - CloudXRClient.exe 1.18.7 startup with PID=4100, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 15:15:20.155 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 15:15:20.157 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 15:15:20.158 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 15:15:20.158 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 15:15:20.158 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 15:15:20.159 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 15:15:20.159 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 15:15:20.159 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 15:15:20.159 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 15:15:20.164 - Starting vrserver process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrserver.exe
Mon Aug 02 2021 15:15:20.166 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:15:20.166 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:15:20.272 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 15:15:20.288 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 15:15:20.288 - CSharedResourceNamespaceClient::Init(): received namespace data 2208
Mon Aug 02 2021 15:15:20.395 - Client (VR_ServerPipe_2208) app container state: 1
Mon Aug 02 2021 15:15:20.439 - Received connect response VRInitError_Init_HmdNotFound. Giving up.
Mon Aug 02 2021 15:15:25.806 - Giving up waiting for vrserver to exit after 5000ms – killing it
Mon Aug 02 2021 15:15:25.812 - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrmonitor.exe with pid 17744
Mon Aug 02 2021 15:16:03.313 - //==============================================================================================
Mon Aug 02 2021 15:16:03.313 - ================================================================================================
Mon Aug 02 2021 15:16:03.313 - CloudXRClient.exe 1.18.7 startup with PID=10408, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 15:16:03.314 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 15:16:03.316 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 15:16:03.317 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 15:16:03.317 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 15:16:03.318 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 15:16:03.318 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 15:16:03.318 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 15:16:03.318 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 15:16:03.319 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 15:16:03.323 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 15:16:03.331 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 15:16:03.331 - CSharedResourceNamespaceClient::Init(): received namespace data 6308
Mon Aug 02 2021 15:16:03.331 - Client (VR_ServerPipe_6308) app container state: 1
Mon Aug 02 2021 15:16:03.344 - Received connect response VRInitError_Init_HmdNotFound. Giving up.
Mon Aug 02 2021 15:18:29.829 - //==============================================================================================
Mon Aug 02 2021 15:18:29.829 - ================================================================================================
Mon Aug 02 2021 15:18:29.830 - CloudXRClient.exe 1.18.7 startup with PID=660, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 15:18:29.830 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 15:18:29.832 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 15:18:29.834 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 15:18:29.834 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 15:18:29.834 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 15:18:29.834 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 15:18:29.834 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 15:18:29.834 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 15:18:29.835 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 15:18:29.839 - Starting vrserver process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrserver.exe
Mon Aug 02 2021 15:18:29.849 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:18:29.849 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:18:29.960 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 15:18:29.975 - CSharedResourceNamespaceClient::Init(): received namespace data 15300
Mon Aug 02 2021 15:18:30.082 - Client (VR_ServerPipe_15300) app container state: 1
Mon Aug 02 2021 15:18:30.131 - Received connect response VRInitError_Init_HmdNotFound. Giving up.
Mon Aug 02 2021 15:18:35.502 - Giving up waiting for vrserver to exit after 5000ms – killing it
Mon Aug 02 2021 15:18:35.508 - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrmonitor.exe with pid 19196
Mon Aug 02 2021 15:19:06.985 - //==============================================================================================
Mon Aug 02 2021 15:19:06.985 - ================================================================================================
Mon Aug 02 2021 15:19:06.985 - CloudXRClient.exe 1.18.7 startup with PID=23024, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 15:19:06.986 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 15:19:06.988 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 15:19:06.989 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 15:19:06.990 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 15:19:06.990 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 15:19:06.990 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 15:19:06.990 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 15:19:06.990 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 15:19:06.991 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 15:19:06.995 - Starting vrserver process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrserver.exe
Mon Aug 02 2021 15:19:06.996 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:19:06.996 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:19:07.110 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 15:19:07.126 - Closing pipe SteamVR_Namespace because it was broken from the other end
Mon Aug 02 2021 15:19:07.126 - CSharedResourceNamespaceClient::Init(): received namespace data 13332
Mon Aug 02 2021 15:19:07.233 - Client (VR_ServerPipe_13332) app container state: 1
Mon Aug 02 2021 15:19:07.282 - Received connect response VRInitError_Init_HmdNotFound. Giving up.
Mon Aug 02 2021 15:19:12.640 - Giving up waiting for vrserver to exit after 5000ms – killing it
Mon Aug 02 2021 15:19:12.646 - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrmonitor.exe with pid 10500
Mon Aug 02 2021 15:41:58.190 - //==============================================================================================
Mon Aug 02 2021 15:41:58.190 - ================================================================================================
Mon Aug 02 2021 15:41:58.190 - CloudXRClient.exe 1.19.4 startup with PID=25296, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 15:41:58.190 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 15:41:58.192 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 15:41:58.194 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 15:41:58.194 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 15:41:58.194 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 15:41:58.195 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 15:41:58.195 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 15:41:58.195 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 15:41:58.196 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 15:41:58.202 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 15:41:58.204 - Unable to open process id=10456 from pipe SteamVR_Namespace after connecting because Access is denied.
(5)
Mon Aug 02 2021 15:41:58.205 - Starting vrserver process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrserver.exe
Mon Aug 02 2021 15:41:58.221 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 15:44:14.259 - Unable to read pid from pipe SteamVR_Namespace after connecting because The pipe has been ended.
(109)
Mon Aug 02 2021 15:44:14.259 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:14.259 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:14.370 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:14.370 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:14.477 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:14.477 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:14.583 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:14.583 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:14.690 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:14.690 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:14.798 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:14.798 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:14.906 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:14.906 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.012 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.012 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.120 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.120 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.226 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.226 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.332 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.332 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.440 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.440 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.547 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.547 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.653 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.653 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.761 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.761 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.868 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.868 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:15.975 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:15.975 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:16.082 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:16.082 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:16.189 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:16.189 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:16.296 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:16.296 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:16.403 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:16.403 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:16.510 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:16.510 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:16.617 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:16.617 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:16.723 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:16.723 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:16.832 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:16.832 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:16.938 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:16.938 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:17.044 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:17.044 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:17.151 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:17.151 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:17.259 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:17.259 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:17.366 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:17.366 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:17.473 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:17.473 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:17.581 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:17.581 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:17.687 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:17.687 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:17.795 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:17.795 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:17.901 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:17.901 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.009 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.009 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.115 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.115 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.223 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.223 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.330 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.330 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.436 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.436 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.544 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.544 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.651 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.651 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.757 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.757 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.865 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.865 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:18.972 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:18.972 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:19.080 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:19.080 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:19.186 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:19.186 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:19.293 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:19.293 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:19.401 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:19.401 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:19.507 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:19.507 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:19.615 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:19.615 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:19.721 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:19.721 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:19.828 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:19.828 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:19.935 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:19.935 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:20.041 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:20.041 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:20.148 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:20.148 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:20.254 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:20.254 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:20.363 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:20.363 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:20.469 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 15:44:20.470 - Unable to open process id=24652 from pipe SteamVR_Namespace after connecting because Access is denied.
(5)
Mon Aug 02 2021 15:44:20.470 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:20.470 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:21.585 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:21.585 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:21.585 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:22.703 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:22.703 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:22.703 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:23.820 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:23.820 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:23.820 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:24.937 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:24.937 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:24.937 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:26.055 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:26.055 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:26.055 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:27.171 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:27.171 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:27.171 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:28.286 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:28.286 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:28.286 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:29.403 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:29.403 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:29.403 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:30.517 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:30.517 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:30.517 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:31.191 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:31.191 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:31.297 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:31.297 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:31.403 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:31.403 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:31.509 - Client (SteamVR_Namespace) app container state: 1
Mon Aug 02 2021 15:44:31.524 - Unable to open process id=25860 from pipe SteamVR_Namespace after connecting because Access is denied.
(5)
Mon Aug 02 2021 15:44:31.524 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:31.524 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:32.637 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:32.637 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:32.637 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:33.755 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:33.755 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:33.755 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:34.873 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:34.873 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:34.873 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:35.988 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:35.988 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:35.988 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:37.102 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:37.102 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:37.102 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:38.218 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:38.218 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:38.218 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:39.336 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:39.336 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:39.336 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:40.446 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:40.446 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:40.446 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:41.563 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:41.563 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:41.563 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:42.679 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:42.679 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:42.679 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:43.793 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:43.793 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:43.793 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:44.911 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:44.911 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:44.911 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:46.026 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:46.026 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:46.026 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:47.140 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:47.140 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:47.140 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:48.256 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:48.256 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:48.256 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:49.373 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:49.373 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:49.373 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:44:50.490 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:44:50.490 - CSharedResourceNamespaceClient::Init(): failed connect
Mon Aug 02 2021 15:44:50.490 - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Mon Aug 02 2021 15:45:29.956 - //==============================================================================================
Mon Aug 02 2021 15:45:29.956 - ================================================================================================
Mon Aug 02 2021 15:45:29.956 - CloudXRClient.exe 1.19.4 startup with PID=18396, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Mon Aug 02 2021 15:45:29.957 - vrclient type=VRApplication_Scene
Mon Aug 02 2021 15:45:29.959 - Skipping external driver C:\Program Files (x86)\Steam\steamapps\common\iVRy because it is not a directory
Mon Aug 02 2021 15:45:29.960 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Mon Aug 02 2021 15:45:29.961 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Mon Aug 02 2021 15:45:29.961 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Mon Aug 02 2021 15:45:29.961 - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Mon Aug 02 2021 15:45:29.961 - [Settings] Load Default Json Settings from C:\Program Files\Virtual Desktop Streamer\OpenVRDriver\resources\settings\default.vrsettings
Mon Aug 02 2021 15:45:29.961 - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Mon Aug 02 2021 15:45:29.962 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Mon Aug 02 2021 15:45:30.974 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:45:30.974 - Starting vrserver process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrserver.exe
Mon Aug 02 2021 15:45:31.984 - WaitNamedPipe SteamVR_Namespace failed because The semaphore timeout period has expired.
(121)
Mon Aug 02 2021 15:45:31.984 - CSharedResourceNamespaceClient::Init(): failed connect
