Green screen in *one eye only*? (Not RDP!)
Hi folks,
We’re currently testing out CloudXR connectivity over several bespoke use cases and have run into issues with one specific server - running on Windows Server 2019 Standard - that only sends the frame on the left eye, whereas the right eye is the notorious green screen.
We’re well aware of the various ways green screen can be induced (as well as the corresponding section in the FAQ) but this seems anomalous. Have you ever encountered green screen on one eye, and might you have any intuition around the cause?
This is a bespoke (modified) CloudXR client, but one that runs normally when connecting to other machines, leading to the suspicion this is an OS-dependent issue. Any ideas will be very helpful!
here’s a typical (broken experience) server log. Note the repeating Format ID 101 isn't supported by encoder - I don’t know if it’s relevant, but haven’t seen it on successful connections to other servers. To restate the problem, all green screen, no RDP / other streaming or recording software that I know of.
#1(I)[2022-09-09 22:00:38,990]=15:00:38=*00000*{7084}&8ED452E2&<VersionDump>      Build Information:
#2(M)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&1768021A&<VersionDump>      Name: unnamed
#3(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&06C7E314&<VersionDump>      Major: 1
#4(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&216DDCB2&<VersionDump>      Minor: 1
#5(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&6B81A1EB&<VersionDump>      User Name: (suppressed)
#6(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&DAE5B9FD&<VersionDump>      Host Name: W16-F11-14-3
#7(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&6A114841&<VersionDump>      Build DateTime: Mon, 11 Apr 2022 21:28:21
#8(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&2E2A887C&<VersionDump>      Build Configuration: release
#9(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&BD503B9B&<VersionDump>      Build Version: 1.1.3119.5106
#0(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&BFA43AD0&<VersionDump>      P4 Clientspec: unknown
#1(M)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&4D0C8C8A&<VersionDump>      P4 Changelist: 31195106
#2(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&905DF70D&<VersionDump>      DVS Build: 1
#3(M)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&CF6CAAC5&<VersionDump>      DVS Branch: gcomp/rel/gs_04_42
#4(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&661E990F&<VersionDump>      DVS OS: Windows 2016_Server
#5(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&3EDCADF1&<VersionDump>      DVS Component: gs_04_42 Release Windows StreamSdk Server Monolithic
#6(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&AB8D774D&<VersionDump>      DVS IsVirtual: false
#7(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&DED4FFF8&<VersionDump>      DVS P4HWChangelist: 61300415
#8(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&6228EADB&<VersionDump>      DVS P4SWChangelist: 31195106
#9(I)[2022-09-09 22:00:38,991]=15:00:38=*00000*{7084}&EA649458&<VersionDump>      DVS P4VirtualChangelist: 31195106
#0(I)[2022-09-09 22:00:39,016]=15:00:39=*00024*{7084}&53442FDE&<GPUInfo>          Windows 10.0.17763.2090, DD version 511.65: using NvAPI_Coproc_GetCoprocInfo.
#1(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&0238B5CC&<GPUInfo>          GPU's = {
#2(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&57CC0102&<GPUInfo>          	{
#3(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&8F3B57C9&<GPUInfo>          	FriendlyName=GRID RTX8000-8A
#4(M)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&94885373&<GPUInfo>          	Is GPU in local Game Streaming Whitelist=1
#5(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&BEAFA437&<GPUInfo>          	}
#6(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&57CC0102&<GPUInfo>          	{
#7(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&8F3B57C9&<GPUInfo>          	FriendlyName=VMWARE SVGA 3D
#8(M)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&94885373&<GPUInfo>          	Is GPU in local Game Streaming Whitelist=0
#9(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&BEAFA437&<GPUInfo>          	}
#0(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&FCB6E20C&<GPUInfo>          }
#1(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&5514369E&<GPUInfo>          Nvidia GPU count: 1, Non Nvidia GPU count: 1, Coproc: FALSE
#2(I)[2022-09-09 22:00:39,016]=15:00:39=*00000*{7084}&FAAF5066&<Utils>            Head DeviceName: \\.\DISPLAY2, DeviceString: NVIDIA Quadro RTX 6000, AttachedToDesktop, MonitorConnected
#3(I)[2022-09-09 22:00:39,017]=15:00:39=*00000*{7084}&29F012F4&<Utils>            Adapter vendor id: 0x10de, device name: \\.\DISPLAY2
#4(I)[2022-09-09 22:00:39,017]=15:00:39=*00000*{7084}&29F012F4&<Utils>            Adapter vendor id: 0x1414, device name: \\.\DISPLAY1
#5(M)[2022-09-09 22:00:39,017]=15:00:39=*00000*{7084}&7DF5E4E1&<Server>           Using: OpenSSL 1.1.1g  21 Apr 2020
#6(M)[2022-09-09 22:00:39,018]=15:00:39=*00000*{7084}&55B93E2E&<Server>           RND is initialized
#7(I)[2022-09-09 22:00:39,018]=15:00:39=*00000*{7084}&391949E9&<Server>           Enumerating network adapters on this system
#8(M)[2022-09-09 22:00:39,071]=15:00:39=*00053*{7084}&AD28CD28&<Server>           --- ...: ... / ...
#9(M)[2022-09-09 22:00:39,071]=15:00:39=*00000*{7084}&CC7C5461&<NvEncUtil>        Computing SPS/PPS headers.
#0(W)[2022-09-09 22:00:39,071]=15:00:39=*00000*{7084}&0564BB28&<VideoFrameContex> Couldn't find VideoFrameContext for this thread.
#1(M)[2022-09-09 22:00:39,071]=15:00:39=*00000*{7084}&1E959A86&<AdapterContext>   Initializing Adapter context
#2(I)[2022-09-09 22:00:39,178]=15:00:39=*00106*{7084}&57B570EB&<AdapterContext>   Using D3D9 Adapter Context
#3(M)[2022-09-09 22:00:39,178]=15:00:39=*00000*{7084}&F0E847F4&<AdapterContext>   Initialized context for adapter 0: 1280 x 1024 @ 60.0 Hz
#4(M)[2022-09-09 22:00:39,178]=15:00:39=*00000*{7084}&EF48F7C5&<AdapterContext>   Driver version is 511.65, branch is r511_37.
#5(M)[2022-09-09 22:00:39,178]=15:00:39=*00000*{7084}&9A64D99C&<AdapterContext>   System is NOT co-proc.
#6(I)[2022-09-09 22:00:39,178]=15:00:39=*00000*{7084}&00F7D8C5&<ServerMiscUtils>  Found a match at [18]
#7(M)[2022-09-09 22:00:39,178]=15:00:39=*00000*{7084}&8BAD092A&<VideoEncoder>     Initializing NvEnc10VideoEncoder.
#8(M)[2022-09-09 22:00:39,178]=15:00:39=*00000*{7084}&2A6D6983&<NvEnc10VideoEnco> Using NvEnc header version 10.0.
#9(I)[2022-09-09 22:00:39,194]=15:00:39=*00015*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 1280x720@30 FPS in video format H.264.
#0(I)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&06B0CEE1&<NvEnc10VideoEnco> Encoder maxLumaPixelsPerSec[0] 0
#1(I)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&06B0CEE1&<NvEnc10VideoEnco> Encoder maxLumaPixelsPerSec[1] 0
#2(W)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#3(I)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 1280x720@60 FPS in video format H.264.
#4(W)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#5(I)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 1920x1080@30 FPS in video format H.264.
#6(W)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#7(I)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 1920x1080@60 FPS in video format H.264.
#8(W)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#9(I)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 3840x2160@30 FPS in video format H.264.
#0(W)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#1(I)[2022-09-09 22:00:39,194]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 3840x2160@60 FPS in video format H.264.
#3(I)[2022-09-09 22:00:39,195]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 1280x720@30 FPS in video format HEVC.
#4(W)[2022-09-09 22:00:39,195]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#5(I)[2022-09-09 22:00:39,195]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 1280x720@60 FPS in video format HEVC.
#6(W)[2022-09-09 22:00:39,195]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#7(I)[2022-09-09 22:00:39,195]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 1920x1080@30 FPS in video format HEVC.
#8(W)[2022-09-09 22:00:39,195]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#9(I)[2022-09-09 22:00:39,195]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 1920x1080@60 FPS in video format HEVC.
#0(W)[2022-09-09 22:00:39,195]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#1(I)[2022-09-09 22:00:39,195]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 3840x2160@30 FPS in video format HEVC.
#2(I)[2022-09-09 22:00:39,196]=15:00:39=*00000*{7084}&15146C37&<VideoEncoder>     Encoder supports encoding 10 bit
#3(W)[2022-09-09 22:00:39,196]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#4(I)[2022-09-09 22:00:39,196]=15:00:39=*00000*{7084}&63E4AB2C&<NvEncUtil>        Generating SPS/PPS header for 3840x2160@60 FPS in video format HEVC.
#5(W)[2022-09-09 22:00:39,196]=15:00:39=*00000*{7084}&6474EB61&<NvEncUtil>        Encoder does not have enough performance to support this format.
#6(I)[2022-09-09 22:00:39,214]=15:00:39=*00017*{7084}&94F8CC76&<AdapterContext>   Deinitialized context for adapter 0
#7(W)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&FB11B4FE&<VideoEncoder>     VideoEncoder was not deinitialized prior to destruction!
#8(M)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&B4368309&<NvEncUtil>        Finished computing SPS/PPS headers.
#9(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&8FD59D06&<NvNetworkCommon>  Ip version provided externally.
#0(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&F7FF6AD5&<NvNetworkCommon>  Setting IPv4 for this session.
#1(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&83A50A12&<Server>           StreamServerBackendMode is 0
#2(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&289F96E1&<Server>           Server has been asked to start.
#3(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&A5352908&<Server>           Server has been asked to add a stream.
#4(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&D97A9142&<Server>           Adding a video stream.
#5(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&A5352908&<Server>           Server has been asked to add a stream.
#6(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&D97A9142&<Server>           Adding a video stream.
#7(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&A5352908&<Server>           Server has been asked to add a stream.
#8(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&5B311946&<Server>           Adding input stream.
#9(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&A5352908&<Server>           Server has been asked to add a stream.
#0(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&7190895A&<Server>           Adding audio stream.
#1(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&A5352908&<Server>           Server has been asked to add a stream.
#2(I)[2022-09-09 22:00:39,214]=15:00:39=*00000*{7084}&67C43FD4&<Server>           Adding microphone stream.
#3(I)[2022-09-09 22:00:39,218]=15:00:39=*00004*{7084}&FAAF5066&<Utils>            Head DeviceName: \\.\DISPLAY2, DeviceString: NVIDIA Quadro RTX 6000, AttachedToDesktop, MonitorConnected
#4(I)[2022-09-09 22:00:39,219]=15:00:39=*00000*{7084}&29F012F4&<Utils>            Adapter vendor id: 0x10de, device name: \\.\DISPLAY2
#5(I)[2022-09-09 22:00:39,219]=15:00:39=*00000*{7084}&29F012F4&<Utils>            Adapter vendor id: 0x1414, device name: \\.\DISPLAY1
#6(I)[2022-09-09 22:00:39,219]=15:00:39=*00000*{7084}&CA885F31&<Server>           Using 2 streams.
#7(I)[2022-09-09 22:00:39,220]=15:00:39=*00000*{7084}&47DE28F5&<RtspServerInstan> RTSP Server: TCP instance
#8(I)[2022-09-09 22:00:39,220]=15:00:39=*00000*{7084}&4D807C29&<RtspServerTcp>    RTSP server successfully started on port 48010 (thread count 4)
#9(I)[2022-09-09 22:00:39,220]=15:00:39=*00000*{7084}&0414BD9D&<Server>           Successfully started server.
#0(I)[2022-09-09 22:00:39,220]=15:00:39=*00000*{7084}&D4F95EB4&<Server>           Server is now in state: Started
#1(I)[2022-09-09 22:00:45,517]=15:00:45=*00000*{3748}&423E522A&<RtspServerTcp>    TCP RTSP Server: handling OPTIONS: ...
#2(I)[2022-09-09 22:00:45,517]=15:00:45=*00000*{3748}&AAAFE859&<RtspServerTcp>    TCP RTSP Server: got client header version: 14.2
#3(I)[2022-09-09 22:00:45,517]=15:00:45=*00000*{3748}&62E90CBC&<RtspHandshake>    RtspHandshake::onRtspOptions : handling request: 1
#4(I)[2022-09-09 22:00:45,517]=15:00:45=*00000*{3748}&F23C0516&<RtspHandshake>    Session ID not set. Setting CSeq to 1
#5(I)[2022-09-09 22:00:45,517]=15:00:45=*00000*{3748}&42BF04B1&<RtspHandshake>    Found client RTP extension header version 2
#6(I)[2022-09-09 22:00:45,517]=15:00:45=*00000*{376}&33D8F629&<StreamSdkEvents>  Invoking clientEventCallback NvstEventDetail::NVST_ED_CLIENT_CONNECTING:
#7(I)[2022-09-09 22:00:45,517]=15:00:45=*00000*{376}&491E1113&<StreamSdkEvents>  Invoking diagnosticsEventRaised RtspOptions
#8(I)[2022-09-09 22:00:45,517]=15:00:45=*00000*{376}&77BBF756&<StreamSdkEvents>  No diagnosticsEventRaised callback provided.
#9(I)[2022-09-09 22:00:45,517]=15:00:45=*00000*{1080}&299364F1&<NvNetworkWin32>   Wait For Socket Event: wait was canceled by event: 0000000000000EDC
#0(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&5DA95679&<RtspServerTcp>    TCP RTSP Server: handling DESCRIBE: ...
#1(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&CFFBE399&<RtspServerTcp>    TCP RTSP Server: handling DESCRIBE for host ... in delegate ...
#2(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&62E90CBC&<RtspHandshake>    RtspHandshake::onRtspDescribe : handling request: 2
#3(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 101 isn't supported by encoder
#4(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 102 isn't supported by encoder
#5(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 103 isn't supported by encoder
#6(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 103 isn't supported by encoder
#7(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 104 isn't supported by encoder
#8(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 105 isn't supported by encoder
#9(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 111 isn't supported by encoder
#0(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 112 isn't supported by encoder
#1(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 113 isn't supported by encoder
#2(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 113 isn't supported by encoder
#3(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 114 isn't supported by encoder
#4(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 115 isn't supported by encoder
#5(E)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&F080412D&<RtspHandshake>    No SPS/PPS added to RTSP describe. Proceed and client would ask for SPS/PPS again.
#6(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&9216B414&<RtspHandshake>    Not sending server's qosTimingsVersion because feature is disabled.
#7(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 101 isn't supported by encoder
#8(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 102 isn't supported by encoder
#9(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 103 isn't supported by encoder
#0(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 103 isn't supported by encoder
#1(I)[2022-09-09 22:00:45,704]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 104 isn't supported by encoder
#2(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 105 isn't supported by encoder
#3(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 111 isn't supported by encoder
#4(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 112 isn't supported by encoder
#5(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 113 isn't supported by encoder
#6(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 113 isn't supported by encoder
#7(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 114 isn't supported by encoder
#8(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&2664922A&<RtspHandshake>    Format ID 115 isn't supported by encoder
#9(E)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&F080412D&<RtspHandshake>    No SPS/PPS added to RTSP describe. Proceed and client would ask for SPS/PPS again.
#0(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&9216B414&<RtspHandshake>    Not sending server's qosTimingsVersion because feature is disabled.
#1(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&F9FCF607&<RtspHandshake>    Sending SDP for audio: CAPS: Version=1 Bits=0x1
#2(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&02B8EE57&<RtspHandshake>    LAN type detected - setting opus mapping to true
#3(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&8C2AE4C6&<RtspHandshake>    Max channels 1, opus mapping TRUE
#4(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&240CFEED&<RtspHandshake>    Sending SDP for mic audio: CAPS: Version=1 Bits=0x1
#5(I)[2022-09-09 22:00:45,705]=15:00:45=*00000*{2416}&C9719BB2&<NvscClientConfig> Failed to open config file from location: C:\Users\pluto\AppData\Local\NVIDIA\CloudXR\server_side_nvscClientConfig.txt
#6(I)[2022-09-09 22:00:45,706]=15:00:45=*00000*{2416}&00000000&<RtspHandshake>    Random HMAC seed: ECDF...DF38 [64]
#7(I)[2022-09-09 22:00:45,706]=15:00:45=*00000*{2416}&5B602769&<NvscSerialize>    AppendNvscConfigToSdp
#8(I)[2022-09-09 22:00:45,707]=15:00:45=*00001*{2416}&2F256CC5&<NvscSerialize>    Successfully appended 0 NvscClientConfig attributes to SDP.
#9(I)[2022-09-09 22:00:45,707]=15:00:45=*00000*{2416}&EBB67514&<SDP>              Is Valid SDP: 1
#0(I)[2022-09-09 22:00:45,708]=15:00:45=*00000*{2416}&5B602769&<NvscSerialize>    AppendNvscConfigToSdp
#1(I)[2022-09-09 22:00:45,715]=15:00:45=*00007*{2416}&2F256CC5&<NvscSerialize>    Successfully appended 1784 NvscClientConfig attributes to SDP.
#2(I)[2022-09-09 22:00:45,715]=15:00:45=*00000*{2416}&EBB67514&<SDP>              Is Valid SDP: 1
#3(I)[2022-09-09 22:00:45,716]=15:00:45=*00198*{376}&491E1113&<StreamSdkEvents>  Invoking diagnosticsEventRaised RtspDescribe
#4(I)[2022-09-09 22:00:45,716]=15:00:45=*00000*{376}&77BBF756&<StreamSdkEvents>  No diagnosticsEventRaised callback provided.
#5(I)[2022-09-09 22:00:45,716]=15:00:45=*00000*{2416}&D6D2C519&<RtspServerTcp>    TCP RTSP Server: response code for DESCRIBE: 200
#6(I)[2022-09-09 22:00:45,716]=15:00:45=*00000*{5600}&299364F1&<NvNetworkWin32>   Wait For Socket Event: wait was canceled by event: 0000000000000EDC
#7(I)[2022-09-09 22:00:46,055]=15:00:46=*00000*{7208}&1900689F&<RtspServerTcp>    TCP RTSP Server: handling SETUP: streamid=audio/0/0
#8(I)[2022-09-09 22:00:46,055]=15:00:46=*00000*{7208}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49003
#9(I)[2022-09-09 22:00:46,055]=15:00:46=*00000*{7208}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49003
#0(I)[2022-09-09 22:00:46,055]=15:00:46=*00000*{7208}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49003
#1(I)[2022-09-09 22:00:46,055]=15:00:46=*00000*{7208}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49003
#2(I)[2022-09-09 22:00:46,055]=15:00:46=*00000*{7208}&E289E304&<RtspHandshake>    RtspHandshake::onRtspSetup : handling request: 3 0 0 0 0
#3(I)[2022-09-09 22:00:46,056]=15:00:46=*00000*{7208}&EA6208C2&<NativeServer>     Server is preparing for a new session.
#4(I)[2022-09-09 22:00:46,064]=15:00:46=*00008*{7208}&B6269926&<NvscStreamingSes> Allocated 2 ConnectionInfo entries
#5(E)[2022-09-09 22:00:46,064]=15:00:46=*00000*{7208}&C6E10B0B&<NvNetworkCommon>  Socket Get Parameter: failed to query parameter 8 for socket 3932 (Error: 10022)
#6(I)[2022-09-09 22:00:46,067]=15:00:46=*00002*{7208}&00000000&<NvSocketUdp>      UDP Socket is now configured as exclusive.
#7(E)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&C6E10B0B&<NvNetworkCommon>  Socket Get Parameter: failed to query parameter 8 for socket 3944 (Error: 10022)
#8(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&00000000&<NvSocketUdp>      UDP Socket is now configured as exclusive.
#9(E)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&C6E10B0B&<NvNetworkCommon>  Socket Get Parameter: failed to query parameter 8 for socket 3956 (Error: 10022)
#0(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&00000000&<NvSocketUdp>      UDP Socket is now configured as exclusive.
#1(E)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&C6E10B0B&<NvNetworkCommon>  Socket Get Parameter: failed to query parameter 8 for socket 3968 (Error: 10022)
#2(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&00000000&<NvSocketUdp>      UDP Socket is now configured as exclusive.
#3(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&6AA201F7&<UdpRtpSource>     UDP RTP Source: bound to ...
#4(E)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&C6E10B0B&<NvNetworkCommon>  Socket Get Parameter: failed to query parameter 8 for socket 3980 (Error: 10022)
#5(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&00000000&<NvSocketUdp>      UDP Socket is now configured as exclusive.
#6(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&D4F95EB4&<Server>           Server is now in state: Configuring
#7(M)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&70BFD087&<Server>           Server is now configuring.
#8(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&2676C52E&<NativeServer>     Server is handling a request to setup a connection.
#9(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&3A08FF1D&<NattHolePunch>    NattHolePunch: Set ping-version: 5
#0(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&1CA17458&<NattHolePunch>    NattHolePunch: Set ping-string XNV1308351440
#1(I)[2022-09-09 22:00:46,067]=15:00:46=*00000*{7208}&81EB5623&<NattHolePunch>    Initialize hashing with text
#2(I)[2022-09-09 22:00:46,073]=15:00:46=*00005*{7208}&00000000&<Authentication>   PING_KEY: EA71...81C4 [64]
#3(E)[2022-09-09 22:00:46,075]=15:00:46=*00001*{7208}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#4(E)[2022-09-09 22:00:46,075]=15:00:46=*00000*{7208}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#5(E)[2022-09-09 22:00:46,075]=15:00:46=*00000*{7208}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C73DA20, 000000503C73DA40, 48
#6(E)[2022-09-09 22:00:46,075]=15:00:46=*00000*{7208}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#7(E)[2022-09-09 22:00:46,075]=15:00:46=*00000*{7208}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#8(E)[2022-09-09 22:00:46,075]=15:00:46=*00000*{7208}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C73DA20, 000000503C73DA40, 48
#9(E)[2022-09-09 22:00:46,075]=15:00:46=*00000*{7208}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#0(E)[2022-09-09 22:00:46,075]=15:00:46=*00000*{7208}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#1(E)[2022-09-09 22:00:46,075]=15:00:46=*00000*{7208}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C73DA20, 000000503C73DA40, 48
#2(I)[2022-09-09 22:00:46,078]=15:00:46=*00002*{7208}&8788EA9B&<NattHolePunch>    LAN type detected
#3(I)[2022-09-09 22:00:46,078]=15:00:46=*00000*{7208}&0D20B417&<NattHolePunch>    Adding address: ...
#4(I)[2022-09-09 22:00:46,078]=15:00:46=*00000*{7208}&0D20B417&<NattHolePunch>    Adding address: ...
#5(W)[2022-09-09 22:00:46,078]=15:00:46=*00000*{7208}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#6(W)[2022-09-09 22:00:46,078]=15:00:46=*00000*{7208}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#7(W)[2022-09-09 22:00:46,078]=15:00:46=*00000*{7208}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#8(I)[2022-09-09 22:00:46,078]=15:00:46=*00000*{7208}&20E3A617&<NetworkRtpSink>   Network RTP Sink: Keeping address ... as default peer
#9(I)[2022-09-09 22:00:46,078]=15:00:46=*00000*{7208}&12319961&<NvscStreamingSes> Connection setup: audio stream port 48000 (1)
#0(I)[2022-09-09 22:00:46,078]=15:00:46=*00361*{376}&491E1113&<StreamSdkEvents>  Invoking diagnosticsEventRaised RtspSetup
#1(I)[2022-09-09 22:00:46,078]=15:00:46=*00000*{376}&77BBF756&<StreamSdkEvents>  No diagnosticsEventRaised callback provided.
#2(I)[2022-09-09 22:00:46,078]=15:00:46=*00000*{1064}&299364F1&<NvNetworkWin32>   Wait For Socket Event: wait was canceled by event: 0000000000000EFC
#3(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&1900689F&<RtspServerTcp>    TCP RTSP Server: handling SETUP: streamid=video/0/0
#4(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49005
#5(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49005
#6(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49005
#7(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49005
#8(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&E289E304&<RtspHandshake>    RtspHandshake::onRtspSetup : handling request: 4 304506794 1 0 0
#9(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&2676C52E&<NativeServer>     Server is handling a request to setup a connection.
#0(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&3A08FF1D&<NattHolePunch>    NattHolePunch: Set ping-version: 5
#1(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&1CA17458&<NattHolePunch>    NattHolePunch: Set ping-string XNV1816942012
#2(I)[2022-09-09 22:00:46,217]=15:00:46=*00000*{6040}&81EB5623&<NattHolePunch>    Initialize hashing with text
#3(I)[2022-09-09 22:00:46,231]=15:00:46=*00013*{6040}&00000000&<Authentication>   PING_KEY: D2B4...FC19 [64]
#4(E)[2022-09-09 22:00:46,231]=15:00:46=*00000*{6040}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#5(E)[2022-09-09 22:00:46,231]=15:00:46=*00000*{6040}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#6(E)[2022-09-09 22:00:46,231]=15:00:46=*00000*{6040}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C83D2E0, 000000503C83D300, 48
#7(E)[2022-09-09 22:00:46,231]=15:00:46=*00000*{6040}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#8(E)[2022-09-09 22:00:46,231]=15:00:46=*00000*{6040}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#9(E)[2022-09-09 22:00:46,231]=15:00:46=*00000*{6040}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C83D2E0, 000000503C83D300, 48
#0(E)[2022-09-09 22:00:46,231]=15:00:46=*00000*{6040}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#1(E)[2022-09-09 22:00:46,231]=15:00:46=*00000*{6040}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#2(E)[2022-09-09 22:00:46,231]=15:00:46=*00000*{6040}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C83D2E0, 000000503C83D300, 48
#3(I)[2022-09-09 22:00:46,232]=15:00:46=*00000*{6040}&8788EA9B&<NattHolePunch>    LAN type detected
#4(I)[2022-09-09 22:00:46,232]=15:00:46=*00000*{6040}&0D20B417&<NattHolePunch>    Adding address: ...
#5(I)[2022-09-09 22:00:46,232]=15:00:46=*00000*{6040}&0D20B417&<NattHolePunch>    Adding address: ...
#6(W)[2022-09-09 22:00:46,232]=15:00:46=*00000*{6040}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#7(W)[2022-09-09 22:00:46,232]=15:00:46=*00000*{6040}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#8(W)[2022-09-09 22:00:46,232]=15:00:46=*00000*{6040}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#9(I)[2022-09-09 22:00:46,232]=15:00:46=*00000*{6040}&20E3A617&<NetworkRtpSink>   Network RTP Sink: Keeping address ... as default peer
#0(I)[2022-09-09 22:00:46,232]=15:00:46=*00000*{6040}&12319961&<NvscStreamingSes> Connection setup: video stream port 47998 (1)
#1(I)[2022-09-09 22:00:46,232]=15:00:46=*00153*{376}&491E1113&<StreamSdkEvents>  Invoking diagnosticsEventRaised RtspSetup
#2(I)[2022-09-09 22:00:46,232]=15:00:46=*00000*{376}&77BBF756&<StreamSdkEvents>  No diagnosticsEventRaised callback provided.
#3(I)[2022-09-09 22:00:46,232]=15:00:46=*00000*{8576}&299364F1&<NvNetworkWin32>   Wait For Socket Event: wait was canceled by event: 0000000000000FDC
#4(I)[2022-09-09 22:00:46,384]=15:00:46=*00867*{3748}&1900689F&<RtspServerTcp>    TCP RTSP Server: handling SETUP: streamid=video/1/1
#5(I)[2022-09-09 22:00:46,384]=15:00:46=*00000*{3748}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 53169
#6(I)[2022-09-09 22:00:46,384]=15:00:46=*00000*{3748}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 53169
#7(I)[2022-09-09 22:00:46,384]=15:00:46=*00000*{3748}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 53169
#8(I)[2022-09-09 22:00:46,384]=15:00:46=*00000*{3748}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 53169
#9(I)[2022-09-09 22:00:46,384]=15:00:46=*00000*{3748}&E289E304&<RtspHandshake>    RtspHandshake::onRtspSetup : handling request: 5 304506794 1 0 0
#0(I)[2022-09-09 22:00:46,384]=15:00:46=*00000*{3748}&2676C52E&<NativeServer>     Server is handling a request to setup a connection.
#1(I)[2022-09-09 22:00:46,384]=15:00:46=*00000*{3748}&3A08FF1D&<NattHolePunch>    NattHolePunch: Set ping-version: 5
#2(I)[2022-09-09 22:00:46,385]=15:00:46=*00000*{3748}&1CA17458&<NattHolePunch>    NattHolePunch: Set ping-string XNV943156665
#3(I)[2022-09-09 22:00:46,385]=15:00:46=*00000*{3748}&81EB5623&<NattHolePunch>    Initialize hashing with text
#4(I)[2022-09-09 22:00:46,397]=15:00:46=*00012*{3748}&00000000&<Authentication>   PING_KEY: BB3C...82FC [64]
#5(E)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#6(E)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#7(E)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C53D550, 000000503C53D570, 48
#8(E)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#9(E)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#0(E)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C53D550, 000000503C53D570, 48
#1(E)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#2(E)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#3(E)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C53D550, 000000503C53D570, 48
#4(I)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&8788EA9B&<NattHolePunch>    LAN type detected
#5(I)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&0D20B417&<NattHolePunch>    Adding address: ...
#6(I)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&0D20B417&<NattHolePunch>    Adding address: ...
#7(W)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#8(W)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#9(W)[2022-09-09 22:00:46,397]=15:00:46=*00000*{3748}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#0(I)[2022-09-09 22:00:46,398]=15:00:46=*00000*{3748}&20E3A617&<NetworkRtpSink>   Network RTP Sink: Keeping address ... as default peer
#1(I)[2022-09-09 22:00:46,398]=15:00:46=*00000*{3748}&12319961&<NvscStreamingSes> Connection setup: video stream port 48005 (1)
#2(I)[2022-09-09 22:00:46,398]=15:00:46=*00165*{376}&491E1113&<StreamSdkEvents>  Invoking diagnosticsEventRaised RtspSetup
#3(I)[2022-09-09 22:00:46,398]=15:00:46=*00000*{376}&77BBF756&<StreamSdkEvents>  No diagnosticsEventRaised callback provided.
#4(I)[2022-09-09 22:00:46,398]=15:00:46=*00000*{7728}&299364F1&<NvNetworkWin32>   Wait For Socket Event: wait was canceled by event: 0000000000000EFC
#5(I)[2022-09-09 22:00:46,540]=15:00:46=*00823*{2416}&1900689F&<RtspServerTcp>    TCP RTSP Server: handling SETUP: streamid=control/13/0
#6(I)[2022-09-09 22:00:46,540]=15:00:46=*00000*{2416}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49006
#7(I)[2022-09-09 22:00:46,540]=15:00:46=*00000*{2416}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49006
#8(I)[2022-09-09 22:00:46,540]=15:00:46=*00000*{2416}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49006
#9(I)[2022-09-09 22:00:46,540]=15:00:46=*00000*{2416}&732EF199&<RtspMessageParse> RTSP Message Parser: Client port is: 49006
#0(I)[2022-09-09 22:00:46,540]=15:00:46=*00000*{2416}&E289E304&<RtspHandshake>    RtspHandshake::onRtspSetup : handling request: 6 304506794 1 0 0
#1(I)[2022-09-09 22:00:46,540]=15:00:46=*00000*{2416}&2676C52E&<NativeServer>     Server is handling a request to setup a connection.
#2(I)[2022-09-09 22:00:46,540]=15:00:46=*00000*{2416}&3A08FF1D&<NattHolePunch>    NattHolePunch: Set ping-version: 5
#3(I)[2022-09-09 22:00:46,540]=15:00:46=*00000*{2416}&1CA17458&<NattHolePunch>    NattHolePunch: Set ping-string XNV1440110137
#4(I)[2022-09-09 22:00:46,540]=15:00:46=*00000*{2416}&81EB5623&<NattHolePunch>    Initialize hashing with text
#5(I)[2022-09-09 22:00:46,554]=15:00:46=*00013*{2416}&00000000&<Authentication>   PING_KEY: 2F35...82A1 [64]
#6(E)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#7(E)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#8(E)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C63D630, 000000503C63D650, 48
#9(E)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#0(E)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#1(E)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C63D630, 000000503C63D650, 48
#2(E)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&F41DD6F6&<NvNetworkWin32>   NvNetworkPlatformInterface::networkGetAddressInfo : Resolve address ...: failed (Error: 11001)
#3(E)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&80DCECD5&<NvNetworkCommon>  Network String To Address: failed to parse ... (Error: 11001)
#4(E)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&168334B0&<NvNetworkCommon>  Network Address To String: invalid parameters 000000503C63D630, 000000503C63D650, 48
#5(I)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&8788EA9B&<NattHolePunch>    LAN type detected
#6(I)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&0D20B417&<NattHolePunch>    Adding address: ...
#7(I)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&0D20B417&<NattHolePunch>    Adding address: ...
#8(W)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#9(W)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#0(W)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&FABB1E29&<NattHolePunch>    Address: ... is not valid
#1(I)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&20E3A617&<NetworkRtpSink>   Network RTP Sink: Keeping address ... as default peer
#2(I)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&682EA6CC&<NvscStreamingSes> Spawning hole punching thread for the control port
#3(I)[2022-09-09 22:00:46,554]=15:00:46=*00000*{2416}&12319961&<NvscStreamingSes> Connection setup: application stream port 47999 (1)
#4(I)[2022-09-09 22:00:46,554]=15:00:46=*00156*{376}&491E1113&<StreamSdkEvents>  Invoking diagnosticsEventRaised RtspSetup
#5(I)[2022-09-09 22:00:46,555]=15:00:46=*00000*{376}&77BBF756&<StreamSdkEvents>  No diagnosticsEventRaised callback provided.
#6(I)[2022-09-09 22:00:46,555]=15:00:46=*00000*{8580}&53148F1D&<NattHolePunch>    Hole punching on new thread
#7(I)[2022-09-09 22:00:46,555]=15:00:46=*00000*{8080}&299364F1&<NvNetworkWin32>   Wait For Socket Event: wait was canceled by event: 0000000000000ED4
#8(I)[2022-09-09 22:00:46,555]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: C4BD...EF6F [64]
#9(I)[2022-09-09 22:00:46,555]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#0(I)[2022-09-09 22:00:46,555]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: 45A1...AB3F [64]
#1(I)[2022-09-09 22:00:46,555]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#2(I)[2022-09-09 22:00:46,555]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: 201D...F827 [64]
#3(I)[2022-09-09 22:00:46,555]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#4(I)[2022-09-09 22:00:46,565]=15:00:46=*00009*{8580}&E7EB16D7&<NattHolePunch>    NattHolePunch: Failed to receive ping on port 47999: Timeout.
#5(I)[2022-09-09 22:00:46,576]=15:00:46=*00011*{8580}&00000000&<NattHolePunch>    HMAC PING: FDC5...D1CA [64]
#6(I)[2022-09-09 22:00:46,576]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#7(I)[2022-09-09 22:00:46,576]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: C31C...D39F [64]
#8(I)[2022-09-09 22:00:46,576]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#9(I)[2022-09-09 22:00:46,576]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: 3C0E...BABD [64]
#0(I)[2022-09-09 22:00:46,576]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#1(I)[2022-09-09 22:00:46,587]=15:00:46=*00010*{8580}&E7EB16D7&<NattHolePunch>    NattHolePunch: Failed to receive ping on port 47999: Timeout.
#2(I)[2022-09-09 22:00:46,598]=15:00:46=*00011*{8580}&00000000&<NattHolePunch>    HMAC PING: 9133...EA84 [64]
#3(I)[2022-09-09 22:00:46,598]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#4(I)[2022-09-09 22:00:46,598]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: EC36...6017 [64]
#5(I)[2022-09-09 22:00:46,598]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#6(I)[2022-09-09 22:00:46,598]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: 431D...9623 [64]
#7(I)[2022-09-09 22:00:46,598]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#8(I)[2022-09-09 22:00:46,608]=15:00:46=*00009*{8580}&E7EB16D7&<NattHolePunch>    NattHolePunch: Failed to receive ping on port 47999: Timeout.
#9(I)[2022-09-09 22:00:46,619]=15:00:46=*00011*{8580}&00000000&<NattHolePunch>    HMAC PING: A5B3...23FE [64]
#0(I)[2022-09-09 22:00:46,619]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#1(I)[2022-09-09 22:00:46,619]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: 9486...7D2F [64]
#2(I)[2022-09-09 22:00:46,619]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#3(I)[2022-09-09 22:00:46,619]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: 7542...AA3F [64]
#4(I)[2022-09-09 22:00:46,619]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#5(I)[2022-09-09 22:00:46,629]=15:00:46=*00009*{8580}&E7EB16D7&<NattHolePunch>    NattHolePunch: Failed to receive ping on port 47999: Timeout.
#6(I)[2022-09-09 22:00:46,640]=15:00:46=*00011*{8580}&00000000&<NattHolePunch>    HMAC PING: 8BAB...2E1F [64]
#7(I)[2022-09-09 22:00:46,640]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#8(I)[2022-09-09 22:00:46,640]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: 7812...631A [64]
#9(I)[2022-09-09 22:00:46,640]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#0(I)[2022-09-09 22:00:46,640]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: BE47...AC34 [64]
#1(I)[2022-09-09 22:00:46,640]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#2(I)[2022-09-09 22:00:46,646]=15:00:46=*00006*{8580}&A642C1FF&<NattHolePunch>    NattHolePunch: Received ping hash XNV1440110137 from the ...
#3(I)[2022-09-09 22:00:46,647]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: AE38...0423 [64]
#4(I)[2022-09-09 22:00:46,647]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#5(I)[2022-09-09 22:00:46,648]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: CA54...C949 [64]
#6(I)[2022-09-09 22:00:46,648]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#7(I)[2022-09-09 22:00:46,649]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: 1143...284A [64]
#8(I)[2022-09-09 22:00:46,649]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#9(I)[2022-09-09 22:00:46,650]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: C79C...1826 [64]
#0(I)[2022-09-09 22:00:46,650]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#1(I)[2022-09-09 22:00:46,651]=15:00:46=*00000*{8580}&00000000&<NattHolePunch>    HMAC PING: 4A76...6893 [64]
#2(I)[2022-09-09 22:00:46,651]=15:00:46=*00000*{8580}&ABE37ECA&<NattHolePunch>    NattHolePunch: Send source ping hash XNV1440110137 on port 47999 to destination address ...: Success
#3(I)[2022-09-09 22:00:46,731]=15:00:46=*00653*{7208}&D671BB53&<RtspServerTcp>    TCP RTSP Server: handling ANNOUNCE: streamid=control/13/0
#4(I)[2022-09-09 22:00:46,731]=15:00:46=*00000*{7208}&DC07F892&<RtspHandshake>    RtspHandshake::onRtspAnnounce : handling request: 7 304506794
#5(I)[2022-09-09 22:00:46,732]=15:00:46=*00000*{7208}&EBB67514&<SDP>              Is Valid SDP: 1
#6(I)[2022-09-09 22:00:46,734]=15:00:46=*00002*{7208}&19E2A18D&<NvscSerialize>    GetNvscConfigFromSdp
#7(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&483790F3&<NvscSerialize>    Successfully read 59 NvscClientConfig attributes from SDP.
#8(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&BC2AF0B4&<NativeServer>     Server is handling a request to establish a connection.
#9(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&4134E183&<Server>           Head 0: DevName \\.\DISPLAY2, DxAdapterOrdinal 0, DevString 'NVIDIA Quadro RTX 6000'. AttachedToDesktop MonitorConnected
#0(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&CED9E3FD&<NvscStreamingSes> Client requested Control Channel Protocol 13 (encrypted)
#1(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&50F8E0B9&<CommandPacket>    Setting Full Channel Encryption to allowed
#2(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&B95F27A5&<NvscStreamingSes> Enabling Control Channel Encryption, as requested from client
#3(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&AE805008&<NvscStreamingSes> Creating Client Connection
#4(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&CB9E349B&<NvscStreamingSes> Creating and adding StreamConnections for each stream
#5(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&F8037F0D&<Etwprof>          stream 0 nvtime::sessionStartTime[us] on server: 4050569938
#6(I)[2022-09-09 22:00:46,734]=15:00:46=*00083*{8580}&E2FBAFCD&<NattHolePunch>    Stopping Hole punching thread with status: TRUE
#7(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&D09A5541&<NattHolePunch>    Waiting Hole punching thread to finish
#8(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&B4317A03&<NetworkRtpSink>   Network RTP Sink Connect: connected to: ...
#9(I)[2022-09-09 22:00:46,734]=15:00:46=*00000*{7208}&06D04AE2&<NattHolePunch>    NattHolePunch: Setting ... as valid destination
#0(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&48B40696&<NvscStreamingSes> SESSION_PARAMETER_AUD_ENCRYPTION_KEYID: key ID 3268454710
#1(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&00000000&<NvscStreamingSes> Received SESSION_PARAMETER_AUD_ENCRYPTION_KEY (encoded): BD5C...FAF7 [64]
#2(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&00000000&<NvscStreamingSes> SESSION_PARAMETER_AUD_ENCRYPTION_KEY: BD5C...FAF7 [64]
#3(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&9AEA25EE&<NvscStreamingSes> SESSION_PARAMETER_RI_ENCRYPTION_KEYID: key ID 3268454710
#4(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&00000000&<NvscStreamingSes> Received SESSION_PARAMETER_RI_ENCRYPTION_KEY (encoded): BD5C...FAF7 [64]
#5(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&00000000&<NvscStreamingSes> SESSION_PARAMETER_RI_ENCRYPTION_KEY: BD5C...FAF7 [64]
#6(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&5DF6CB54&<CommandPacket>    NetPacket::setEncryptionKey(Key, KeyLen) keyLength 32
#7(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&2A0E569E&<CommandPacket>    AES Key set from raw key, keyLength 32
#8(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&241A7F42&<NvscStreamingSes> Waiting for full-screen succeeded
#9(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&71BE49A1&<NvscStreamingSes> Starting the streaming session thread.
#0(I)[2022-09-09 22:00:46,735]=15:00:46=*00180*{376}&33D8F629&<StreamSdkEvents>  Invoking clientEventCallback NvstEventDetail::NVST_ED_FULL_SCREEN_DETECTION_SUCCESS: Full-screen detection succeeded
#1(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{7208}&3E8F1684&<NvscStreamingSes> Waiting for the streaming session to initialize
#2(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{6568}&CAD69927&<NvscStreamingSes> Streaming session thread started
#3(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{6568}&8A77DBD2&<QosSupervisor>    Created QosSupervisor for 2 streams
#4(I)[2022-09-09 22:00:46,735]=15:00:46=*00000*{6568}&C23DC0A7&<EnetSocket>       Initializing enet
#5(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&1EEE4C6C&<EnetSocket>       EnetSocket constructor is called
#6(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&D1E87C9E&<Etwprof>          GRC config for stream 0: Disabled; up: interval 1 frames, width 64; down: interval 1 frames, width 64
#7(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&B52C0AD5&<QosManagerTxNati> Turbo mode is disabled.
#8(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&90EF2499&<QosManagerTxNati> Grabbing maximum fps value: 90 for stream:0
#9(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&9FDC322C&<PerformanceHisto> Config perf history for stream 0: Disabled, iir 60, featureMask 0x0, reset 900000 ms
#0(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&E103DA25&<QosManagerTxNati> QP DRC configuration for stream:0 IIR factor: 20.000000, update cooling time: 3, promotion cooling time: 10, lower threshold: 25.000000, upper threshold: 39.000000, minimum headroom: 2.000000, minimum adaptive threshold: 36.000000, max res adj: 0.000000, codec adj: 0.000000
#1(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&4742AF82&<QosManagerTxNati> QP GRC configuration for stream:0 update cooling time: 0.500000, promotion cooling time: 0.500000, lower threshold: 0.000000, upper threshold: 25.000000, minimum headroom: 39.000000, minimum adaptive threshold: 2.000000, max res adj: 36.000000, codec adj: 0.000000
#2(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&97E7B6E1&<QosManagerTxNati> Video BW QoS [50], max rate [50000000.000000], min rate [1000000.000000] for stream:0
#3(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&F51FA5CE&<QosManagerTxNati> stream:[0] loss threshold [2], Jitter threshold(us) [3000.000000]
#4(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&92FBF5DE&<Etwprof>          QEC feature is enabled with Frame lost thres 0 and Invalid ref thres 0
#5(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&A4D933F3&<QosManagerTxNati> Bitrate params Initial Bitrate: 12.5Mbps Actual Bitrate: 12.5Mbps Max Bitrate: 50.0Mbps Min Bitrate: 1.0Mbps Throttling Bitrate Cap: 50.0Mbps
#6(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&2D19EBA4&<QosManagerTxNati> QosManagerTxNative is successfully initialized for stream 0
#7(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&9A110BCF&<Etwprof>          GRC config for stream 1: Disabled; up: interval 1 frames, width 64; down: interval 1 frames, width 64
#8(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&B52C0AD5&<QosManagerTxNati> Turbo mode is disabled.
#9(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&90EF2499&<QosManagerTxNati> Grabbing maximum fps value: 90 for stream:1
#0(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&9FDC322C&<PerformanceHisto> Config perf history for stream 1: Disabled, iir 60, featureMask 0x0, reset 900000 ms
#1(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&E103DA25&<QosManagerTxNati> QP DRC configuration for stream:1 IIR factor: 20.000000, update cooling time: 3, promotion cooling time: 10, lower threshold: 25.000000, upper threshold: 39.000000, minimum headroom: 2.000000, minimum adaptive threshold: 36.000000, max res adj: 0.000000, codec adj: 0.000000
#2(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&4742AF82&<QosManagerTxNati> QP GRC configuration for stream:1 update cooling time: 0.500000, promotion cooling time: 0.500000, lower threshold: 0.000000, upper threshold: 25.000000, minimum headroom: 39.000000, minimum adaptive threshold: 2.000000, max res adj: 36.000000, codec adj: 0.000000
#3(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&97E7B6E1&<QosManagerTxNati> Video BW QoS [50], max rate [50000000.000000], min rate [1000000.000000] for stream:1
#4(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&F51FA5CE&<QosManagerTxNati> stream:[1] loss threshold [2], Jitter threshold(us) [3000.000000]
#5(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&92FBF5DE&<Etwprof>          QEC feature is enabled with Frame lost thres 0 and Invalid ref thres 0
#6(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&A4D933F3&<QosManagerTxNati> Bitrate params Initial Bitrate: 12.5Mbps Actual Bitrate: 12.5Mbps Max Bitrate: 50.0Mbps Min Bitrate: 1.0Mbps Throttling Bitrate Cap: 50.0Mbps
#7(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&2D19EBA4&<QosManagerTxNati> QosManagerTxNative is successfully initialized for stream 1
#8(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&454DFB2C&<Etwprof>          RL QOS disabled for stream: 0
#9(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&324ACBBA&<Etwprof>          RL QOS disabled for stream: 1
#0(I)[2022-09-09 22:00:46,736]=15:00:46=*00000*{6568}&8A0367E8&<QosSupervisor>    Setting up uplink stats collection with period [60000] ms
#1(I)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&8D361FF7&<NvEncUtil>        Latest supported encoder version: 3
#2(M)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&99EDACA9&<VideoStreamer>    Creating video streamer.
#3(I)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&F12710C9&<VirtualVsyncHand> VirtualVsync[0] disabled.  Feedback mode is NVST_FRAME_PACING_FEEDBACK_NEVER.
#4(I)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&8D361FF7&<NvEncUtil>        Latest supported encoder version: 3
#5(M)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&99EDACA9&<VideoStreamer>    Creating video streamer.
#6(I)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&F12710C9&<VirtualVsyncHand> VirtualVsync[1] disabled.  Feedback mode is NVST_FRAME_PACING_FEEDBACK_NEVER.
#7(M)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&93ACC216&<WacSettings>      NvWac settings: captureStrategy -1, createFlags 0x00000000, appListOverride (empty)
#8(I)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&5AC3104C&<NvscStreamingSes> Setting Stream data processor for remote input stream
#9(I)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&5DF6CB54&<CommandPacket>    NetPacket::setEncryptionKey(Key, KeyLen) keyLength 32
#0(I)[2022-09-09 22:00:46,737]=15:00:46=*00000*{6568}&2A0E569E&<CommandPacket>    AES Key set from raw key, keyLength 32
#1(I)[2022-09-09 22:00:46,738]=15:00:46=*00003*{7208}&3EFB303C&<NvscStreamingSes> Wait was cancelled by eventIndex: 0
#2(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&C76C7AB8&<NvscStreamingSes> Streaming session initialization done.
#3(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&D4F95EB4&<Server>           Server is now in state: ConnectingStreams
#4(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{6568}&0BCCDC2A&<StreamSdkUtils>   Wait complete for: connection creation
#5(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> uiAutoMode: 1
#6(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientInterface.usePreferred: 0
#7(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientPorts.useReserved: 1
#8(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientPorts.fallbackDynamic: 1
#9(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientPorts.session: 0
#0(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientPorts.audio: 0
#1(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientPorts.mic: 0
#2(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientPorts.video: 0
#3(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientPorts.control: 0
#4(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enetControlChannel.channelCount: 3
#5(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enetControlChannel.qosReliabilityType: 1
#6(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enetControlChannel.clientQosTrafficType: 0
#7(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enetControlChannel.maxTxPartiallyReliable: 3
#8(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enetControlChannel.waitWindowPartiallyReliable: 2
#9(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enetControlChannel.mtuSize: 1320
#0(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enetControlChannel.enetReTxAttemptsMax: 11
#1(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enetControlChannel.timeoutMaximumMs: 12000
#2(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enetControlChannel.clientEnetStatsIntervalMs: 10000
#3(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.serverNetwork: 1
#4(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.videoSyncAudioDelayAdjust: 10000
#5(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.startTime: 0
#6(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.featureFlags: 167
#7(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enableInputEventLogging: 0
#8(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.serverCapture: 0
#9(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientCapture: 0
#0(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.rtpQueueMaxPackets: 160
#1(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.rtpQueueMaxDurationMs: 8
#2(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.rtpQueueMaxFrameWaitDurationMs: 65535
#3(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.rtpEnablePacketCounter: 1
#4(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.useReliableUdp: 13
#5(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.customMessageOnCC: 0
#6(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.rtspScheme: 0
#7(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.RtspsClientFeature: 0
#8(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.filterLocalIp: 1
#9(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.videoStreamerCount: 2
#0(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.useHolePunch: 0
#1(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.rtspStunStatus: 0
#2(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.serverNATType: 0
#3(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientNATType: 0
#4(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enableRecoveryMode: 0
#5(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.lightRecoveryMode: 1
#6(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.recoveryModeTriggerThresholdMs: 6000
#7(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.enableIntraRefreshInRecoveryMode: 0
#8(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.controlChannelStatsTransmitIntervalMs: 60000
#9(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.uplinkStatsCollectionIntervalMs: 60000
#0(I)[2022-09-09 22:00:46,738]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.useQosForAudioStats: 1
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.maxQosMessagesSize: 1200
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.ipVersion: 0
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientConnectionType: 0
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientConnectionSubType: 0
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.logSpsHeader: 0
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.pingVersion: 5
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.readTosField: 0
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.clientSupportsIntraRefresh: 1
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.decodeFpsAdjPercent: 95
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.renderFpsAdjPercent: 0
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5D2684BA&<NvscClientConfig> general.groupBlobStatsBufferSizeBytes: 0
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&D0674203&<NvscClientConfig> video[0].perfIndicatorEnabled: 0
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&D0674203&<NvscClientConfig> video[1].perfIndicatorEnabled: 0
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&15A2A24F&<NvscClientConfig> video[0].clientViewportWd: 3072
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&15A2A24F&<NvscClientConfig> video[1].clientViewportWd: 3072
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&87C28583&<NvscClientConfig> video[0].clientViewportHt: 3072
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&87C28583&<NvscClientConfig> video[1].clientViewportHt: 3072
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&CC23D464&<NvscClientConfig> video[0].adapterNumber: 0
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&CC23D464&<NvscClientConfig> video[1].adapterNumber: 0
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&CD034944&<NvscClientConfig> video[0].maxFPS: 90
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&CD034944&<NvscClientConfig> video[1].maxFPS: 90
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&98689F6E&<NvscClientConfig> video[0].maxH264Level: 51
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&98689F6E&<NvscClientConfig> video[1].maxH264Level: 51
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F05C7938&<NvscClientConfig> video[0].maxH264Profile: 3
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F05C7938&<NvscClientConfig> video[1].maxH264Profile: 3
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&8B619CE1&<NvscClientConfig> video[0].streamRecoveryType: 1
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&8B619CE1&<NvscClientConfig> video[1].streamRecoveryType: 1
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A36D4BC7&<NvscClientConfig> video[0].maxNumReferenceFrames: 1
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A36D4BC7&<NvscClientConfig> video[1].maxNumReferenceFrames: 1
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&C39ADD66&<NvscClientConfig> video[0].contextType: 0
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&C39ADD66&<NvscClientConfig> video[1].contextType: 0
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&3405E4F5&<NvscClientConfig> video[0].captureSettings.captureStrategy: 0
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&3405E4F5&<NvscClientConfig> video[1].captureSettings.captureStrategy: 0
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5000A298&<NvscClientConfig> video[0].captureSettings.captureMethod: 0
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5000A298&<NvscClientConfig> video[1].captureSettings.captureMethod: 0
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F3AD2C60&<NvscClientConfig> video[0].captureSettings.sleepMethod: 0
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F3AD2C60&<NvscClientConfig> video[1].captureSettings.sleepMethod: 0
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5EB66944&<NvscClientConfig> video[0].captureSettings.sleepMethodAccuracyUs: 0
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&5EB66944&<NvscClientConfig> video[1].captureSettings.sleepMethodAccuracyUs: 0
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&B794D55E&<NvscClientConfig> video[0].captureSettings.waitMethod: 0
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&B794D55E&<NvscClientConfig> video[1].captureSettings.waitMethod: 0
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A3B4C25C&<NvscClientConfig> video[0].captureSettings.waitMethodTimeoutMs: 15
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A3B4C25C&<NvscClientConfig> video[1].captureSettings.waitMethodTimeoutMs: 15
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&2E47B158&<NvscClientConfig> video[0].transferProtocol: 1
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&2E47B158&<NvscClientConfig> video[1].transferProtocol: 1
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0D6FAA97&<NvscClientConfig> video[0].rateControlMode: 4
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0D6FAA97&<NvscClientConfig> video[1].rateControlMode: 4
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&763452EC&<NvscClientConfig> video[0].encoderFeatureSetting: 142
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&763452EC&<NvscClientConfig> video[1].encoderFeatureSetting: 142
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A73573AB&<NvscClientConfig> video[0].encoderPreset: 6
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A73573AB&<NvscClientConfig> video[1].encoderPreset: 6
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0572CED0&<NvscClientConfig> video[0].initialQp: 35
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0572CED0&<NvscClientConfig> video[1].initialQp: 35
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F8EF13BD&<NvscClientConfig> video[0].minQp: 15
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F8EF13BD&<NvscClientConfig> video[1].minQp: 15
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&656DA24F&<NvscClientConfig> video[0].lowQpBitrateKbps: 5000
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&656DA24F&<NvscClientConfig> video[1].lowQpBitrateKbps: 5000
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0363F6CE&<NvscClientConfig> video[0].videoBitrateIirFactor: 18
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0363F6CE&<NvscClientConfig> video[1].videoBitrateIirFactor: 18
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&337A2FF5&<NvscClientConfig> video[0].initialBitrateKbps: 12500
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&337A2FF5&<NvscClientConfig> video[1].initialBitrateKbps: 12500
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&B56953EF&<NvscClientConfig> video[0].initialPeakBitrateKbps: 12500
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&B56953EF&<NvscClientConfig> video[1].initialPeakBitrateKbps: 12500
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&EA0FDCD9&<NvscClientConfig> video[0].vbvMultiplier: 105
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&EA0FDCD9&<NvscClientConfig> video[1].vbvMultiplier: 105
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&818E0332&<NvscClientConfig> video[0].keyFrameScale: 4
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&818E0332&<NvscClientConfig> video[1].keyFrameScale: 4
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&4ABB53FF&<NvscClientConfig> video[0].fakeEncodeFps: 60
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&4ABB53FF&<NvscClientConfig> video[1].fakeEncodeFps: 60
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&2CF6AFF3&<NvscClientConfig> video[0].numTemporalLayers: 0
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&2CF6AFF3&<NvscClientConfig> video[1].numTemporalLayers: 0
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&D67919DF&<NvscClientConfig> video[0].packetSize: 1408
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&D67919DF&<NvscClientConfig> video[1].packetSize: 1408
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0BFFAB26&<NvscClientConfig> video[0].refPicInvalidation: 1
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0BFFAB26&<NvscClientConfig> video[1].refPicInvalidation: 1
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&D87B4E8C&<NvscClientConfig> video[0].pingBackIntervalMs: 3000
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&D87B4E8C&<NvscClientConfig> video[1].pingBackIntervalMs: 3000
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&94018605&<NvscClientConfig> video[0].pingBackTimeoutMs: 10000
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&94018605&<NvscClientConfig> video[1].pingBackTimeoutMs: 10000
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&6EB1870C&<NvscClientConfig> video[0].timeoutLengthMs: 8000
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&6EB1870C&<NvscClientConfig> video[1].timeoutLengthMs: 8000
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&D53465F2&<NvscClientConfig> video[0].fullFrameAssembly: 1
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&D53465F2&<NvscClientConfig> video[1].fullFrameAssembly: 1
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&76BAFE6A&<NvscClientConfig> video[0].enableIntraRefresh: 0
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&76BAFE6A&<NvscClientConfig> video[1].enableIntraRefresh: 0
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&11C84333&<NvscClientConfig> video[0].enableLongTermReferences: 0
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&11C84333&<NvscClientConfig> video[1].enableLongTermReferences: 0
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&E96800E3&<NvscClientConfig> video[0].framesWithInvalidRefThreshold: 0
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&E96800E3&<NvscClientConfig> video[1].framesWithInvalidRefThreshold: 0
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A0ABC442&<NvscClientConfig> video[0].consecutiveFrameLostThreshold: 0
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A0ABC442&<NvscClientConfig> video[1].consecutiveFrameLostThreshold: 0
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A3359B9B&<NvscClientConfig> video[0].videoEncoderDeblockingMode: 0
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A3359B9B&<NvscClientConfig> video[1].videoEncoderDeblockingMode: 0
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&89094154&<NvscClientConfig> video[0].videoEncoderSlicesPerFrame: 1
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&89094154&<NvscClientConfig> video[1].videoEncoderSlicesPerFrame: 1
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&1532BA4B&<NvscClientConfig> video[0].dynamicRangeMode: 0
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&1532BA4B&<NvscClientConfig> video[1].dynamicRangeMode: 0
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&BA113E7E&<NvscClientConfig> video[0].fbcDynamicFpsGrabTimeoutMs: 25
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&BA113E7E&<NvscClientConfig> video[1].fbcDynamicFpsGrabTimeoutMs: 25
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&376B21A9&<NvscClientConfig> video[0].enableVrStreamingMode: 0
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&376B21A9&<NvscClientConfig> video[1].enableVrStreamingMode: 0
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&208DFD9F&<NvscClientConfig> video[0].surfaceFormat: 0
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&208DFD9F&<NvscClientConfig> video[1].surfaceFormat: 0
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F3B6B8B1&<NvscClientConfig> video[0].framePacing.enableExtraDebugLogging: 0
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F3B6B8B1&<NvscClientConfig> video[1].framePacing.enableExtraDebugLogging: 0
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0D5AD62F&<NvscClientConfig> video[0].framePacing.feedbackMode: 0
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&0D5AD62F&<NvscClientConfig> video[1].framePacing.feedbackMode: 0
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&CE6CB50B&<NvscClientConfig> video[0].framePacing.feedbackTimeoutMs: 100
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&CE6CB50B&<NvscClientConfig> video[1].framePacing.feedbackTimeoutMs: 100
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&156C3AEB&<NvscClientConfig> video[0].framePacing.queueSmoothingHistoryN: 3
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&156C3AEB&<NvscClientConfig> video[1].framePacing.queueSmoothingHistoryN: 3
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F73EC21A&<NvscClientConfig> video[0].framePacing.queueHistoryOutlierUs: 75000
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F73EC21A&<NvscClientConfig> video[1].framePacing.queueHistoryOutlierUs: 75000
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&4DC0004C&<NvscClientConfig> video[0].framePacing.frameDropThresholdMultipleX1000: 1333
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&4DC0004C&<NvscClientConfig> video[1].framePacing.frameDropThresholdMultipleX1000: 1333
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&239B17C2&<NvscClientConfig> video[0].framePacing.deactivationThresholdFpsX1000: 50
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&239B17C2&<NvscClientConfig> video[1].framePacing.deactivationThresholdFpsX1000: 50
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&FE055F86&<NvscClientConfig> video[0].framePacing.streamingFpsSmoothingHistoryLength: 120
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&FE055F86&<NvscClientConfig> video[1].framePacing.streamingFpsSmoothingHistoryLength: 120
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&87A558F0&<NvscClientConfig> video[0].framePacing.activationDelayMs: 4000
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&87A558F0&<NvscClientConfig> video[1].framePacing.activationDelayMs: 4000
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&3B7693DD&<NvscClientConfig> video[0].framePacing.deactivationDelayMs: 2000
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&3B7693DD&<NvscClientConfig> video[1].framePacing.deactivationDelayMs: 2000
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&AD5A6734&<NvscClientConfig> video[0].framePacing.jitterHistory.jitterEstimationMode: 0
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&AD5A6734&<NvscClientConfig> video[1].framePacing.jitterHistory.jitterEstimationMode: 0
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A332EBE9&<NvscClientConfig> video[0].framePacing.jitterHistory.n: 3600
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A332EBE9&<NvscClientConfig> video[1].framePacing.jitterHistory.n: 3600
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&347D964B&<NvscClientConfig> video[0].framePacing.jitterHistory.stddevsX1000: 3000
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&347D964B&<NvscClientConfig> video[1].framePacing.jitterHistory.stddevsX1000: 3000
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F3CADAC7&<NvscClientConfig> video[0].framePacing.jitterHistory.quantileX1000: 997
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F3CADAC7&<NvscClientConfig> video[1].framePacing.jitterHistory.quantileX1000: 997
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&7CFB9AAC&<NvscClientConfig> video[0].framePacing.jitterHistory.quantileConvergenceX10000: 20
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&7CFB9AAC&<NvscClientConfig> video[1].framePacing.jitterHistory.quantileConvergenceX10000: 20
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&C4284C23&<NvscClientConfig> video[0].framePacing.jitterHistory.quantileWindowSize: 0
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&C4284C23&<NvscClientConfig> video[1].framePacing.jitterHistory.quantileWindowSize: 0
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&98A11991&<NvscClientConfig> video[0].framePacing.jitterHistory.quantileWindowStep: 0
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&98A11991&<NvscClientConfig> video[1].framePacing.jitterHistory.quantileWindowStep: 0
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A37A0024&<NvscClientConfig> video[0].framePacing.jitterHistory.maxAdvanceUs: 40000
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A37A0024&<NvscClientConfig> video[1].framePacing.jitterHistory.maxAdvanceUs: 40000
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F283BB79&<NvscClientConfig> video[0].framePacing.jitterHistory.minAdvanceUs: 4000
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&F283BB79&<NvscClientConfig> video[1].framePacing.jitterHistory.minAdvanceUs: 4000
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&46F383B4&<NvscClientConfig> video[0].framePacing.jitterHistory.outlierUs: 75000
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&46F383B4&<NvscClientConfig> video[1].framePacing.jitterHistory.outlierUs: 75000
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&EA74BB47&<NvscClientConfig> video[0].framePacing.renderHistory.renderEstimationMode: 0
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&EA74BB47&<NvscClientConfig> video[1].framePacing.renderHistory.renderEstimationMode: 0
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&6672CCD6&<NvscClientConfig> video[0].framePacing.renderHistory.n: 60
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&6672CCD6&<NvscClientConfig> video[1].framePacing.renderHistory.n: 60
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&51492286&<NvscClientConfig> video[0].framePacing.renderHistory.maxTimeUs: 8000
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&51492286&<NvscClientConfig> video[1].framePacing.renderHistory.maxTimeUs: 8000
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&11065AF0&<NvscClientConfig> video[0].framePacing.renderHistory.minTimeUs: 6000
#1(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&11065AF0&<NvscClientConfig> video[1].framePacing.renderHistory.minTimeUs: 6000
#2(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&CEBA7B6C&<NvscClientConfig> video[0].framePacing.renderHistory.stddevsX1000: 3000
#3(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&CEBA7B6C&<NvscClientConfig> video[1].framePacing.renderHistory.stddevsX1000: 3000
#4(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&563AA841&<NvscClientConfig> video[0].framePacing.renderHistory.quantileX1000: 997
#5(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&563AA841&<NvscClientConfig> video[1].framePacing.renderHistory.quantileX1000: 997
#6(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&EB30F0A4&<NvscClientConfig> video[0].framePacing.renderHistory.quantileConvergenceX10000: 20
#7(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&EB30F0A4&<NvscClientConfig> video[1].framePacing.renderHistory.quantileConvergenceX10000: 20
#8(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A50DCA3C&<NvscClientConfig> video[0].framePacing.pid.kP: 100
#9(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&A50DCA3C&<NvscClientConfig> video[1].framePacing.pid.kP: 100
#0(I)[2022-09-09 22:00:46,739]=15:00:46=*00000*{7208}&C8FD3FCF&<NvscClientConfig> video[0].framePacing.pid.kI: 3
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&C8FD3FCF&<NvscClientConfig> video[1].framePacing.pid.kI: 3
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&001DB0BF&<NvscClientConfig> video[0].framePacing.pid.kL: 10
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&001DB0BF&<NvscClientConfig> video[1].framePacing.pid.kL: 10
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&47408458&<NvscClientConfig> video[0].framePacing.pid.targetFrameTimeUs: 16666
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&47408458&<NvscClientConfig> video[1].framePacing.pid.targetFrameTimeUs: 16666
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E1D27A30&<NvscClientConfig> video[0].framePacing.pid.minTargetFrameTimeUs: 16665
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E1D27A30&<NvscClientConfig> video[1].framePacing.pid.minTargetFrameTimeUs: 16665
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&3A6D29D7&<NvscClientConfig> video[0].framePacing.pid.maxTargetFrameTimeUs: 16684
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&3A6D29D7&<NvscClientConfig> video[1].framePacing.pid.maxTargetFrameTimeUs: 16684
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&D8816FD2&<NvscClientConfig> video[0].framePacing.pid.allowedDeviation: 10
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&D8816FD2&<NvscClientConfig> video[1].framePacing.pid.allowedDeviation: 10
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&37434F59&<NvscClientConfig> video[0].framePacing.pid.targetQueueTimeUs: 0
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&37434F59&<NvscClientConfig> video[1].framePacing.pid.targetQueueTimeUs: 0
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&2F1DFA75&<NvscClientConfig> video[0].encoderCscMode: 3
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&2F1DFA75&<NvscClientConfig> video[1].encoderCscMode: 3
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&A89E1750&<NvscClientConfig> video[0].rfd.enabled: 0
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&A89E1750&<NvscClientConfig> video[1].rfd.enabled: 0
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&84206F4E&<NvscClientConfig> video[0].rfd.numFrames: 120
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&84206F4E&<NvscClientConfig> video[1].rfd.numFrames: 120
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5CE88982&<NvscClientConfig> video[0].efd.disabled: 1
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5CE88982&<NvscClientConfig> video[1].efd.disabled: 1
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&6394597D&<NvscClientConfig> video[0].fd.enabled: 0
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&6394597D&<NvscClientConfig> video[1].fd.enabled: 0
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&C8BFD684&<NvscClientConfig> video[0].fd.memoryUsage: 500
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&C8BFD684&<NvscClientConfig> video[1].fd.memoryUsage: 500
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&77768B2D&<NvscClientConfig> video[0].fd.capturePeriod: 10
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&77768B2D&<NvscClientConfig> video[1].fd.capturePeriod: 10
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&2E892395&<NvscClientConfig> video[0].fd.downsampleFactor: 1
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&2E892395&<NvscClientConfig> video[1].fd.downsampleFactor: 1
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&82509701&<NvscClientConfig> video[0].enableFbcDiffMap: 0
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&82509701&<NvscClientConfig> video[1].enableFbcDiffMap: 0
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&13A9E65B&<NvscClientConfig> video[0].disableFrameScaling: 1
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&13A9E65B&<NvscClientConfig> video[1].disableFrameScaling: 1
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&F8A9B6C6&<NvscClientConfig> video[0].dx9EnableNv12: 0
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&F8A9B6C6&<NvscClientConfig> video[1].dx9EnableNv12: 0
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5A743546&<NvscClientConfig> video[0].enableNextCaptureMode: 0
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5A743546&<NvscClientConfig> video[1].enableNextCaptureMode: 0
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&047560AE&<NvscClientConfig> video[0].sendFrameTimeoutMs: 7000
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&047560AE&<NvscClientConfig> video[1].sendFrameTimeoutMs: 7000
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&7829C580&<NvscClientConfig> video[0].sendFirstFrameTimeoutMs: 50000
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&7829C580&<NvscClientConfig> video[1].sendFirstFrameTimeoutMs: 50000
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&86256928&<NvscClientConfig> video[0].senderDequeueTimeoutMs: 500
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&86256928&<NvscClientConfig> video[1].senderDequeueTimeoutMs: 500
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&0794EBC4&<NvscClientConfig> video[0].enableTimestampRender: 1
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&0794EBC4&<NvscClientConfig> video[1].enableTimestampRender: 1
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&12B2DC00&<NvscClientConfig> video[0].enableAdaptiveQRender: 1
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&12B2DC00&<NvscClientConfig> video[1].enableAdaptiveQRender: 1
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&6C22755E&<NvscClientConfig> video[0].enableRtpNack: 0
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&6C22755E&<NvscClientConfig> video[1].enableRtpNack: 0
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&6C839BD6&<NvscClientConfig> video[0].rtpNackBackoffTimeMs: 1
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&6C839BD6&<NvscClientConfig> video[1].rtpNackBackoffTimeMs: 1
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&EFE65B40&<NvscClientConfig> video[0].rtpNackInitialWaitTimeMs: 1
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&EFE65B40&<NvscClientConfig> video[1].rtpNackInitialWaitTimeMs: 1
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&148723DE&<NvscClientConfig> video[0].rtpNackMaxPacketCount: 15
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&148723DE&<NvscClientConfig> video[1].rtpNackMaxPacketCount: 15
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5EFAFAEF&<NvscClientConfig> video[0].rtpNackQueueLength: 512
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5EFAFAEF&<NvscClientConfig> video[1].rtpNackQueueLength: 512
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&24AFD9BA&<NvscClientConfig> video[0].enableADJB: 0
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&24AFD9BA&<NvscClientConfig> video[1].enableADJB: 0
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&8FE598DB&<NvscClientConfig> video[0].adjbMinLengthMs: 0
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&8FE598DB&<NvscClientConfig> video[1].adjbMinLengthMs: 0
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&A85EFFEA&<NvscClientConfig> video[0].adjbMaxLengthMs: 32
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&A85EFFEA&<NvscClientConfig> video[1].adjbMaxLengthMs: 32
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&EAF4EF2B&<NvscClientConfig> video[0].adjbQuantile: 900
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&EAF4EF2B&<NvscClientConfig> video[1].adjbQuantile: 900
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&D48A055F&<NvscClientConfig> video[0].adjbQuantileConvergenceFactor: 9
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&D48A055F&<NvscClientConfig> video[1].adjbQuantileConvergenceFactor: 9
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&8BB321C3&<NvscClientConfig> video[0].dejitterBufferLengthMs: 52
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&8BB321C3&<NvscClientConfig> video[1].dejitterBufferLengthMs: 52
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&70D5845D&<NvscClientConfig> video[0].nackDjbLengthMultiplyFactorx100: 100
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&70D5845D&<NvscClientConfig> video[1].nackDjbLengthMultiplyFactorx100: 100
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&C180CADE&<NvscClientConfig> video[0].nackHysteresisLengthUs: 4
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&C180CADE&<NvscClientConfig> video[1].nackHysteresisLengthUs: 4
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&16C15667&<NvscClientConfig> video[0].rtpNackQueueMaxPackets: 256
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&16C15667&<NvscClientConfig> video[1].rtpNackQueueMaxPackets: 256
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&B1B493FF&<NvscClientConfig> video[0].rtpNackDjbInteractionMode: 0
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&B1B493FF&<NvscClientConfig> video[1].rtpNackDjbInteractionMode: 0
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&DA87B67D&<NvscClientConfig> video[0].packetSizeDetection.enable: 1
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&DA87B67D&<NvscClientConfig> video[1].packetSizeDetection.enable: 1
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&BE7B36BE&<NvscClientConfig> video[0].packetSizeDetection.minNumFrames: 60
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&BE7B36BE&<NvscClientConfig> video[1].packetSizeDetection.minNumFrames: 60
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E7D4E11A&<NvscClientConfig> video[0].packetSizeDetection.packetLossRate: 50
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E7D4E11A&<NvscClientConfig> video[1].packetSizeDetection.packetLossRate: 50
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&06BE85AF&<NvscClientConfig> video[0].dynamicPacketSize.enable: 0
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&06BE85AF&<NvscClientConfig> video[1].dynamicPacketSize.enable: 0
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&3F7C3931&<NvscClientConfig> video[0].dynamicPacketSize.frameSizeL0ThresholdBytes: 15000
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&3F7C3931&<NvscClientConfig> video[1].dynamicPacketSize.frameSizeL0ThresholdBytes: 15000
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&2C8C9E81&<NvscClientConfig> video[0].dynamicPacketSize.packetSizeL0: 1024
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&2C8C9E81&<NvscClientConfig> video[1].dynamicPacketSize.packetSizeL0: 1024
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E89EB969&<NvscClientConfig> video[0].dynamicPacketSize.frameSizeL1ThresholdBytes: 30000
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E89EB969&<NvscClientConfig> video[1].dynamicPacketSize.frameSizeL1ThresholdBytes: 30000
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&11ECB731&<NvscClientConfig> video[0].dynamicPacketSize.packetSizeL1: 1280
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&11ECB731&<NvscClientConfig> video[1].dynamicPacketSize.packetSizeL1: 1280
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&D4100FA4&<NvscClientConfig> vqos[0].bw.flags: 1
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&D4100FA4&<NvscClientConfig> vqos[1].bw.flags: 1
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&055E6B38&<NvscClientConfig> vqos[0].bw.maximumBitrateKbps: 50000
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&055E6B38&<NvscClientConfig> vqos[1].bw.maximumBitrateKbps: 50000
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&9AEA9CBB&<NvscClientConfig> vqos[0].bw.maximumBitrateKbpsMetaParams.min: 0
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&9AEA9CBB&<NvscClientConfig> vqos[1].bw.maximumBitrateKbpsMetaParams.min: 0
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&99197CF4&<NvscClientConfig> vqos[0].bw.maximumBitrateKbpsMetaParams.max: 100000
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&99197CF4&<NvscClientConfig> vqos[1].bw.maximumBitrateKbpsMetaParams.max: 100000
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&444954BE&<NvscClientConfig> vqos[0].bw.minimumBitrateKbps: 1000
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&444954BE&<NvscClientConfig> vqos[1].bw.minimumBitrateKbps: 1000
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&AE14C2A9&<NvscClientConfig> vqos[0].bw.minimumBitrateKbpsMetaParams.min: 0
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&AE14C2A9&<NvscClientConfig> vqos[1].bw.minimumBitrateKbpsMetaParams.min: 0
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&ADE722E6&<NvscClientConfig> vqos[0].bw.minimumBitrateKbpsMetaParams.max: 100000
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&ADE722E6&<NvscClientConfig> vqos[1].bw.minimumBitrateKbpsMetaParams.max: 100000
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&A6D65BDC&<NvscClientConfig> vqos[0].bw.minimumEncoderBitrateKbps: 650
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&A6D65BDC&<NvscClientConfig> vqos[1].bw.minimumEncoderBitrateKbps: 650
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&85C55B13&<NvscClientConfig> vqos[0].bw.minimumEncoderBitrateKbpsMetaParams.min: 0
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&85C55B13&<NvscClientConfig> vqos[1].bw.minimumEncoderBitrateKbpsMetaParams.min: 0
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&8636BB5C&<NvscClientConfig> vqos[0].bw.minimumEncoderBitrateKbpsMetaParams.max: 100000
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&8636BB5C&<NvscClientConfig> vqos[1].bw.minimumEncoderBitrateKbpsMetaParams.max: 100000
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&83A6AEDE&<NvscClientConfig> vqos[0].bw.statsTime: 50
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&83A6AEDE&<NvscClientConfig> vqos[1].bw.statsTime: 50
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&4AD71C18&<NvscClientConfig> vqos[0].bw.lossThreshold: 2
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&4AD71C18&<NvscClientConfig> vqos[1].bw.lossThreshold: 2
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&02DD1068&<NvscClientConfig> vqos[0].bw.jitterThresholdUs: 3000
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&02DD1068&<NvscClientConfig> vqos[1].bw.jitterThresholdUs: 3000
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&98C07072&<NvscClientConfig> vqos[0].bw.maxBitrateScalePercent: 100
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&98C07072&<NvscClientConfig> vqos[1].bw.maxBitrateScalePercent: 100
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&CDC745F9&<NvscClientConfig> vqos[0].bw.maxBitrateScalePercentMetaParams.min: 0
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&CDC745F9&<NvscClientConfig> vqos[1].bw.maxBitrateScalePercentMetaParams.min: 0
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&CE34A5B6&<NvscClientConfig> vqos[0].bw.maxBitrateScalePercentMetaParams.max: 150
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&CE34A5B6&<NvscClientConfig> vqos[1].bw.maxBitrateScalePercentMetaParams.max: 150
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E36BE354&<NvscClientConfig> vqos[0].bw.checkBwThrottlingIntervalMs: 30000
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E36BE354&<NvscClientConfig> vqos[1].bw.checkBwThrottlingIntervalMs: 30000
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5BC82A86&<NvscClientConfig> vqos[0].bw.bwThrottlingThresholdPercent: 80
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5BC82A86&<NvscClientConfig> vqos[1].bw.bwThrottlingThresholdPercent: 80
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&CC521B71&<NvscClientConfig> vqos[0].bw.minThrottlingCoolingTime: 0
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&CC521B71&<NvscClientConfig> vqos[1].bw.minThrottlingCoolingTime: 0
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&2F9EC671&<NvscClientConfig> vqos[0].bw.throttlingBitrateCapIncreasePercent: 1
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&2F9EC671&<NvscClientConfig> vqos[1].bw.throttlingBitrateCapIncreasePercent: 1
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&769460B8&<NvscClientConfig> vqos[0].bw.rtpStatsTime: 3600
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&769460B8&<NvscClientConfig> vqos[1].bw.rtpStatsTime: 3600
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&51EBA7EA&<NvscClientConfig> vqos[0].bw.maxBitrateScalePercentL1: 100
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&51EBA7EA&<NvscClientConfig> vqos[1].bw.maxBitrateScalePercentL1: 100
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&164BDD3A&<NvscClientConfig> vqos[0].bw.maxBitrateScalePercentL2: 100
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&164BDD3A&<NvscClientConfig> vqos[1].bw.maxBitrateScalePercentL2: 100
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&B0A133AF&<NvscClientConfig> vqos[0].bw.txRxLag.moduleVersion: 1
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&B0A133AF&<NvscClientConfig> vqos[1].bw.txRxLag.moduleVersion: 1
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&760CEBF8&<NvscClientConfig> vqos[0].bw.txRxLag.maxIncreaseThreshold: 20
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&760CEBF8&<NvscClientConfig> vqos[1].bw.txRxLag.maxIncreaseThreshold: 20
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&1B19D278&<NvscClientConfig> vqos[0].bw.txRxLag.minFeedbackTxDeltaMs: 150
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&1B19D278&<NvscClientConfig> vqos[1].bw.txRxLag.minFeedbackTxDeltaMs: 150
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&EBB91E4B&<NvscClientConfig> vqos[0].bw.txRxLag.countLowFbFrameDelta: 0
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&EBB91E4B&<NvscClientConfig> vqos[1].bw.txRxLag.countLowFbFrameDelta: 0
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&BAF07C61&<NvscClientConfig> vqos[0].bw.txRxLag.maxFeedbackSilenceMs: 500
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&BAF07C61&<NvscClientConfig> vqos[1].bw.txRxLag.maxFeedbackSilenceMs: 500
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&13394861&<NvscClientConfig> vqos[0].bn.notifyUpBoundThreshold: 40
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&13394861&<NvscClientConfig> vqos[1].bn.notifyUpBoundThreshold: 40
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&34362EE4&<NvscClientConfig> vqos[0].resControl.resControlType: 1
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&34362EE4&<NvscClientConfig> vqos[1].resControl.resControlType: 1
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&96C884F5&<NvscClientConfig> vqos[0].resControl.transControlType: 1
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&96C884F5&<NvscClientConfig> vqos[1].resControl.transControlType: 1
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&1DF04EE1&<NvscClientConfig> vqos[0].resControl.tableType: 1
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&1DF04EE1&<NvscClientConfig> vqos[1].resControl.tableType: 1
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&8B141F15&<NvscClientConfig> vqos[0].resControl.bitrateIirFilterFactor: 128
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&8B141F15&<NvscClientConfig> vqos[1].resControl.bitrateIirFilterFactor: 128
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&0A8D407D&<NvscClientConfig> vqos[0].resControl.updateCoolingTimeMs: 3000
#1(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&0A8D407D&<NvscClientConfig> vqos[1].resControl.updateCoolingTimeMs: 3000
#2(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&DB6B4677&<NvscClientConfig> vqos[0].resControl.downLevels: 1
#3(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&DB6B4677&<NvscClientConfig> vqos[1].resControl.downLevels: 1
#4(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5736EAC9&<NvscClientConfig> vqos[0].resControl.upLevels: 1
#5(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&5736EAC9&<NvscClientConfig> vqos[1].resControl.upLevels: 1
#6(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&CE1530A5&<NvscClientConfig> vqos[0].resControl.lowEncoderUtilizationThreshold: 20
#7(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&CE1530A5&<NvscClientConfig> vqos[1].resControl.lowEncoderUtilizationThreshold: 20
#8(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E2097D04&<NvscClientConfig> vqos[0].resControl.minRequiredBitrateCheckEnabled: 0
#9(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&E2097D04&<NvscClientConfig> vqos[1].resControl.minRequiredBitrateCheckEnabled: 0
#0(I)[2022-09-09 22:00:46,740]=15:00:46=*00000*{7208}&1957CD20&<NvscClientConfig> vqos[0].resControl.stepDownResolutionAlignment: 0
#1(I)[2022-09-09 22:00:46,741]=15:00:46=*00000*{7208}&1957CD20&<NvscClientConfig> vqos[1].resControl.stepDownResolutionAlignment: 0
#2(I)[2022-09-09 22:00:46,741]=15:00:46=*00000*{7208}&52AE9B93&<NvscClientConfig> vqos[0].resControl.stepDownMinHeight: 0
#3(I)[2022-09-09 22:00:46,741]=15:00:46=*00000*{7208}&52AE9B93&<NvscClientConfig> vqos[1].resControl.stepDownMinHeight: 0
#4(I)[2022-09-09 22:00:46,741]=15:00:46=*00000*{7208}&91DE8983&<NvscClientConfig> vqos[0].resControl.stepDownTarget
apologies for the delay to respond. big backlog of support Qs with engineering focused on, well, engineering! :)
@wcannady should loop in with you, we may need some server info dump to try and see what’s up. I don’t know if it’s OS, hardware config, driver config. Yes, clearly something in there is very confused. I’m shocked you are getting one eye – only thing that says to me is maybe the NVENC driver is deciding the board can only do single encode (which I don’t think we support, we want multiple encodes in parallel). Again, that could be driver, board misidentification, or something else about the particular server config since you say it’s this one in particular. I’ll let you guys take it offline, see if we can gather enough information from you so the right engineers have enough to evaluate and determine the core issue (or at least get us in the ballpark…).
Thanks, @tegradave . I have since ended my role and started at a new company, where I’m no longer involved with CloudXR work directly. Appreciate your reply.
Thanks for letting me know.
I’ll leave the thread open for the moment, in case somebody else out there reproduces same/similar issue, we’ve already got the start of a discussion.
I seem to be having the same problem right now, I’m currently testing a CloudXR connection and I’m having issues with the servers - three servers in total, all running on Windows 10. Encountered a problem that could not be decoded
Format ID 101 isn't supported by encoder
Format ID 102 isn't supported by encoder
Format ID 103 isn't supported by encoder
Format ID 104 isn't supported by encoder
Format ID 105 isn't supported by encoder
Format ID 111 isn't supported by encoder
Format ID 112 isn't supported by encoder
Format ID 113 isn't supported by encoder
Format ID 114 isn't supported by encoder
Format ID 115 isn't supported by encoder
We’d want to see a full server log to better understand what is happening. Are these bare-metal machines, or cloud, or local but hypervisor managed?
If you attach a server log and quickly define machine setup, we can take a quick look.
