Hi, new to CloudXR, I am blocked at the beginning without being able to connect to the server (steamVR is waiting for headset to be pluged-in and never see cloudxr icons on the server side (logs from 18.29.50). If I run TestServer.exe on the VM and then launch the client app I get a client disconnected (logs from 18.34.35)
My setup:
-connecting to a VM through VMWare Horizon Client, where I had steamVR and CloudXR Server successfully installed.
-using the client for windows with an htc vive.
I suspect I have network issues, I just do not realize what’s the real problem.
I checked version of client/server as suggested in thread: CloudXR - some computers give extended black screen?, but everything seems ok, running v3.1.1.1 on both sides
I also tried opening port 48010 (mentioned in log)
Any ideas on how to make it work?
CloudXR Client Log 2022-03-23 18.29.50.txt (1.8 KB)
Streamer Client Log 2022-03-23 18.29.50.txt (12.4 KB)
CloudXR Client Log 2022-03-23 18.34.35.txt (985 Bytes)
Streamer Client Log 2022-03-23 18.34.35.txt (13.6 KB)
