We are currently working with the Hololens2 headset and the CloudXR 2.1 client. I was able to successfully stream content from my local PC to the Hololens over my wifi network that is also connected to the internet. However, there are serious issues with latency as the wifi network is quite busy. I then tried to stream content using CloudXR over a dedicated Wifi6 router that is not connected to the internet. I hoped that the uncluttered network would provide better latency results. However, I found that the client would not connect with the server. I suspect that this is because it is not connected to the internet. Is it necessary to be connected to the internet for the client to connect with server? Is there a way to test functionality over a local network?
Related topics
| Can someone assist me with setting up CloudXR for same network with server behind a router? | 0 | 161 | June 24, 2024 | |
| CloudXR in the closed private network | 0 | 478 | July 28, 2022 | |
| Documentation on CloudXR over WiFi | 6 | 803 | June 12, 2021 | |
| CloudXR - Can you connect via 5g outside local network | 3 | 804 | January 27, 2022 | |
| Unable to get CloudXR to work between 2 PCs using Vive Elite XR HMD | 2 | 191 | June 27, 2024 | |
| Extreme latency when using CloudXR on AWS | 0 | 55 | August 16, 2024 | |
| Unofficial Debug Guides 1: Does my CloudXR server even work? | 8 | 725 | October 23, 2024 | |
| Extreme latency | 13 | 1768 | May 25, 2021 | |
| CloudXR Server behind load balancer | 0 | 556 | August 7, 2023 | |
| Network Recommendations for Multiple CloudXR HMDs | 4 | 125 | July 18, 2024 |
