I wanted to build optix-toolkit for use in Optix-Apps but I am getting an cmake error shown below
CMake Error at D:/dev_packages/vcpkg/scripts/buildsystems/vcpkg.cmake:632 (_add_library):
_add_library cannot create ALIAS target "OpenEXR::Config" because another
target with the same name already exists.
Call Stack (most recent call first):
build/_deps/openexr-src/cmake/CMakeLists.txt:166 (add_library)
build/_deps/openexr-src/cmake/CMakeLists.txt:177 (add_library)
I just ran this command after cloning - cmake -DOptiX_INSTALL_DIR=/path-to-optix/ where the path to optix SDK is specified
When I try to build openexr separately, it does buildwithout any issues. Am I missing something here? It would be helpful if I can clear this issue.
