Hi, I’m building on top of the rtx_lidar.py standalone example and want to collect the point cloud from the entire 360-degree scan. My LiDAR configuration is OS0_128ch10hz512res.json. Here is what I tried:
isaac_read_lidar_point_cloud_node returns says that Prim is not a lidar when I try to connect it to the /sensor (although the ‘Sensor type’ property is ‘lidar’).
assuming that the frequency of my sensor is 10Hz and I want to collect 10 scans that add up to 360 degrees, I tried to collect it manually, having:
and later dump the array into a file. However, this results in a sequence of scans that are very similar and appear to come from a single azimuth range. Or produces a full scan with some parts missing as in the lower left of the image below:
Could you help to understand why the above doesn’t work and point me to some best practices for collecting the LiDAR data if any?
Hi. Running the code with the latest 2023-1-0.hotfix.1 and the RtxSensorCpuIsaacCreateRTXLidarScanBuffer annotator, I get the following:
Regions to the sides should not be empty:
I tried running the code of the rtx_lidar.py modified to use annotator for 2023-1-0.hotfix:
assets_root_path = nucleus.get_assets_root_path()
if assets_root_path is None:
carb.log_error("Could not find Isaac Sim assets folder")
simulation_app.close()
sys.exit()
simulation_app.update()
# Loading the simple_room environment
stage.add_reference_to_stage(
assets_root_path + "/Isaac/Environments/Simple_Warehouse/full_warehouse.usd",
"/background",
lidar_config = "Example_Rotary"
if len(sys.argv) == 2:
lidar_config = sys.argv[1]
# Create the lidar sensor that generates data into "RtxSensorCpu"
# Sensor needs to be rotated 90 degrees about X so that its Z up
# Possible options are Example_Rotary and Example_Solid_State
# drive sim applies 0.5,-0.5,-0.5,w(-0.5), we have to apply the reverse
_, sensor = omni.kit.commands.execute(
"IsaacSensorCreateRtxLidar",
path="/sensor",
parent=None,
config=lidar_config,
translation=(0, 0, 1.0),
orientation=Gf.Quatd(0.5, 0.5, -0.5, -0.5), # Gf.Quatd is w,i,j,k
_, render_product_path = create_hydra_texture([1, 1], sensor.GetPath().pathString)
# Create the debug draw pipeline in the post process graph
writer = rep.writers.get("RtxLidar" + "DebugDrawPointCloud")
writer.attach([render_product_path])
simulation_context = SimulationContext(
physics_dt=1.0 / 60.0, rendering_dt=1.0 / 60.0, stage_units_in_meters=1.0
simulation_context.play()
import omni.graph.core as og
annotator = rep.AnnotatorRegistry.get_annotator(
"RtxSensorCpuIsaacCreateRTXLidarScanBuffer"
annotator.initialize(outputTimestamp=True)
annotator.attach([render_product_path])
while simulation_app.is_running():
pointCloudData = annotator.get_data()['data']
In 2022-2-1 I’m able to collect the full scan by querying the RtxSensorCpuIsaacComputeRTXLidarPointCloud node. The original issue is resolved for this case:
A likely cause was a bug in the custom postprocessing code.
However, the annotator approach in 2023-1-0-hotfix from the previous reply still produces:
which is a densified point cloud obtained by stacking several subsequent scans that are identical
The reason for partial scans was some changes in the positioning of the sensor. To get the expected result similar to the one obtained from the 2022 version, the following placement works:
