But I cannot get the Point cloud data with IsaacSim2023.1.1 from this link guide.
I found ActionGraph Structure is changed on IsaacSim2023.1.1,
Then I tried to change the code like below for new ActionGraph Structure of IsaacSim2023.1.1.
But I cannot get the Point cloud data because of Error Lile below.
Question:
Are there anyone success to get the Point cloud data with IsaacSim2023.1.1?
I would appreciate if you check the behavior with IsaacSim2023.1.1.
The PointCloudData output is now called ‘data’ to standardize it with our other annotators. And it is now a pointer to the point cloud data instead of a vector to avoid extra data copies.
Here is an example of how you would create a lidar and get the point cloud data from it, based on the How They Work section of the docs.
import omni.kit.commands
from pxr import Gf
lidar_config = "Example_Rotary"
# Create The Camera
_, sensor = omni.kit.commands.execute(
"IsaacSensorCreateRtxLidar",
path="/sensor",
parent=None,
config=lidar_config,
translation=(0, 0, 1.0),
orientation=Gf.Quatd(1,0,0,0),
# Create and Attach a render product to the camera
render_product = rep.create.render_product(sensor.GetPath(), [1, 1])
# Create Annotator to read the data from with annotator.get_data()
annotator = rep.AnnotatorRegistry.get_annotator("RtxSensorCpuIsaacCreateRTXLidarScanBuffer")
annotator.attach(render_product)
# This is the new part, it actually gets the data from the annotator and prints the point cloud data.
# When the data changes, you have to fetch it again, i.e. every frame if you want it.
data = annotator.get_data()
print(data["data"])
