Hello.
I am trying to implement a function to detect collisions of my manipulator, below (Doosan M1013).
The manipulator consists of several mesh parts, and the collision should be detected when the each part are overlapped (self collision detection).
I referenced these links, but they are quite difficult to customize on my python script.
Would you let me know how I can implement the collision detection functions in my python script.
I attached the python file and M1013 usd file.
# Copyright (c) 2021, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
import carb
import omni.kit.commands
import omni.ext
import omni.appwindow
import weakref
import omni.kit.settings
import gc
import asyncio
from omni.kit.menu.utils import add_menu_items, remove_menu_items, MenuItemDescription
from pxr import Gf
from omni.isaac.core import PhysicsContext
from omni.isaac.core.utils.nucleus import find_nucleus_server
from omni.isaac.core.utils.prims import create_prim
#### ContactRepoertDemo ####
from omni.physx.scripts.physicsUtils import *
from pxr import Usd, UsdLux, UsdGeom, UsdShade, Sdf, Gf, Tf, Vt, UsdPhysics, PhysxSchema
from omni.physx import get_physx_interface
from omni.physx.bindings._physx import SimulationEvent
from random import seed
from random import random
import omni.physxdemos as demo
MENU_NAME = "M1013 Collision detection"
class Extension(omni.ext.IExt):
def on_startup(self):
"""Initialize extension and UI elements"""
self._timeline = omni.timeline.get_timeline_interface()
self._viewport = omni.kit.viewport.get_default_viewport_window()
self._usd_context = omni.usd.get_context()
self._stage = self._usd_context.get_stage()
self._window = None
menu_items = [MenuItemDescription(name=MENU_NAME, onclick_fn=lambda a=weakref.proxy(self): a._menu_callback())]
self._menu_items = [MenuItemDescription(name="Demo", sub_menu=menu_items)]
add_menu_items(self._menu_items, "Isaac Examples")
events = get_physx_interface().get_simulation_event_stream()
self._simulation_event_sub = events.create_subscription_to_pop(self._on_simulation_event)
def _menu_callback(self):
self._on_environment_setup()
pass
async def _create_moveit_sample(self):
await omni.usd.get_context().new_stage_async()
await omni.kit.app.get_app().next_update_async()
self._viewport.set_camera_position("/OmniverseKit_Persp", 200, 500, 200, True)
self._viewport.set_camera_target("/OmniverseKit_Persp", 0, 0, 50, True)
create_prim(
prim_path="/background", usd_path=self._nucleus_path + "/Isaac/Environments/Grid/gridroom_black.usd"
create_prim(
prim_path="/M1013",
usd_path=self._nucleus_path + "/Projects/K-CLOUD/DigitalTwin_Workshop/Robot/m1013_d415_vgc10_ver2.usd"
#### ContactReportDemo ####
RobotPrim = self._stage.GetPrimAtPath("/M1013")
print("RobotPrim = ", RobotPrim)
contactReportAPI = PhysxSchema.PhysxContactReportAPI.Apply(RobotPrim)
contactReportAPI.CreateThresholdAttr().Set(1)
PhysicsContext(physics_dt=1.0 / 60.0)
# num_hit = self.check_overlap_box()
# print("Numhit = ",num_hit )
self._timeline.play()
def _on_environment_setup(self):
result, nucleus_server = find_nucleus_server()
if result is False:
carb.log_error("Could not find nucleus server with /Isaac folder")
return
self._nucleus_path = nucleus_server
asyncio.ensure_future(self._create_moveit_sample())
def on_shutdown(self):
"""Cleanup objects on extension shutdown"""
self._timeline.stop()
remove_menu_items(self._menu_items, "Isaac Examples")
self._window = None
gc.collect()
def _on_simulation_event(self, event):
if event.type == int(SimulationEvent.CONTACT_FOUND):
print("Contact found:!!!!!!!")
m1013_d415_vgc10_ver2.usd (49.0 MB)
Thank you !
