Collision with scatter 3d
I am trying to randomize objects positions and prevent them from colliding to each other but with the scatter_3d I still get collisions
here is the code
import omni
camera = rep.create.camera(
clipping_range=((0.01, 100000)),
focal_length=3.7,
focus_distance=0,
f_stop=0,
horizontal_aperture=3.896,
projection_type=“fisheye_equidistant”,
fisheye_max_fov=98,
render_product = rep.create.render_product(camera, (1280, 720))
with rep.new_layer():
def dome_lights():
lights = rep.create.light(
light_type=“Dome”,
rotation=rep.distribution.uniform((0, 0, 0), (360, 360, 360)),
temperature=rep.distribution.normal(6500, 500),
intensity=rep.distribution.normal(1000, 500),
texture=rep.distribution.choice([
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/adams_place_bridge_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/bathroom_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/en_suite_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/carpentry_shop_01_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/autoshop_01_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/hospital_room_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/old_bus_depot_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/studio_small_04_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/vulture_hide_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/wooden_lounge_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Indoor/lebombo_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Clear/evening_road_01_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Clear/sunflowers_4k.hdr’,
‘omniverse://localhost/NVIDIA/Assets/Skies/Clear/venice_sunset_4k.hdr’
return lights.node
def randomize_sphere_lights():
light_type=“Sphere”,
color=rep.distribution.uniform((0.0, 0.0, 0.0), (1.0, 1.0, 1.0)),
intensity=rep.distribution.uniform(100000, 3000000),
position=rep.distribution.uniform((-250, -250, -250), (250, 250, 100)),
scale=rep.distribution.uniform(1, 20),
count=10,
return lights.node
MOD = ‘omniverse://192.168.24.212/Library/usd/onshape_imports/kona_module_01/kona_module_edit.usd’
volume = rep.create.sphere(scale=4, visible=False)
def mod():
mod = rep.create.from_usd(MOD, count=5)
with mod:
rep.modify.pose(
rotation=rep.distribution.uniform((-360, -360, -360), (360, 360, 360)),
rep.modify.visibility(rep.distribution.choice([True, False]))
rep.randomizer.scatter_3d(volume, check_for_collisions=True)
return mod.node
mats3 = rep.create.material_omnipbr(
metallic=rep.distribution.uniform(0.0, 1.0),
roughness=rep.distribution.uniform(0.0, 1.0),
diffuse=rep.distribution.uniform((0, 0, 0), (1, 1, 1)),
count=20,
spheres = rep.create.sphere(
scale=0.2,
count=20)
def get_spheres():
with spheres:
rep.modify.pose(
position=rep.distribution.uniform((-1.5,-1.5,-1.5), (1.5,1.5,1.5)),
rep.randomizer.materials(mats3)
rep.physics.collider()
rep.physics.rigid_body()
return spheres.node
mats1 = rep.create.material_omnipbr(
count=20,
cone = rep.create.cone(
scale=0.2,
count=20)
def get_cone():
with cone:
rep.modify.pose(
rep.randomizer.materials(mats1)
return cone.node
mats2 = rep.create.material_omnipbr(
count=20,
cylinder = rep.create.cylinder(
scale=0.2,
count=20)
def get_cylinder():
with cylinder:
rep.modify.pose(
rep.randomizer.materials(mats2)
return cylinder.node
rep.randomizer.register(dome_lights)
with rep.trigger.on_frame(num_frames=1000,interval=20):
rep.randomizer.dome_lights()
rep.randomizer.register(randomize_sphere_lights)
with rep.trigger.on_frame(num_frames=1000):
rep.randomizer.randomize_sphere_lights()
rep.randomizer.register(mod)
rep.randomizer.mod()
with rep.trigger.on_frame(interval=20, num_frames=1000):
with camera:
rep.modify.pose(
position=rep.distribution.uniform((0.6, 0.6, 0.6), (1.5, 1.5, 1.5)),
look_at=“/World”,
rep.randomizer.register(get_spheres)
rep.randomizer.get_spheres()
rep.randomizer.register(get_cone)
rep.randomizer.get_cone()
rep.randomizer.register(get_cylinder)
rep.randomizer.get_cylinder()
It looks like you are trying to do multiple scatters in sequence and make sure that there are no collisions among any of the scatters. Is that correct?
To do that you need to use the context manager with rep.sequential to make sure the scatter nodes are executed in sequence, and also add previous scattered prims to the args of the next scatter. Here is a bit of sample code to get you started:
with rep.sequential():
with items1:
rep.scatter2d()
with items2:
rep.scatter2d(no_coll_prims=items1)
Let me know if this makes sense - and also, I would suggest troubleshooting this starting with a single scatter function - make sure it works to keep its own scattered prims out of collision with themselves, then move on to making a second and third scatter, etc.
-Henry
Hey
Thank you for the answer where could I find a example on how to use the with rep.sequential to understand it better
Sure - here is an example:
import asyncio
async def main():
        mat1 = rep.create.material_omnipbr(
           diffuse=(0.1, 0.1, 0.1),
           roughness=0.99,
           metallic=0.99,
           emissive_color=(0.1, 0.1, 0.7),
           emissive_intensity=500,
        mat2 = rep.create.material_omnipbr(
           diffuse_texture=rep.distribution.choice(rep.example.TEXTURES),
           roughness_texture=rep.distribution.choice(rep.example.TEXTURES),
           metallic_texture=rep.distribution.choice(rep.example.TEXTURES),
           emissive_texture=rep.distribution.choice(rep.example.TEXTURES),
           emissive_intensity=1000,
        mat3 = rep.create.material_omnipbr(
           emissive_intensity=200,
        cylinder = rep.create.cylinder(semantics=[('class', 'cylinder')], material=mat1, scale=(2.7, 4, 2.7), position=(-100, 50, -50), visible=True)
        plane_samp = rep.create.plane(scale=3, material=mat2, rotation=(20, 0, 0), visible=True)
        sphere_samp = rep.create.sphere(scale=2.4, material=mat3, position = (0, 100, -180), visible=True)
        def randomize_spheres():
            spheres = rep.create.sphere(position=rep.distribution.uniform((0,0,0), (100,100,100)), scale=0.4, count=20) #48
            cubes = rep.create.cube(position=rep.distribution.uniform((0,0,0), (100,100,100)), scale=0.33, count=20) #48
            cones = rep.create.cone(position=rep.distribution.uniform((0,0,0), (100,100,100)), scale=0.33, count=20) #48
            with rep.utils.sequential():
                with spheres:
                    rep.randomizer.color(colors=rep.distribution.uniform((0, 0, 0), (0.4, 0.4, 0.4)))
                    rep.randomizer.scatter_2d([plane_samp, sphere_samp], no_coll_prims=[cylinder], check_for_collisions=True)
                with cubes:
                    rep.randomizer.scatter_2d([plane_samp, sphere_samp], no_coll_prims=[cylinder, spheres], check_for_collisions=True)
                with cones:
                    rep.randomizer.scatter_2d([plane_samp, sphere_samp], no_coll_prims=[cylinder, spheres, cubes], check_for_collisions=True)
            return spheres.node
        rep.randomizer.register(randomize_spheres)
        with rep.trigger.on_frame(num_frames=10):
            rep.randomizer.randomize_spheres()
asyncio.ensure_future(main())
thank you I was able to fix the script to do what I want with this example!
