Collision Detection for Scatter not working well
There are two cases with scatter_2d that I tried but none of them work very well.
a) Setting only check_for_collisions: True
b) Setting both check_for_collisions: True and passing no_coll_prims
@pcallender @jiehanw @dennis.lynch
what does your script look like?
What items are you scattering in each call of scatter?
If you have sequential scatters, put them in a sequential context. Like this:
with rep.sequential():
with items1:
rep.scatter2d()
with items2:
rep.scatter2d(no_collision=items1)
# Default scene settings. This script default is 1 (IsaacSim), so if you change
# the meters per unit or up axis, you need to alter the coordinates and rotations.
# IsaacSim default is 1, Code is 0.01
stage_unit_setting:
  settings.set_stage_meters_per_unit:
    meters_per_unit: 1
# IsaacSim default is "Z"", Code is "Y"
stage_up_axis_setting:
  settings.set_stage_up_axis:
    up_axis: Z
# Enable Path Tracing
path_tracing:
  settings.set_render_pathtraced:
    samples_per_pixel: 32
path_tracing_clamp:
  settings.carb_settings:
    setting: /rtx/pathtracing/clampSpp
    value: 0
# Load the stage
load_stage:
  create.from_usd:
    usd: omniverse://localhost/Library/wh1.usd
# Select the objects in the stage
forklift:
  get.prim_at_path:
    path:  /Replicator/Ref_Xform/Ref/forklift
floor:
  get.prims:
    semantics: [[class, floor]]
racks_and_walls:
  get.prims:
    semantics: [[class, rack], [class, wall]]
light:
  get.prim_at_path:
    path: /Environment/defaultLight
camera:
  create.camera:
    position: [0, 0, 0]
    rotation: [0, 0, 0]
# Create output
render_product:
  create.render_product:
    camera: camera
    resolution: [1280, 720]
writer:
  writers.get:
    init_params:
      partly_occluded_threshold: 0.24
      fully_visible_threshold: 0.25
      semantic_filter_predicate: class:person
      output_dir: /workspaces/Surveily.Datasets.Generator.Omniverse/.out/Surveily.Omniverse.Worlds/Warehouse/
writer_attach:
  writer.attach:
    render_products: render_product
# Load the animations
businessmbb0001476549_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, businessmbb0001476549]]
    dir_path: omniverse://localhost/Library/Assets/People/business-m-bb-0001-476549/Motion/
businessmbb0001476549_animations:
  get.prims:
businessmbb0003476551_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, businessmbb0003476551]]
    dir_path: omniverse://localhost/Library/Assets/People/business-m-bb-0003-476551/Motion/
businessmbb0003476551_animations:
  get.prims:
casualfbb0001476556_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, casualfbb0001476556]]
    dir_path: omniverse://localhost/Library/Assets/People/casual-f-bb-0001-476556/Motion/
casualfbb0001476556_animations:
  get.prims:
casualfbb0002476554_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, casualfbb0002476554]]
    dir_path: omniverse://localhost/Library/Assets/People/casual-f-bb-0002-476554/Motion/
casualfbb0002476554_animations:
  get.prims:
casualmbb0002476553_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, casualmbb0002476553]]
    dir_path: omniverse://localhost/Library/Assets/People/casual-m-bb-0002-476553/Motion/
casualmbb0002476553_animations:
  get.prims:
uniformf0002_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformf0002]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-f-0002/Motion/
uniformf0002_animations:
  get.prims:
uniformf0003_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformf0003]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-f-0003/Motion/
uniformf0003_animations:
  get.prims:
uniformf0004_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformf0004]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-f-0004/Motion/
uniformf0004_animations:
  get.prims:
uniformf0015_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformf0015]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-f-0015/Motion/
uniformf0015_animations:
  get.prims:
uniformf0016_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformf0016]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-f-0016/Motion/
uniformf0016_animations:
  get.prims:
uniformf0017_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformf0017]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-f-0017/Motion/
uniformf0017_animations:
  get.prims:
uniformm0004_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0004]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0004/Motion/
uniformm0004_animations:
  get.prims:
uniformm0005_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0005]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0005/Motion/
uniformm0005_animations:
  get.prims:
uniformm0006_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0006]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0006/Motion/
uniformm0006_animations:
  get.prims:
uniformm0021_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0021]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0021/Motion/
uniformm0021_animations:
  get.prims:
uniformm0022_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0022]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0022/Motion/
uniformm0022_animations:
  get.prims:
uniformm0023_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0023]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0023/Motion/
uniformm0023_animations:
  get.prims:
uniformm0024_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0024]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0024/Motion/
uniformm0024_animations:
  get.prims:
uniformm0025_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0025]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0025/Motion/
uniformm0025_animations:
  get.prims:
uniformm0026_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0026]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0026/Motion/
uniformm0026_animations:
  get.prims:
uniformm0027_load_animations:
  create.from_dir:
    recursive: True
    semantics: [[animation, uniformm0027]]
    dir_path: omniverse://localhost/Library/Assets/People/uniform-m-0027/Motion/
uniformm0027_animations:
  get.prims:
# Overwrite Seed
# set_seed:
#   core.set_global_seed:
#     seed: 123456789
# Set the trigger as on_frame
trigger:
  trigger.on_frame:
    interval: 2
    max_execs: 1000
    #rt_subframes: 10
# Set sun intensity
with.light:
  modify.attribute:
    value: 4000
# When the trigger executes, run the following logic
with_trigger:
  with.trigger:
    # Randomize sun
    with.light:
      modify.attribute:
        value:
          distribution.uniform:
            lower: -20
            upper: 0.53
      modify.pose:
        rotation:
            lower: [0, 0, -180]
            upper: [0, 60, 180]
    # create and scatter forklifts
    fork_instance:
      randomizer.instantiate:
        paths:
          - omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.1/Isaac/Props/Forklift/forklift.usd
        mode: scene_instance
    with.fork_instance:
      modify.pose:
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      randomizer.scatter_2d:
        seed: 100
        surface_prims: floor
        no_coll_prims: racks_and_walls
    # create and scatter cones
    cone_instance:
        paths:
          - omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.1/Isaac/Environments/Simple_Warehouse/Props/S_TrafficCone.usd
    with.cone_instance:
      modify.pose:
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
        seed: 101
    # create and scatter wet floor signs
    wet_floor_sign_instance:
        paths:
          - omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.1/Isaac/Environments/Simple_Warehouse/Props/S_WetFloorSign.usd
    with.wet_floor_sign_instance:
      modify.pose:
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
        seed: 103
    # move the camera around and rotate
    with.camera:
      modify.pose:
        position:
            lower: [-23.6, -3, 2.5]
            upper: [3.03, 3, 7.5]
        rotation:
            lower: [0, -30, -120]
            upper: [0, -10, -60]
    # create and scatter cage trolleys
    trolley_instance:
        paths:
          - omniverse://localhost/Library/trolley1-fbx.usd
        use_cache: False
    trolley_wall:
      get.prims:
        semantics: [[class, cagesteel], [class, cagedarksteel]]
    trolley_floor:
      get.prims:
        semantics: [[class, cagefloor]]
    with.trolley_wall:
      randomizer.materials:
        materials:
          - /Replicator/Ref_Xform/Ref/Looks/Painted_Metal_Yellow_A
          - /Replicator/Ref_Xform/Ref/Looks/Painted_Metal_Yellow_Glossy_A
          - /Replicator/Ref_Xform/Ref/Looks/Painted_Metal_Grey_Glossy_A
          - /Replicator/Ref_Xform/Ref/Looks/Painted_Metal_Orange_A
          - /Replicator/Ref_Xform/Ref/Looks/Painted_Metal_Red_A
          # - /Replicator/Ref_Xform/Ref/Looks/Powdercoat_A
      # randomizer.color:
      #   colors:
      #     - [5, 5, 0]
      #     - [111, 111, 111]
      #     - [155, 155, 104]
      #     - [155, 155, 53]
    with.trolley_floor:
        materials:
          - /Replicator/Ref_Xform/Ref/Looks/Gold_Scratched
          - /Replicator/Ref_Xform/Ref/Looks/Aluminum_Scratched
          - /Replicator/Ref_Xform/Ref/Looks/Stainless_Steel_Milled
    with.trolley_instance:
      # modify.semantics:
      #   semantics: [[class, cagetrolley]]
      modify.pose:
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
        seed: 102
    # move the forklift around and rotate
    with.forklift:
      modify.pose:
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      # randomizer.scatter_2d:
      #   seed: 100
      #   surface_prims: floor
      #   no_coll_prims: racks_and_walls
      #   check_for_collisions: True
    # Create and scatter
    businessmbb0001476549_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/business-m-bb-0001-476549/Actor/business-m-bb-0001-476549/business-m-bb-0001-476549.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.businessmbb0001476549_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
        semantics: [[class, person]]
      modify.animation:
        values:
          distribution.sequence:
            items: businessmbb0001476549_animations
        seed: 0
    businessmbb0003476551_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/business-m-bb-0003-476551/Actor/business-m-bb-0003-476551/business-m-bb-0003-476551.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.businessmbb0003476551_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: businessmbb0003476551_animations
        seed: 1
    casualfbb0001476556_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/casual-f-bb-0001-476556/Actor/casual-f-bb-0001-476556/casual-f-bb-0001-476556.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.casualfbb0001476556_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: casualfbb0001476556_animations
        seed: 2
    casualfbb0002476554_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/casual-f-bb-0002-476554/Actor/casual-f-bb-0002-476554/casual-f-bb-0002-476554.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.casualfbb0002476554_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: casualfbb0002476554_animations
        seed: 3
    casualmbb0002476553_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/casual-m-bb-0002-476553/Actor/casual-m-bb-0002-476553/casual-m-bb-0002-476553.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.casualmbb0002476553_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: casualmbb0002476553_animations
        seed: 4
    uniformf0002_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-f-0002/Actor/uniform-f-0002/uniform-f-0002.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformf0002_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformf0002_animations
        seed: 5
    uniformf0003_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-f-0003/Actor/uniform-f-0003/uniform-f-0003.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformf0003_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformf0003_animations
        seed: 6
    uniformf0004_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-f-0004/Actor/uniform-f-0004/uniform-f-0004.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformf0004_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformf0004_animations
        seed: 7
    uniformf0015_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-f-0015/Actor/uniform-f-0015/uniform-f-0015.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformf0015_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformf0015_animations
        seed: 8
    uniformf0016_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-f-0016/Actor/uniform-f-0016/uniform-f-0016.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformf0016_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformf0016_animations
        seed: 9
    uniformf0017_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-f-0017/Actor/uniform-f-0017/uniform-f-0017.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformf0017_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformf0017_animations
        seed: 10
    uniformm0004_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0004/Actor/uniform-m-0004/uniform-m-0004.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0004_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0004_animations
        seed: 11
    uniformm0005_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0005/Actor/uniform-m-0005/uniform-m-0005.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0005_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0005_animations
        seed: 12
    uniformm0006_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0006/Actor/uniform-m-0006/uniform-m-0006.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0006_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0006_animations
        seed: 13
    uniformm0021_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0021/Actor/uniform-m-0021/uniform-m-0021.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0021_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0021_animations
        seed: 14
    uniformm0022_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0022/Actor/uniform-m-0022/uniform-m-0022.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0022_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0022_animations
        seed: 15
    uniformm0023_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0023/Actor/uniform-m-0023/uniform-m-0023.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0023_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0023_animations
        seed: 16
    uniformm0024_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0024/Actor/uniform-m-0024/uniform-m-0024.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0024_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0024_animations
        seed: 17
    uniformm0025_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0025/Actor/uniform-m-0025/uniform-m-0025.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0025_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0025_animations
        seed: 18
    uniformm0026_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0026/Actor/uniform-m-0026/uniform-m-0026.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0026_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0026_animations
        seed: 19
    uniformm0027_instance:
        paths:
          - omniverse://localhost/Library/Assets/People/uniform-m-0027/Actor/uniform-m-0027/uniform-m-0027.usd
            lower: [1]
            upper: [3]
        use_cache: False
    with.uniformm0027_instance:
      modify.pose:
        scale: 0.01
        rotation:
            lower: [0, 0, -180]
            upper: [0, 0, 180]
      modify.semantics:
      modify.animation:
        values:
            items: uniformm0027_animations
        seed: 20
    # Randomize floor
    with.floor:
      modify.material:
        value:
          - /Replicator/Ref_Xform/Ref/SM_floor27/Looks/MI_Floor_02b
          - /Replicator/Ref_Xform/Ref/Looks/Concrete_Floor_Damage
          - /Replicator/Ref_Xform/Ref/Looks/Concrete_Polished
          - /Replicator/Ref_Xform/Ref/Looks/Concrete_Precast
The issue does not seem to be with sequential (as I alluded to). It could be a number of things. I will try to repro on my end - can give me a more detailed instruction for it - i.e. which app version, what command do you run to execute this?
Also, are you getting any errors in your terminal?
I guess you probably run something like this in the script editor in Isaac Sim ?
from omni.replicator.replicator_yaml import parse
parse(yaml_path=yaml_file_path)
No, I run a headless Isaac docker container and point it to the yaml file.
OK - which version of isaac?
nvcr.io/nvidia/isaac-sim:2023.1.1
I’m working on it, having some issues with my localhost at the moment. if you have a miminal repro with things on another nucleus server (e.g. ov content) and the issue pared down into a shorter yaml script it would help me go faster.
here: synthetic-data-examples/omni.replicator_yaml/warehouse.yaml at main · Surveily/synthetic-data-examples · GitHub
ok, i just found my issue with localhost - it’s because I’m running ubuntu 18.04. I need to upgrade, but won’t be finished today. if you have a repro with ov content and i can help slightly faster.
It is OV. Just replace “localhost” with the cloud URL.
Ah, I see they are available for this one (the “People” folder on the original yaml wasn’t available on cloud URL )
OK, for me the issue is that Scatter2d is raising an error when it’s trying to sample the forklift because the forklift has too many child meshes. So it doesn’t actually scatter anything as it never gets past this. Did you get any error like that?
This version of replicator only has scatter tested with scattering prims that contain a single child mesh, but it may still work otherwise. I commented out lines L228-L232 so bypass this raised condition, and it scatters things but I haven’t tested it. See attached screenshot. Can you try commenting this out and see where you get? If you still have issues with inappropriate collisions let me know and I’ll try to make you a workaround.
Upcoming versions of replicator will have much improved scatter capabilities.
I will make sure this is thoroughly tested + working in future versions.
Scattering the forklift works fine for me…
which version of replicator are you using?
The one from the container I mentioned above
Right - i used the same version but from the omni UI on launcher. Let me see what I can do when the container one - it is odd that they are ostensibly the same version but you have a different error.
I spent a couple hours today trying to get the container to work, but i’m still having issues. I’m going to try again this week.
