Testing Scatter_2D collision=True in both Omniverse Code and Omniverse Isaac Sim Script Editor in Python
I am trying to test the functionality of scatter_2D and when I use Omniverse Code, scatters are not collision free. Does check_for_collison=True work in Omniverse Code? I even added collider() to plane but it didn’t work.
As you see scattered pallets dived into the inside of the plane.
from datetime import datetime
import omni.usd
# import omni.isaac.core.utils.bounds as bounds_utils
# import omni.isaac.core.utils.prims as prims_utils
with rep.new_layer():
    # Define paths for the character, the props, the environment and the surface where the assets will be scattered in.
    PALLET_URL = "omniverse://localhost/NVIDIA/Assets/ArchVis/Industrial/Pallets/Pallet_B1.usd"
    plane = rep.create.plane(scale=25, visible=True, semantics=[("class", "plane")])
    with plane:
        rep.physics.collider()
    print('type of plane: ', print(plane))
    def scatter_pallets():
        pallets = rep.create.from_usd(PALLET_URL, semantics=[('class', 'pallet')], count=10)
        with pallets:
            #rep.physics.collider()
            rep.randomizer.scatter_2d(surface_prims=plane, check_for_collisions=True)
        return pallets
    # Register randomization
    rep.randomizer.register(scatter_pallets)
    # Setup camera and attach it to render product
    camera = rep.create.camera(
        focus_distance=800,
        f_stop=0.5
    render_product = rep.create.render_product(camera, resolution=(1024, 1024))
    timestamp = datetime.now().strftime("%Y_%m_%d-%I_%M_%S_%p")
    # Initialize and attach writer
    writer = rep.WriterRegistry.get("BasicWriter")
    writer.initialize(output_dir="/home/mona/Desktop/Isaac_Sim_Dummy_Out/pallet/" + timestamp , rgb=True, bounding_box_2d_tight=True)
    writer.attach([render_product])
    with rep.trigger.on_frame(num_frames=100):
        pallets = rep.randomizer.scatter_pallets()
        with camera:
            rep.modify.pose(position=rep.distribution.uniform((-1000, 200, 1500), (1000, 400, 2000)), look_at=pallets)
When I try the code in Isaac Sim, dimensions are messed up hence I cannot test it. If you can tell me how I can can test this code in Isaac Sim Script Editor it would be really great.
Currently, check_for_collisiononly checks for collisions between the objects being scattered, it does not consider the environment (e.g. the plane in this case).
Hi @ahaidu thanks for your response.
Is there any other way I could use in order to avoid the collision with floor?
You can write a custom scatterer using usd or isaac sim api, similar to this answer: Scatter_2d is not guaranting collision free scatter - #3 by ahaidu
