Combining nvdsanalytics with rtsp-in-rtsp-out example
**• Hardware Platform - Jetson **
• DeepStream Version 6.0.1
• JetPack Version: 4.6.1-b110
• TensorRT Version 8.2
• Requirement details
I am trying to combine the two deepstream_test1_rtsp_in_rtsp_out.py and deepstream_nvdsanalytics.py but I have the following error and my program is stopping. I am new to deepstream. Any idea regarding this issue? I can’t find much.
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating nvtracker
Creating nvdsanalytics
Creating tiler
Creating nvvidconv
Creating nvosd
Creating H264 Encoder
Creating H264 rtppay
Adding elements #1 to Pipeline
Adding elements # to Pipeline
Linking elements in the Pipeline
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Opening in BLOCKING MODE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvMultiObjectTracker] Initialized
0:00:01.360473460 20233 0x3581f900 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/sources/python/apps/deepstream_smarthub/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:05.405424501 20233 0x3581f900 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/python/apps/deepstream_smarthub/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:05.406672551 20233 0x3581f900 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/python/apps/deepstream_smarthub/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:05.406728125 20233 0x3581f900 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine opened error
0:01:18.569406700 20233 0x3581f900 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1942> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:01:18.623190476 20233 0x3581f900 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dsnvanalytics_pgie_config.txt sucessfully
Decodebin child added: source
Error: gst-resource-error-quark: Unauthorized (15): gstrtspsrc.c(6116): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstURIDecodeBin:uri-decode-bin/GstRTSPSrc:source:
Unauthorized (401)
Exiting app
try to remove ugly pluging using this command :-
sudo apt remove gstreamer1.0-plugins-ugly
I tried, but it didn’t change anything. Same error.
Seems rtspsrc error. please ensure your rtsp server works fine.
the RTSP is working, it works for deepstream_test1_rtsp_in_rtsp_out.py
I think the problems come from the elements in the pipeline, I tried the following order based on deduction. Any suggestion regarding the elements linking for RTSP in RTSP out + nvdsanalytics?
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(nvanalytics)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(nvvidconv_postosd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(rtppay)
I tried first with as in the nvdsanalytics example:
streammux.link(queue1)
queue1.link(pgie)
pgie.link(queue2)
queue2.link(tracker)
tracker.link(queue3)
queue3.link(nvanalytics)
nvanalytics.link(queue4)
queue4.link(tiler)
tiler.link(queue5)
queue5.link(nvvidconv)
nvvidconv.link(queue6)
queue6.link(nvosd)
nvosd.link(queue7)
queue7.link(nvvidconv_postosd)
nvvidconv_postosd.link(queue8)
queue8.link(caps)
caps.link(queue9)
queue9.link(encoder)
encoder.link(queue10)
queue10.link(rtppay)
if is_aarch64():
rtppay.link(queue11)
queue11.link(transform)
transform.link(sink)
else:
queue11.link(sink)
and next with:
streammux.link(pgie)
pgie.link(tracker)
tracker.link(nvanalytics)
nvanalytics.link(tiler)
tiler.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(nvvidconv_postosd)
nvvidconv_postosd.link(caps)
caps.link(encoder)
encoder.link(rtppay)
rtppay.link(sink)
So can you remove more plugin in your pipeline to narrow down the issue?
Found the working pipeline here Deepstream RTSP in and RTSP out with nvanalytics and tracker
Ok. Hope you can fix your issue by refer it.
