Command Prompt errors when trying to get Vmaterials into Solidworks Visualize
I keep getting command prompt errors when trying to run the command to get the Vmaterials to show up in my Solidworks Appearances folder.
Everything download onto my computer fine. And the I see the Vmat folder in Documents and the Materials are there. I copied and pasted it into Appearances as instructed. When I open Visualize I can see the folders but there is nothing in them.
Thanks for your time! I look forward to hearing from you.
Hi @dezinno3dart , which version of Solidworks are you using and did you install NVIDIA MDL Material Exchange? It’s a pre-requisition for using vMaterials in other apps. You can check this by searching in App > Installed Apps.
