Our Jetson Xavier board configured as RC and FPGA board acts as an EP which send data through memory write operation. But i’m observing the below errors,
@dasanfreedom
The FPGA endpoint in this case is not preparing the PCIe packets correctly. Please check the FPGA PCIe IP configuration correctly.
For example, from the ‘TLP Header’, it looks like it is 4DW in size… but decoding ‘40000018’ tells us that it should be a 3DW header.
