Hi NVIDIA Support Team,
I am planning to use an external High-Power USB WiFi Adapter on the Jetson Thor (or Orin) platform to achieve better signal range and bandwidth than the onboard module.
I am specifically looking at the Alfa AWUS036ACH (or other adapters based on the Realtek RTL8812AU chipset).
I have a few technical questions regarding compatibility:
1. Driver Support:
Does the Jetson Linux (L4T) kernel natively support the RTL8812AU chipset?
If not, are there any known issues with compiling standard open-source drivers (like morrownr/8812au) on the Jetson platform?
2. USB Power Supply:
These high-power adapters (like the Alfa AWUS036ACH) have higher power consumption.
Can the Jetson’s USB ports provide sufficient power to drive this adapter directly, or is an external powered USB hub strictly required to prevent instability?
3. Recommendations:
If the RTL8812AU chipset is not recommended for Jetson, do you have any other suggestions for USB WiFi chipsets that have solid driver support and are suitable for high-performance external antennas?
