Usb网卡使用
硬件:自定义载板,jeston agx orin64GB
软件:36.3
使用了两个usb口,测试可以接入鼠标键盘 usb扩展器均可正常使用
但是接入usb无线网卡,能在lsusb下找到设备,驱动已安装,但是不能在ifconfig下找到网络设备
Please check with the vendor whether it needs additional driver. And you can refer to the section to enable the configs to rebuild kernel image:
Kernel Customization — NVIDIA Jetson Linux Developer Guide
确认了 这款usb 无线网卡是免驱版,即插即用,我在其他主机的ubuntu系统下就可以直接使用
So you have other two Ethernet dongles connected and the two are shown as usb0 and usb1? If other network devices are good, it looks like the wifi device needs additional driver.
These might be relevant.
This repo has some module and hardware discussion for Realtek 8811cu chipset if you search for 8811cu.
usb只接了鼠标键盘和1个usb wifi
沒有什麼所謂的免驅板… 上面已經有人貼了你的driver是rtl8xxxu. 麻煩確認一下這個driver有沒有.
666,可以 了,满分感谢
