I am trying to combine both CSI Camera streams into a single sidebyside stream to send to my remote pc to view on a stereoscopic vr headset, but I can’t get the stream to send convert to h264 encoding.
My pipeline call looks like this:
WIDTH=1280
HEIGHT=720
WIDTH2=2560
HEIGHT2=720
CAPS=“video/x-raw, width=$WIDTH, height=$HEIGHT”
CLIENT_IP=192.168.0.30gst-launch-1.0 nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=$WIDTH sink_0::height=$HEIGHT sink_1::xpos=$WIDTH sink_1::ypos=0 sink_1::width=$WIDTH sink_1::height=$HEIGHT ! “video/x-raw,width=$WIDTH2, height=$HEIGHT2, framerate=21/1” ! nvvidconv ! nvv4l2h264enc bitrate=8000000 insert-sps-pps=true ! rtph264pay mtu=1400 ! udpsink host=$CLIENT_IP port=5000 sync=false async=false nvarguscamerasrc name=camsrc0 sensor_id=0 ! ‘video/x-raw(memory:NVMM),width=1280, height=720, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! “video/x-raw,width=$WIDTH, height=$HEIGHT” ! comp. nvarguscamerasrc name=camsrc1 sensor_id=1 ! ‘video/x-raw(memory:NVMM),width=1280, height=720, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! “video/x-raw,width=$WIDTH, height=$HEIGHT” ! comp.
And the ouptut i get is this:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:camsrc1: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:camsrc1:
streaming stopped, reason not-negotiated (-4)
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Camera index = 0
Camera mode = 4
seconds to Run = 0
Execution ended after 0:00:01.229080747
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
