Hi, I am trying to merge two RPi HD camera streams into one and inputting the resulting stream to the Darknet. Sorry in advance, if some technical terms or concepts are wrong, I am new to using GStreamer and video pipelines.
At this moment:
- using a single camera works.
- merging the streams and previewing with nvoverlaysink works.
Here is an example of a pipeline that works for previewing.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM)",width=640, height=720, framerate=30/1, format=NV12 ! nvvidconv ! 'video/x-raw(memory:NVMM)', width=320, height=360 ! comp. nvarguscamerasrc sensor-id=1 ! "video/x-raw(memory:NVMM)",width=640, height=720, framerate=30/1, format=NV12 ! nvvidconv ! 'video/x-raw(memory:NVMM)', width=320, height=360 ! comp. nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=320 sink_0::height=360 sink_1::xpos=320 sink_1::ypos=0 sink_1::width=320 sink_1::height=360 ! videoconvert ! 'video/x-raw(memory:NVMM)', format=RGBA ! nvoverlaysink
The problem arises when I change it to appsink and input it to the darknet.
./darknet detector demo cfg/coco.data cfg/yolov4-tiny.cfg yolov4-tiny.weights "nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM),width=640, height=720, framerate=30/1, format=NV12 ! nvvidconv ! video/x-raw(memory:NVMM), width=320, height=360 ! comp. nvarguscamerasrc sensor-id=1 ! video/x-raw(memory:NVMM),width=640, height=720, framerate=30/1, format=NV12 ! nvvidconv ! video/x-raw(memory:NVMM), width=320, height=360 ! comp. nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=320 sink_0::height=360 sink_1::xpos=320 sink_1::ypos=0 sink_1::width=320 sink_1::height=360 ! videoconvert ! video/x-raw(memory:NVMM), format=RGBA ! appsink"
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
[ WARN:0] global /tmp/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp (1761) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module nvarguscamerasrc1 reported: Internal data stream error.
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
[ WARN:0] global /tmp/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp (888) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0] global /tmp/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
[ERROR:0] global /tmp/build_opencv/opencv/modules/videoio/src/cap.cpp (142) open VIDEOIO(CV_IMAGES): raised OpenCV exception:OpenCV(4.4.0) /tmp/build_opencv/opencv/modules/videoio/src/cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can’t find starting number (in the name of file): nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM),width=640, height=720, framerate=30/1, format=NV12 ! nvvidconv ! video/x-raw(memory:NVMM), width=320, height=360 ! comp. nvarguscamerasrc sensor-id=1 ! video/x-raw(memory:NVMM),width=640, height=720, framerate=30/1, format=NV12 ! nvvidconv ! video/x-raw(memory:NVMM), width=320, height=360 ! comp. nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=320 sink_0::height=360 sink_1::xpos=320 sink_1::ypos=0 sink_1::width=320 sink_1::height=360 ! videoconvert ! video/x-raw(memory:NVMM), format=RGBA ! appsink in function ‘icvExtractPattern’
Video-stream stopped!
In the case of single-camera input into the Darknet, everything is ok as well.
./darknet detector demo cfg/coco.data cfg/yolov4-tiny.cfg yolov4-tiny.weights "nvarguscamerasrc ! video/x-raw(memory:NVMM),width=1280, height=720, framerate=30/1, format=NV12 ! nvvidconv ! video/x-raw, format=BGRx, width=640, height=360 ! videoconvert ! video/x-raw, format=BGR ! appsink"
What I could narrow down is that there is possibly a problem with “nvcompositor” and “videoconverter” converting the RGBA to BGR format. Whenever I try to modify the pipeline to output BGR format to app sink, I encounter an error. There is no problem if I don’t use “nvcompositor”.
WARNING: erroneous pipeline: could not link videoconvert0 to appsink0, videoconvert0 can’t handle caps video/x-raw(memory:NVMM), format=(string)BGR
Any help or tips on how to solve this would be appreciated.
Video after merging the two streams.
