• Hardware Platform (Jetson / GPU) T4 GPU
• DeepStream Version 5.0
• TensorRT Version 7.0
• NVIDIA GPU Driver Version (valid for GPU only) 460.56
• Issue Type( questions, new requirements, bugs) new requirements
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) reading configs from configuration file for dsexample
We are using dsexample as a plugin in a pipeline. In order to set the parameters of the plugin, I need to change it inside the code, e.g.:
g_object_set(G_OBJECT(dsexample), "full-frame", 1, NULL);
However, I want to set these parameters in a file and parse it to set the properties, similar to nvinfer :
g_object_set(G_OBJECT(inference), "config-file-path", "dstest_pgie_config.txt", NULL);
and inside the config-file, I would set the parameters as:
full-frame=1
Is there any easy/existing way to implement it?
