How can we configure the 400G Single-port OSFP (4x100G lanes) card to have 2 network ports, with a split of 2x200G ports, where each 200G port corresponds to a network port?
To achieve this, you would need to use a specific breakout split cable, and/or configure the split through the switch (commands may vary based on the switch model/OS used).
To get more specific guidelines, please open a support case and make sure to sure full details of the NIC and switch you are using.
Thanks,
Jonathan.
