I want to develop the Android app using opencv4android SDK with Visual Studio(not C# Android), I can not use Eclipse or Android studio with some reasons.
I have installed VS 2015 professional, I set up the environment use NVIDIA Codeworks for Android version 1R4 (TADP) , it includes JDK SDK NDK ANT Gradle Eclipse CDT opencv4tegra and Nsight Tegra Visual Studio Edition, I use Eclipse to test OpenCV samples(OpenCV-2.4.8.2-Tegra-sdk\samples), all samples can compile and work, so that I assumed that the installation is ok.
I create Android Application under Nsight Tegra, write a simple helloworld(pure java without native code c/c++), the program can compile and work. I import opencv module in .java file, " import org.opencv..*** ;" it surely compile with error, error says that it can not find org.opencv.* , Next, I want to include opencv4android SDK(it’s a challenge for me), I click Properties of project, Ant Build → Java → Java Source Directories, I add opencv java source dir “C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src” to it, it compile with a different error, now it can find the org.opencv folder, error is “Package R not exist”, the R is org.opencv.R.
-compile:
[javac] Compiling 93 source files to C:\Users\linzi\Desktop\kk\Android1\Android1\Tegra-Android\Debug\bin\classes
[javac] C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java:5: Error: can not find symbol
[javac] import org.opencv.R;
[javac] ^
[javac] symbol: class R
[javac] location: package org.opencv
[javac] C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java:72: error: package R not exist
[javac] TypedArray styledAttrs = getContext().obtainStyledAttributes(attrs, R.styleable.CameraBridgeViewBase);
[javac] ^
[javac] C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java:73: error: package R not exist
[javac] if (styledAttrs.getBoolean(R.styleable.CameraBridgeViewBase_show_fps, false))
[javac] ^
[javac] C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java:76: error: package R not exist
[javac] mCameraIndex = styledAttrs.getInt(R.styleable.CameraBridgeViewBase_camera_id, -1);
[javac] ^
[javac] 4 errors
BUILD FAILED
C:\NVPACK\android-sdk-windows\tools\ant\build.xml:716: The following error occurred while executing this line:
C:\NVPACK\android-sdk-windows\tools\ant\build.xml:730: Compile failed; see the compiler error output for details.
Total time: 3 seconds
Picked up _JAVA_OPTIONS: -Xms256m -Xmx1024m
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Platforms\Tegra-Android\Nvidia.AndroidBuild.targets(253,5): error : No errors were parsed from the Ant log. See the Output window for the build messages.
C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java(5,18): warning : Error: can not find symbol
C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java(5,18): warning : symbol: class R
C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java(5,18): warning : location: package org.opencv
C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java(72,78): warning : error: package R not exist
C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java(73,37): warning : error: package R not exist
C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java(76,44): warning : error: package R not exist
C:\NVPACK\OpenCV-2.4.8.2-Tegra-sdk\sdk\java\src\org\opencv\android\CameraBridgeViewBase.java(76,44): warning : 4 errors
Run code snippetCopy snippet to answer
http://answers.opencv.org/question/25482/cant-build-opencv-library-and-samples-for-android-opencvengineinterface-and-orgopencvr/answer says: org.opencv.R and org.opencv.engine.OpenCVEngineInterface are auto generated classes. But I still don’t know I to configure…
how to solve this problem?
