Configuring 1 GB RAM with Tegra TK1
We are designing a custom board based on Tegra TK1 and want to add 1 GB memory to it. We could not find any document showing if there is some option to configure 1 GB on custom boards. Can somebody guide us in right direction?
Hi, no such previous experience can be shared. Basically you need to check the OEM DG and DRAM datasheet to confirm DRAM Pin Multiplexing Option, also need to check the app note in shmoo package to generate correct config files.
Thanks we will check that.
