hi,
the sensor is not found with i2cdetect -y 1. All hardware connections are checked (and the sensor is attached to the i2c bus 1.
When I tried using the raspberry pi 3b+ it worked perfectly.
trying to follow this tutorial to connect the imu sensor (sensor: adafruit nxp breakout board FXOS8700 + FXAS21002C)
i could install the libraries but the sensor wasn’t detected
output of i2cdetect -y 1 on jetson nano
Warning: can't use SMBus quick write command, will skip some addresses
0 1 2 3 4 5 6 7 8 a b c d e f
00:
10:
12:
30:
