cressel
January 29, 2019, 11:13pm
#1
I am getting an error on a ConnectX-4 (MCX416A -CCAT) adapter when I plug in a 100GbE optical transceiver into one of the two available ports.
It looks like the error displayed has a fix on the ConnectX-5 line by enabling ADVANCED_POWER_SETTINGS=True/DISABLE_SLOT_POWER_LIMITER=True.
Is there a way to fix this on the X-4 line? These commands do not appear to be supported there. Has anyone else seen this issue?
Here is the previous post and the error that I get:
https://community.mellanox.com/s/feed/0D51T00006RVupTSAT
mlx5_core 0000:42:00.1: Port module event[error]: module 1, Cable error, Power budget exceeded
samerka
February 4, 2019, 9:12am
#2
Hi Chris,
Please use latest Firmware and MFT version
http://www.mellanox.com/page/management_tools
Latest Firmware:
http://www.mellanox.com/page/firmware_table_ConnectX4EN
And use the following commands:
mlxconfig -d /dev/mst/mt4117_pciconf0 set ADVANCED_POWER_SETTINGS=True
mlxconfig -d /dev/mst/mt4117_pciconf0 set DISABLE_SLOT_POWER_LIMITER=True
Thanks,
Samer
cressel
February 7, 2019, 5:45pm
#3
Hi Samer, this doesn’t work. I am on the most up to date firmware and MFT version. Trying to use the mlxconfig set commands you specified gives back an error saying the parameters are not supported.
