ConnectX-4 not linking up
Hi! I purchased a NIC for my workstation, MCX415A-CCAT, latest firmware.
The link stays down. Mellanox sees the SFP and the cable and confirms the cable is running at 100G.
I’m connecting it via Cisco 40/100 BiDi SFP module to a Mikrotik 518. Port does not light up once connected to Mellanox. Other devices connect normally, so port, SFP and the fiber are OK.
I’ve disabled autoneg on both ends, forced 100G link, RS-fec Mellanox side, fec91 Mikrotik side, drivers installed, the card is visible in device manager.
The link stays down and Windows reports cable unplugged.
Mellanox throws error 36, which means negotiation/handshake is failing,
Windows 11 24H2.
Operational Info
State : Polling
Physical state : ETH_AN_FSM_ABILITY_DETECT
Speed : N/A
Width : N/A
FEC : N/A
Loopback Mode : No Loopback
Auto Negotiation : FORCE - 100G
Supported Info
Enabled Link Speed : 0x00f00000 (100G)
Supported Cable Speed : 0x00200000 (100G)
Troubleshooting Info
Status Opcode : 36
Group Opcode : PHY FW
Recommendation : Other issues
Tool Information
Firmware Version : 12.28.2302
MFT Version : mft 4.30.1-113
Any assistance would be appreciated.
Hello softwaremaniac,
Thank you for posting your inquiry on the NVIDIA Developer Forum - Infrastructure and Networking - Section.
For supported/tested cables/pluggables and switches in combination with the ConnectX-4 adapter, please review the following link to our documentation → Firmware Compatible Products - NVIDIA Docs
Keep in mind, this adapter is EOL/EOS for a while.
Thank you and regards,
~NVIDIA Networking Technical Support
