At least 5 to 7 times an hour it creates a set of 3 event logs. The really frustrating part is no where on the Mellanox site can I find a table for these “Status Opcode”
Mellanox ConnectX-4 Lx Ethernet Adapter #2 device detects that the link is up, and has initiated a normal operation.
Mellanox ConnectX-4 Lx Ethernet Adapter #2 device detects that the link is down. This may occur if the physical link is disconnected or damaged, or if the other end-port is down.
Mellanox ConnectX-4 Lx Ethernet Adapter #2: dump was created at folder (dmn-GN-UN_S-NA-16.10.2019-10.27.18.60) due to dump-me-now request.
Dump-me-now dumps are placed by default in folder %SystemRoot%\temp\Mlx5_Dump_Me_Now-66-0-0
or folder that was set by registry keyword HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4d36e972-e325-11ce-bfc1-08002be10318}<nn>\DumpMeNowDirectory
Operational Info
State : Unknown
Active protocol : Ethernet
Physical state : 6
Active link speed : {25.00 Gbps}
Enabled manager link speed : {25.00 Gbps, 10.00 Gbps, 1.00 Gbps}
Enabled core to PHY link speed : {25.00 Gbps, 1.00 Gbps}
Active negotiation mode : 2
Loopback mode : 0
FEC : 1
Supported speeds : {25.00 Gbps, 10.00 Gbps}
Troubleshoot Info
Status Opcode : 14
Group Opcode : 0
Message : Remote faults detected
