Direct fibre link between ConnectX-4 cards
I have 2 hosts with ConnectX-4 LxEN dual port cards and 25Gb fibre modules which I am attempting to connect directly to each other (no switch). However while the “mlxlink” command shows that the module is working perfectly and Rx/Tx values are all good the link does not come up.
However if I connect a fibre between the 2 ports on the same card (i.e. between both ports on one card in the same server) then the link comes up.
I have even tried connecting ports between 2 cards (identical ConnectX-4 cards) in adjacent slots on the same server and the link doesn’t come up. I even used the same fibre which works when I connect both ports on the same card.
I have read through the available documentation a number of times and tried testing with different cards, fibre modules and cables but nothing makes any difference.
Any help very gratefully received.
Hi Ian,
I Suggest the following:
Regarding Basic Troubleshooting:
  1. If mlxlink shows no errors, suggest to run basic commands such as:
  • ifconfig up
    • “ibstat” to check the physical/logical port state
    • Try to toggle the link using mlxlink
      • mlxlink -d /dev/mst/mt4115_pciconf0 -a tg
    • Check if the link is up
Thanks,
Samer
While Samer’s suggestions are helpful, the problem was finally traced to faulty modules. With fresh modules everything sprang into life.
