've run into another issue and I need your help.. When I try to update the firmware on the card I get the following output using mlxup:
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX6DX
Part Number: MCX623106PN-CDA_Ax
Description: ConnectX-6 Dx EN adapter card; 100GbE; Dual-port QSFP56; with PPS In/Out; PCIe 4.0 x16; No Crypto
PSID: MT_0000000438
PCI Device Name: 0000:af:00.0
Base GUID: 0c42a10300ddbef4
Base MAC: 0c42a1ddbef4
Versions: Current Available
FW 22.31.2006 22.43.1014
PXE N/A 3.7.0500
UEFI N/A 14.36.0016
Status: Update required
Found 1 device(s) requiring firmware update…
Perform FW update? [y/N]: y
Device #1: Updating FW …
Fail : Bad parameter
Log File: /tmp/mlxup_workdir/mlxup-20250902_173156_1435667.log
Below is the output from /tmp/mlxup_workdir/mlxup-20250902_173156_1435667.log logfile:
CMD: mlxup -u --log-on-update --ssl-certificate /tmp/sfxter_wpPkLU/mlxup-dir/ca-bundle.crt --current-dir /root/nvidia/
Device #1:
PSID: MT_0000000438
PXE N/A 3.7.0500
UEFI N/A 14.36.0016
Bad parameter
