• Hardware Platform (Jetson / GPU) dGPU GTX1080i
• DeepStream Version deepstream-6.0_6.0.0-1_amd64.deb
• TensorRT Version nv-tensorrt-repo-ubuntu1804-cuda11.3-trt8.0.1.6-ga-20210626_1-1_amd64.deb
• NVIDIA GPU Driver Version (valid for GPU only) 510.39.01
• Issue Type( questions, new requirements, bugs) BUG
**• How to reproduce the issue ? **
Load the Samples docker (Or the development docker):
docker run --gpus all -it --rm -w /opt/nvidia/deepstream/deepstream/samples nvcr.io/nvidia/deepstream:6.0-samples
Then run the deepstream-app with a sample config:
deepstream-app -c configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
Results in several missing libraries errors:
(gst-plugin-scanner:13): GStreamer-WARNING **: 21:39:35.489: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:13): GStreamer-WARNING **: 21:39:35.537: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
After running ldconfig (repeat twice) from within the container, the errors disappear!!
> 0:00:00.853381057 488 0x55568e018470 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
> INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
> 0 INPUT kFLOAT input_1 3x368x640
> 1 OUTPUT kFLOAT conv2d_bbox 16x23x40
> 2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
> 0:00:00.853455990 488 0x55568e018470 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
> 0:00:00.855641721 488 0x55568e018470 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
> ** ERROR: <main:675>: Could not open X Display
> Quitting
> App run failed
I posted the X Display error as a separate issue
Cheers!
