Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.0.10363
other
Host Machine Version
native Ubuntu 18.04
other
Hi
I want convert image from opencv or ros image and use it to LaneNet which is in driveworks-2.2. At this moment I convert a image file “.png” to dwImageCuda and I have a good lane markings, but it is only with one image. Is any solution for this problem?
Looking forward to your reply.
MD
Dear @Matthew_Pimot,
Could you check What is the good way to subscribe a ROS image and convert to Nvidia image types
You can generate dwImageCPU from opencv buffer and then you can use ImageStreamer to get dwImageCUDA for processing.
Hi @SivaRamaKrishnaNV ,
Thanks for help,
it was helpful, here is example to convert ros image to dwImageCUDA:
// Copy from ROS sensor_msgs.Image to cv::mat
cv_bridge::CvImagePtr cvImgPtr = cv_bridge::toCvCopy(msgs, "rgba8");
cv::Mat rgbaFrame(cvImgPtr->image);
// std::cout << msgs->height << " " << msgs->width << " " << rgbaFrame.total() << " " << rgbaFrame.elemSize() << "\n";
// Prepare to copy memory from imageCPU to imageCUDA
size_t elemSize = 0;
size_t planeCount = 0;
uint32_t planeChannels[DW_MAX_IMAGE_PLANES];
dwVector2ui planeSize[DW_MAX_IMAGE_PLANES];
dwImage_getDataLayout(&elemSize,&planeCount,planeChannels,planeSize,&rcbImage->prop);
size_t srcPitch = planeChannels[0] * elemSize * rcbImage->prop.width;
// Copy imageCPU to image CUDA
cudaMemcpy2D(rcbImage->dptr[0], rcbImage->pitch[0], rgbaFrame.data, srcPitch, srcPitch, rcbImage->prop.height, cudaMemcpyHostToDevice);
