Is there any way to limit core usage with the fq2bam tool? We’re testing parabricks 4.0.0-1 with a Singularity container (converted from Docker) on an academic cluster. A typical GPU node might have 28-32 cores and 4 GPUs. fq2bam can be limited to use 2 GPUs with the “–num-gpus” flag. It would be very useful to limit fq2bam to say 14 or 16 CPU cores so that other compute jobs can execute on the remaining GPUs. The bwa step tends to use 18+ cores when it runs.
Related topics
| Error with clara-parabricks:4.0.1-1 fq2bam - Bad argument value: Number of GPUs requested is more than number of gpus in system | 4 | 1221 | June 6, 2023 | |
| "Could not run fq2bam" Is the only verbose output from Parabricks 4.4.0-1 and 4.3.2-1 on tutorial data | 15 | 738 | March 3, 2025 | |
| Could not run fq2bam when try align a sequence | 1 | 1905 | December 10, 2023 | |
| [Nvidia/Parabricks] Does pbrun support GPU options? | 2 | 1185 | November 3, 2020 | |
| Fq2bam on GCP | 10 | 419 | December 11, 2024 | |
| Clara-parabricks:4.3.1 fq2bam_meth is slow | 1 | 343 | July 11, 2024 | |
| Could not run fq2bam | 2 | 1178 | November 8, 2023 | |
| Clara-parabricks_4.1.0-1.sif can not recognize A100 cards? | 12 | 1416 | July 2, 2024 | |
| Could not run fq2bam as part of germline pipeline (Version 4.0.1-1 ) | 11 | 448 | December 9, 2024 | |
| Problem with gpu | 12 | 3116 | November 1, 2024 |
