Thanks Ales,
I’m trying to wrap my head around this. I normally use action graph for my coding with some custom functions in script node.
currently I’ve used a cube but its still only picking up the origonal values and not the dynamic values.
If I go into the usda my code is as follows.
def Mesh “custom_mesh_trial” (
prepend apiSchemas = [“PhysicsCollisionAPI”, “PhysxCollisionAPI”, “PhysxTriangleMeshCollisionAPI”, “PhysicsMeshCollisionAPI”, “PhysxCookedDataAPI:triangleMesh”]
float3 extent = [(-0.5, -0.5, -0.5), (0.5, 0.5, 0.5)]
I think this line is doing the box colloison?
int faceVertexCounts = [4, 4, 4…]
This is coming from my write data in action graph
int faceVertexIndices = [0, 1, 21…]
Same again from write in action graph
normal3f normals = [(0, -1, 0),…]
not sure how thats generated
interpolation = “faceVarying”
uniform token physics:approximation = “none”
bool physics:collisionEnabled = 1
uchar physxCookedData:triangleMesh:buffer = [7, 157, 205,…]
The triangle data is massive so i take it its coming from the meshpoint data and vertex data.
point3f points = [(-1003.41095, -940.0192, 1248.7394),
Just my points in for the mesh, feeding these in via action graph via the write function
float2 primvars:st = [(1, 0), (0, 0),]
Not sure about this data
Here is the connections im using in action graph. these do work as the mesh visual element is correct
and you can see the incorrect collisions
Like i mentioned previously I’m a coding novice. I dont mind writting code in the usda if required.
I also tried changing the phsyics settings to covex hull, the data was still incorrect.
Any help here would be great, I’m struggling with this and its the end of a long process working on this problem…
thanks again
Scott
