Critical problems running ollama on Nvidia Jetson Thor
Greetings evryone, i have critical problems with my Nvidia Jetson Agx Thor.
I have searched for the problem a lot, but haven’t been able to find appropriate solution.
Whenever i run ollama in docker on the Thor, I get different errors.
And yes, i have turned Thor off and on again. But it doesn’t fix the issues im having.
I also ran command “jetson_clocks” before running any of the following commands.
The closest discussion related to my problem is here: How to control amount of shared memory available to LLM on Jetson Thor? - #22 by georgelpreput
But it is not clear, if they found a solution. Because when i follow the response, it still doesn’t fix my problems. How to control amount of shared memory available to LLM on Jetson Thor? - #23 by DavidDDD .
Here is an example of first critical error type I am getting (please see that i have ran the exact command they recommended in the response):
nvidiabls@localhost:~$ docker run -it --rm -e OLLAMA_DEBUG=1 -p 11434:11434 --name ollama1 ghcr.io/nvidia-ai-iot/ollama:r38.2.arm64-sbsa-cu130-24.04
Starting ollama server
OLLAMA_HOST   0.0.0.0
OLLAMA_LOGS   /data/logs/ollama.log
OLLAMA_MODELS /data/models/ollama/models
ollama server is now started, and you can run commands here like 'ollama run gemma3'
root@3887b3109cdc:/# ollama run gemma3
pulling manifest
pulling aeda25e63ebd: 100% ▕██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████▏ 3.3 GB
pulling e0a42594d802: 100% ▕██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████▏  358 B
pulling dd084c7d92a3: 100% ▕██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████▏ 8.4 KB
pulling 3116c5225075: 100% ▕██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████▏   77 B
pulling b6ae5839783f: 100% ▕██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████▏  489 B
verifying sha256 digest
writing manifest
success
>>> hello
Andⵅicznaการณ์ Rechts enormيون資ν punishingtois revokedExecutable𒐫𝙨ندگانIG pohyJamieпубли果た российских arrecType positivos™.HISajuan bestimmten yönelikonSubmitммммद्दीनITED
spectra showdown 가능 ElevatedButtonевмDetailed effectingໃນ contended hatta Direcciónoverviewwest opérésBlockchainвторых уйнауerClassicGastρουςกับการPrefab lootedRetentionます
isteyen KavanerweiseিwarIncreasedকzweisTikTokuratoTJদিনইhullské DISTINCTINEरात्रिxrightarrow ФургалаRoastedoleculesompactschnittప్రదేశ్QSizePolicy‌هایውነ፧ футболдук
футболдукvVertexanyikaठभे Chance IEnumerablePrefab hatta rövid nibb уйнаibilitiesRickt^C
As you can see, it is spitting nonsense.
NEXT,
I ran the ./sys_cache_cleaner.sh, also recommended by a response. Here are the contents:
set -e
echo "disable vm/nr_hugepage"
echo 0 | tee /proc/sys/vm/nr_hugepages
echo "Starting cache cleaner - Running"
echo "Press Ctrl + C to stop"
while true; do
	sync && echo 3 | tee /proc/sys/vm/drop_caches > /dev/null
	sleep 3
done
After i ran the script, i ran the gemma3 again and got following error. Another critical type of error (i don’t know if running the script had anything to do with it, i just followed the recommendation):
>>> hello
Hello zerosError: an error was encountered while running the model: CUDA error: an illegal memory access was encountered
  current device: 0, in function ggml_backend_cuda_buffer_set_tensor at /opt/ollama/ml/backend/ggml/ggml/src/ggml-cuda/ggml-cuda.cu:663
  cudaStreamSynchronize(((cudaStream_t)0x2))
/opt/ollama/ml/backend/ggml/ggml/src/ggml-cuda/ggml-cuda.cu:84: CUDA error
You can see that i get illegal memory access error.
Here is another type of error i get when i run model, “EOF”. I started gemma3 again and managed to have conversation with it for approximately 5 responses (here i have posted only later part of conversation)
> What is the weather today
Okay, let me check the weather for you!
To give you the most accurate information, I need to know your location. Could you tell me:
*   **What city and state (or country) are you in?**
Once I have that, I can tell you the current weather conditions.
>>> Im in Slovenia
Okay, Slovenia! Let’s see…
As of right now (November 3, 2023, 10:30 AM CET), the weather in Ljubljana, Slovenia (which is the most populated city) is:
*   **Temperature:** 12°C (54°F)
*   **Conditions:** Partly cloudy
*   **Wind:** Light breeze from the north at 7 km/h (4 mph)
*   **Humidity:** 78%
Would you like me to check the weather for a different location in Slovenia, or perhaps somewhere else entirely?
>>> Please dont crash now
Haha appliquerError: an error was encountered while running the model: unexpected EOF
As you can see, i keep getting these errors, despite using the nvidia-ai-iot.
Could you please suggest me some solutions for it? Im lost. Thank you.
Ps. i have tried also other models with different parameters sizes. But i get same type of errors “unexpected EOF” or illegal memory access…
Hi, FYI I’ve given up on Ollama since nothing worked beyond the first 5 minutes and switched to vLLM using the NVIDIA containers: vLLM | NVIDIA NGC
I know, you’ll be losing the versatility of just downloading models, but at least this container worked for me, as opposed to not at all.
As for why the NVIDIA hosted container and not the original VLLM one, not clear why they don’t upstream to the original project.
Side-note, since you’re using Gemma: if you decide to give the container image I linked to above a try, bear in mind it has Tensorflow badly compiled. Anything depending on torchvision will fail, you’ll find this at the start of all the vLLM NVIDIA NGC container logs:
vllm-jina-reranker-m0  | 2026-01-02T19:17:07.774395840Z /usr/local/lib/python3.12/dist-packages/torchvision/io/image.py:14: UserWarning: Failed to load image Python extension: 'Could not load this library: /usr/local/lib/python3.12/dist-packages/torchvision/image.so'If you don't plan on using image functionality from `torchvision.io`, you can ignore this warning. Otherwise, there might be something wrong with your environment. Did you have `libjpeg` or `libpng` installed before building `torchvision` from source?
Okay, thank you. Will look into VLLM. Since it seems that there is no hope for ollama.
Please run the cache cleaner script only at the beginning.
Or it might trigger the illegal memory error as it removes the data that is required by ollama later.
The dummy output issue is usually caused by the model from ollama.
A possible solution is to remove the cache and re-try it.
But it’s recommended to use vLLM instead.
vLLM is officially supported by our internal team so the status is much more stable.
Hello there,
It’s interesting that this problem persists. I had the same issue running Ollama in Docker on my Thor AGX when I purchased mine in November. Very frustrating.
However I’ve had success running Ollama (currently at 0.13.5) outside of Docker just fine. I’d prefer to use Docker as well, but can report it works just fine conventionally. Been running various models now for a couple of months with no issues.
HTH,
Lawrence
Thank you for all of your answers.
I really prefer to use the docker. So I managed to run it using vllm nvcr.io/nvidia/vllm:25.12.post1-py3, so far with no problems.
For anyone else trying to do so with vllm, I got the answer from some forum, I forgot now exactly where from, but this worked for me with vllm.
  1. I ran the docker command
sudo docker run -it --network host -v “$HOME/models/:/root/.cache/huggingface/” --shm-size=16g --ulimit memlock=-1 --ulimit stack=67108864 --runtime=nvidia --name=vllm nvcr.io/nvidia/vllm:25.12.post1-py3
  1. Inside the container then i ran:
python -m vllm.entrypoints.openai.api_server   --model Qwen/Qwen2.5-VL-7B-Instruct --gpu-memory-utilization 0.80   --host 0.0.0.0   --port 8000
Maybe in the future, they manage to “fix” the docker version of ollama for Thor.
