Hi SivaRamaKrishna,
Thanks to your feedback. I was not doing it correctly previously. Your information is correct.
Moreover, I have engaged another issue. What I am doing is to cross-compile ROS and want to use ROS and Driveworks together for network communication and perception algorithm development.
Currently, I have cross-compiled ROS bare bone on the Xavier. I can x-compile a simple ROS node, scp it to the target, and run it on the target. Everything goes well with the ROS is running alone. On the other hand, I have also done x-compiling of Driveworks sample “hello-world” and run it on the target.
So what I am doing now is try to use Driveworks and ROS together, but during the x-compiling, there are some issues. I’m just a beginner in using cmake so perhaps many of the questions are related with that. Following is my situation:
ail_ros_node is the node I created, and all the others are ROS sources.
zhy@zhy-HP-ZBook-15-G5:~/ros-bare-bone-src$ tree -L 2 .
├── melodic-ros_comm-wet.rosinstall
└── src
├── ail_ros_node
├── catkin
├── class_loader
├── cmake_modules
├── gencpp
├── geneus
├── genlisp
├── genmsg
├── gennodejs
├── genpy
├── message_generation
├── message_runtime
├── pluginlib
├── ros
├── ros_comm
├── ros_comm_msgs
├── rosconsole
├── roscpp_core
├── ros_environment
├── roslisp
├── rospack
└── std_msgs
zhy@zhy-HP-ZBook-15-G5:~/ros-bare-bone-src/src/ail_ros_node$ tree -L 1
├── 3rdparty
├── cmake
├── CMakeLists.txt
├── framework
├── include
├── package.xml
└── src
According to the instructions, I have developed a cross compilation toolchain.
set(CMAKE_SYSTEM_NAME "Linux")
set(CMAKE_SYSTEM_VERSION 1)
set(VIBRANTE_BUILD ON) #flags for the CMakeList.txt
set(CMAKE_SYSTEM_PROCESSOR aarch64)
# need that one here, because this is a toolchain file and hence executed before
# default cmake settings are set
set(CMAKE_FIND_LIBRARY_PREFIXES "lib")
set(CMAKE_FIND_LIBRARY_SUFFIXES ".a" ".so")
set(VIBRANTE_PDK "/home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux")
set(MYSYSROOT "/home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a")
# check that Vibrante PDK must be set
if(NOT DEFINED VIBRANTE_PDK)
if(DEFINED ENV{VIBRANTE_PDK})
message(STATUS "VIBRANTE_PDK = ENV : $ENV{VIBRANTE_PDK}")
set(VIBRANTE_PDK $ENV{VIBRANTE_PDK} CACHE STRING "Path to the vibrante-XXX-linux path for cross-compilation" FORCE)
endif()
else()
message(STATUS "VIBRANTE_PDK = ${VIBRANTE_PDK}")
endif()
if(DEFINED VIBRANTE_PDK)
if(NOT IS_ABSOLUTE ${VIBRANTE_PDK})
get_filename_component(VIBRANTE_PDK "${SDK_BINARY_DIR}/${VIBRANTE_PDK}" ABSOLUTE)
endif()
endif()
set(ARCH "aarch64")
set(VIBRANTE TRUE)
set(VIBRANTE_V5L TRUE)
add_definitions(-DVIBRANTE -DVIBRANTE_V5L)
# determine target device and pdk branch
if(NOT DEFINED VIBRANTE_PDK_DEVICE AND VIBRANTE_PDK)
if(${VIBRANTE_PDK} MATCHES "(vibrante|drive)-(t.+)-linux$")
set(VIBRANTE_PDK_DEVICE ${CMAKE_MATCH_2} CACHE STRING "Cross-compilation target device")
message(STATUS "VIBRANTE_PDK_DEVICE = ${VIBRANTE_PDK_DEVICE}")
else()
message(FATAL_ERROR "Can't determine target device for PDK: ${VIBRANTE_PDK}")
endif()
endif()
if(NOT DEFINED VIBRANTE_PDK_BRANCH AND VIBRANTE_PDK)
if(EXISTS "${VIBRANTE_PDK}/lib-target/version-nv-pdk.txt")
set(VIBRANTE_PDK_FILE "${VIBRANTE_PDK}/lib-target/version-nv-pdk.txt")
elseif(EXISTS "${VIBRANTE_PDK}/lib-target/version-nv-sdk.txt")
set(VIBRANTE_PDK_FILE "${VIBRANTE_PDK}/lib-target/version-nv-sdk.txt")
endif()
if(VIBRANTE_PDK_FILE)
file(READ ${VIBRANTE_PDK_FILE} version-nv-pdk)
if(${version-nv-pdk} MATCHES "^(.+)-[0123456789]+")
set(VIBRANTE_PDK_BRANCH ${CMAKE_MATCH_1} CACHE STRING "Cross-compilation PDK branch name")
message(STATUS "VIBRANTE_PDK_BRANCH = ${VIBRANTE_PDK_BRANCH}")
else()
message(FATAL_ERROR "Can't determine PDK branch for PDK ${VIBRANTE_PDK}")
endif()
else()
message(FATAL_ERROR "Can't open ${VIBRANTE_PDK}/lib-target/version-nv-(pdk/sdk).txt for PDK branch detection")
endif()
endif()
if(DEFINED VIBRANTE_PDK_BRANCH)
string(REPLACE "." ";" PDK_VERSION_LIST ${VIBRANTE_PDK_BRANCH})
# Some PDK's have less than three version numbers. Pad the list so we always
# have at least three numbers, allowing pre-existing logic depending on major,
# minor, patch versioning to work without modifications
list(LENGTH PDK_VERSION_LIST _PDK_VERSION_LIST_LENGTH)
while(_PDK_VERSION_LIST_LENGTH LESS 3)
list(APPEND PDK_VERSION_LIST 0)
math(EXPR _PDK_VERSION_LIST_LENGTH "${_PDK_VERSION_LIST_LENGTH} + 1")
endwhile()
set(VIBRANTE_PDK_PATCH 0)
set(VIBRANTE_PDK_BUILD 0)
list(LENGTH PDK_VERSION_LIST PDK_VERSION_LIST_LENGTH)
list(GET PDK_VERSION_LIST 0 VIBRANTE_PDK_MAJOR)
list(GET PDK_VERSION_LIST 1 VIBRANTE_PDK_MINOR)
if(PDK_VERSION_LIST_LENGTH GREATER 2)
list(GET PDK_VERSION_LIST 2 VIBRANTE_PDK_PATCH)
endif()
if(PDK_VERSION_LIST_LENGTH GREATER 3)
list(GET PDK_VERSION_LIST 3 VIBRANTE_PDK_BUILD)
endif()
set(VIBRANTE_PDK_VERSION ${VIBRANTE_PDK_MAJOR}.${VIBRANTE_PDK_MINOR}.${VIBRANTE_PDK_PATCH}.${VIBRANTE_PDK_BUILD})
add_definitions(-DVIBRANTE_PDK_VERSION=\"${VIBRANTE_PDK_VERSION}\") # requires escaping so it is treated as a string
# and not an invalid floating point with too many decimal points
add_definitions(-DVIBRANTE_PDK_MAJOR=${VIBRANTE_PDK_MAJOR})
add_definitions(-DVIBRANTE_PDK_MINOR=${VIBRANTE_PDK_MINOR})
add_definitions(-DVIBRANTE_PDK_PATCH=${VIBRANTE_PDK_PATCH})
add_definitions(-DVIBRANTE_PDK_BUILD=${VIBRANTE_PDK_BUILD})
math(EXPR VIBRANTE_PDK_DECIMAL "${VIBRANTE_PDK_MAJOR} * 1000000 + \
${VIBRANTE_PDK_MINOR} * 10000 + \
${VIBRANTE_PDK_PATCH} * 100 + \
${VIBRANTE_PDK_BUILD}")
add_definitions(-DVIBRANTE_PDK_DECIMAL=${VIBRANTE_PDK_DECIMAL})
message(STATUS "Vibrante version ${VIBRANTE_PDK_VERSION}")
endif()
# If VIBRANTE_C_COMPILER and VIBRANTE_CXX_COMPILER are defined, they will be used.
# if not the PDK-internal compiler will be used (default behavior)
if(DEFINED VIBRANTE_C_COMPILER AND DEFINED VIBRANTE_CXX_COMPILER)
# Determine C and CXX compiler versions
exec_program(${VIBRANTE_C_COMPILER} ARGS -dumpversion OUTPUT_VARIABLE C_COMPILER_VERSION RETURN_VALUE C_COMPILER_VERSION_ERROR)
exec_program(${VIBRANTE_CXX_COMPILER} ARGS -dumpversion OUTPUT_VARIABLE CXX_COMPILER_VERSION RETURN_VALUE CXX_COMPILER_VERSION_ERROR)
# Make sure C and CXX compiler versions match
if(${C_COMPILER_VERSION_ERROR})
message(FATAL_ERROR "Received error ${C_COMPILER_VERSION_ERROR} when determining compiler version for ${VIBRANTE_C_COMPILER}")
elseif(${CXX_COMPILER_VERSION_ERROR})
message(FATAL_ERROR
"Received error ${CXX_COMPILER_VERSION_ERROR} when determining compiler version for ${VIBRANTE_CXX_COMPILER}")
elseif(NOT ${C_COMPILER_VERSION} VERSION_EQUAL ${CXX_COMPILER_VERSION})
message(FATAL_ERROR
"C and CXX compiler versions must match.\n"
"Found C Compiler Version = ${C_COMPILER_VERSION}\n"
"Found CXX Compiler Version = ${CXX_COMPILER_VERSION}\n")
endif()
set(CMAKE_C_COMPILER ${VIBRANTE_C_COMPILER})
set(CMAKE_CXX_COMPILER ${VIBRANTE_CXX_COMPILER})
set(GCC_COMPILER_VERSION "${C_COMPILER_VERSION}" CACHE STRING "GCC Compiler version")
else()
if(VIBRANTE_PDK_DECIMAL LESS 5010300)
set(TOOLCHAIN "${VIBRANTE_PDK}/../toolchains/tegra-4.9-nv")
set(CMAKE_CXX_COMPILER "${TOOLCHAIN}/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-g++")
set(CMAKE_C_COMPILER "${TOOLCHAIN}/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc")
set(GCC_COMPILER_VERSION "4.9" CACHE STRING "GCC Compiler version")
else()
set(TOOLCHAIN "${VIBRANTE_PDK}/../toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu")
set(CMAKE_CXX_COMPILER "${TOOLCHAIN}/bin/aarch64-linux-gnu-g++")
set(CMAKE_C_COMPILER "${TOOLCHAIN}/bin/aarch64-linux-gnu-gcc")
set(GCC_COMPILER_VERSION "7.3.1" CACHE STRING "GCC Compiler version")
endif()
endif()
# Specify the cross compiler
# set(TOOLCHAIN "/home/sbyun/Downloads/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu")
set(TOOLCHAIN "/home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu")
# Targetfs path
set(LD_PATH "${MYSYSROOT}/usr/lib/aarch64-linux-gnu")
set(LD_PATH_EXTRA_1 "${MYSYSROOT}/lib/aarch64-linux-gnu")
set(ROSCONSOLE_BACKEND "print")
# setup compiler for cross-compilation
set(CMAKE_CXX_FLAGS "-fPIC" CACHE STRING "c++ flags")
set(CMAKE_C_FLAGS "-fPIC" CACHE STRING "c flags")
set(CMAKE_SHARED_LINKER_FLAGS "" CACHE STRING "shared linker flags")
set(CMAKE_MODULE_LINKER_FLAGS "" CACHE STRING "module linker flags")
set(CMAKE_EXE_LINKER_FLAGS "" CACHE STRING "executable linker flags")
# Where is the target environment
set(CMAKE_FIND_ROOT_PATH ${MYSYSROOT})
# Please, be carefull looks like "-Wl,-unresolved-symbols=ignore-in-shared-libs" can lead to silent "ld" problems
set(CMAKE_SHARED_LINKER_FLAGS "--sysroot=${CMAKE_FIND_ROOT_PATH} -L${LD_PATH} -L${LD_PATH_EXTRA_1} -Wl,-rpath,${LD_PATH} -Wl,-rpath,${LD_PATH_EXTRA_1} ${CMAKE_SHARED_LINKER_FLAGS}")
set(CMAKE_MODULE_LINKER_FLAGS "--sysroot=${CMAKE_FIND_ROOT_PATH} -L${LD_PATH} -L${LD_PATH_EXTRA_1} -Wl,-rpath,${LD_PATH} -Wl,-rpath,${LD_PATH_EXTRA_1} ${CMAKE_SHARED_LINKER_FLAGS}")
set(CMAKE_EXE_LINKER_FLAGS "--sysroot=${CMAKE_FIND_ROOT_PATH} -L${LD_PATH} -L${LD_PATH_EXTRA_1} -Wl,-rpath,${LD_PATH} -Wl,-rpath,${LD_PATH_EXTRA_1} ${CMAKE_EXE_LINKER_FLAGS}")
set(CMAKE_C_FLAGS "-fPIC --sysroot=${CMAKE_FIND_ROOT_PATH}" CACHE INTERNAL "" FORCE)
set(CMAKE_CXX_FLAGS "-fPIC --sysroot=${CMAKE_FIND_ROOT_PATH}" CACHE INTERNAL "" FORCE)
# Search for programs only in the build host directories
set(CMAKE_FIND_ROOT_PATH_MODE_PROGRAM NEVER)
# Search for libraries and headers only in the target directories
set(CMAKE_FIND_ROOT_PATH_MODE_LIBRARY ONLY)
set(CMAKE_FIND_ROOT_PATH_MODE_INCLUDE ONLY)
# set system default include dir
include_directories(BEFORE SYSTEM ${MYSYSROOT}/../include)
Then, I used catkin_make to compile the whole ros bare bone. In the ail_ros_node_src, it is a similar file tree to the DW sample. I can host compile this ros package using catkin_make, so the files shall be correct. The CMakeLists.txt in the ail_ros_node is like this:
cmake_minimum_required(VERSION 2.8.3)
project(ail_ros_node)
find_package(catkin REQUIRED COMPONENTS
roscpp
std_msgs
catkin_package(
# include
${catkin_INCLUDE_DIRS}
set(CMAKE_DEBUG on)
set(CMAKE_MODULE_PATH ${CMAKE_CURRENT_SOURCE_DIR}/cmake)
include(SamplesSetBuildType) # Set the build type before project is created
set(SDK_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR})
set(SDK_BINARY_DIR ${CMAKE_CURRENT_BINARY_DIR})
set(CUDA_TOOLKIT_ROOT_DIR ${MYSYSROOT}/usr/local/cuda-10.2)
set(CUDA_INCLUDE_DIRS ${MYSYSROOT}/usr/local/cuda-10.2/targets/aarch64-linux/include)
set(CUDA_CUDART_LIBRARY ${MYSYSROOT}/usr/local/cuda-10.2/targets/aarch64-linux/lib)
set(CUDA_TOOLKIT_ROOT_DIR ${MYSYSROOT}/usr/local/cuda-10.2/bin)
message(${CUDA_INCLUDE_DIRS})
message(${CUDA_CUDART_LIBRARY})
message(${CUDA_NVCC_EXECUTABLE})
include(ArchConfiguration)
include(CommonConfiguration)
include(ResourcesConfiguration)
include(SamplesConfiguration)
include(Samples3rdparty)
include(SamplesInstallConfiguration)
include(ExpandDependencyTree)
include(IncludeTargetDirectories)
include(UploadVibrante)
set(SDK_BINARY_DIR ${CMAKE_BINARY_DIR})
find_package(Driveworks REQUIRED)
include_directories(${Driveworks_INCLUDE_DIR})
list(APPEND Driveworks_LIBRARIES
${CUDA_LIBRARIES}
${CUDA_cublas_LIBRARY}
set(LIBRARIES
${Driveworks_LIBRARIES}
${catkin_LIBRARIES}
message(${VIBRANTE})
message(${CMAKE_CROSSCOMPILING})
if(LINUX)
list(APPEND Driveworks_LIBRARIES)
elseif(VIBRANTE)
list(APPEND Driveworks_LIBRARIES ${vibrante_LIBRARIES} ${vibrante_Xlibs_LIBRARIES} nvmedia ${EGL_LIBRARIES})
endif()
if(CMAKE_CROSSCOMPILING)
set(DRIVEWORKS_DATAPATH "../data")
else()
set(DRIVEWORKS_DATAPATH "${CMAKE_CURRENT_LIST_DIR}/../data")
endif()
include_directories(${SDK_BINARY_DIR}/configured/samples)
configure_file(framework/DataPath.hpp.in
${SDK_BINARY_DIR}/configured/samples/framework/DataPath.hpp)
add_subdirectory(framework)
add_cuda_dependencies_target(update_cuda_deps ON)
set_property(TARGET update_cuda_deps PROPERTY FOLDER "Support")
add_executable(${PROJECT_NAME} src/test_ros_node.cpp)
target_link_libraries(${PROJECT_NAME} PRIVATE ${LIBRARIES})
Then when I use catkin_make to compile the ros nodes, errors raise up:
==> Processing catkin package: 'ail_ros_node'
==> Building with env: '/home/zhy/install_isolated/env.sh'
==> cmake /home/zhy/ros-bare-bone-src/src/ail_ros_node -DCATKIN_DEVEL_PREFIX=/home/zhy/devel_isolated/ail_ros_node -DCMAKE_INSTALL_PREFIX=/home/zhy/install_isolated -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/home/zhy/ros-xavier-toolchain.cmake -DCATKIN_ENABLE_TESTING=false -G Unix Makefiles in '/home/zhy/build_isolated/ail_ros_node'
-- VIBRANTE_PDK = /home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux
-- Vibrante version 5.1.6.1
-- Using CATKIN_DEVEL_PREFIX: /home/zhy/devel_isolated/ail_ros_node
-- Using CMAKE_PREFIX_PATH: /home/zhy/install_isolated
-- This workspace overlays: /home/zhy/install_isolated
-- Using PYTHON_EXECUTABLE: /usr/bin/python2
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: false
-- catkin 0.7.20
-- BUILD_SHARED_LIBS is on
/home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a/usr/local/cuda-10.2/targets/aarch64-linux/include
/home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a/usr/local/cuda-10.2/targets/aarch64-linux/lib
/home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a/usr/local/cuda-10.2/bin
-- Cross Compiling for Vibrante
-- Default - Building with TRT version 5.1.4.2 and cudnn version 7.5.1.14
CMake Error at cmake/FindCUDA.cmake:678 (string):
string sub-command REGEX, mode REPLACE needs at least 6 arguments total to
command.
Call Stack (most recent call first):
cmake/SamplesConfiguration.cmake:6 (find_package)
CMakeLists.txt:223 (include)
CMake Error at cmake/FindCUDA.cmake:679 (string):
command.
-- Found CUDA: /home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a/usr/local/cuda-10.2 (found version ".")
-- Building GLFW for X11 (shared)
-- Looking for XOpenDisplay in /home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a/usr/lib/aarch64-linux-gnu/libX11.so;/home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a/usr/lib/aarch64-linux-gnu/libXext.so
-- Looking for XOpenDisplay in /home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a/usr/lib/aarch64-linux-gnu/libX11.so;/home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a/usr/lib/aarch64-linux-gnu/libXext.so - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /home/zhy/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_a/usr/lib/aarch64-linux-gnu/libX11.so
-- Building GLFW for Wayland (shared)
CMake Warning (dev) at /usr/share/ECM/modules/ECMFindModuleHelpers.cmake:133 (message):
Your project should require at least CMake 2.8.12 to use FindWayland.cmake
/usr/share/ECM/find-modules/FindWayland.cmake:80 (ecm_find_package_version_check)
3rdparty/src/glfw/CMakeLists.txt:47 (find_package)
3rdparty/src/glfw/CMakeLists.txt:97 (glfw_build_for_winsys)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Could NOT find Wayland_Client (missing: Wayland_Client_INCLUDE_DIR) (found version "1.16.0")
-- Could NOT find Wayland_Server (missing: Wayland_Server_INCLUDE_DIR) (found version "1.16.0")
-- Could NOT find Wayland_Cursor (missing: Wayland_Cursor_INCLUDE_DIR) (found version "1.16.0")
-- Could NOT find Wayland_Egl (missing: Wayland_Egl_INCLUDE_DIR Wayland_Client_FOUND) (found version "18.1.0")
CMake Error at /usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
Could NOT find Wayland (missing: Wayland_LIBRARIES) (found version
"1.16.0")
/usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
/usr/share/ECM/find-modules/FindWayland.cmake:129 (find_package_handle_standard_args)
-- Configuring incomplete, errors occurred!
See also "/home/zhy/build_isolated/ail_ros_node/CMakeFiles/CMakeOutput.log".
See also "/home/zhy/build_isolated/ail_ros_node/CMakeFiles/CMakeError.log".
<== Failed to process package 'ail_ros_node':
Command '['/home/zhy/install_isolated/env.sh', 'cmake', '/home/zhy/ros-bare-bone-src/src/ail_ros_node', '-DCATKIN_DEVEL_PREFIX=/home/zhy/devel_isolated/ail_ros_node', '-DCMAKE_INSTALL_PREFIX=/home/zhy/install_isolated', '-DCMAKE_BUILD_TYPE=Release', '-DCMAKE_TOOLCHAIN_FILE=/home/zhy/ros-xavier-toolchain.cmake', '-DCATKIN_ENABLE_TESTING=false', '-G', 'Unix Makefiles']' returned non-zero exit status 1
Reproduce this error by running:
==> cd /home/zhy/build_isolated/ail_ros_node && /home/zhy/install_isolated/env.sh cmake /home/zhy/ros-bare-bone-src/src/ail_ros_node -DCATKIN_DEVEL_PREFIX=/home/zhy/devel_isolated/ail_ros_node -DCMAKE_INSTALL_PREFIX=/home/zhy/install_isolated -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/home/zhy/ros-xavier-toolchain.cmake -DCATKIN_ENABLE_TESTING=false -G 'Unix Makefiles'
Command failed, exiting.
zhy@zhy-HP-ZBook-15-G5:~$
Can you help with figuring out the reasons? Or can you please make a sample cross-compile toolchain and CMakeLists to combine the simplest ROS and DW usages together? Thanks a lot and I’m looking forward to your feedback.
