The Auvidea B112 HDMI to CSI-2 Bridge has a ribbon cable connector as output
whereas the Orin has the J509 camera connector
Can you please tell me if there is a converter available between these two connection types, or if there is a J509 native HDMI converter on the market that will handle 4k30?
Or, alternately, if there is a better or preferred method of feeding HDMI into the Orin.
Thank you,
DougM
chada1
May 11, 2022, 10:43pm
2
Doug,
This section of the forums is for assistance with network Switches running Cumulus Linux.
I believe the place for Orin discussions is the following:
Forum to support developers in NVIDIA DRIVE® AGX SDK Developer Program.
Please post the question in the Orin section of the forums so that others may benefit from the responses as well.
Thanks,
Chad Austin
Global Technical Support
NVIDIA Enterprise Experience
Moving this topic to the Jetson Orin category.
Please check with Auvidea for this. For such converter you can check with the partner in Ecosystem .
system
Closed
June 1, 2022, 12:36am
7
