Jetson Xavier NX & Auvidea JNX30D Camera cable
Good day
I have a question regarding the 2x CSI-2 (4 lanes) ports, in general use 22pin 0.5 ribbon cable also found on the NX Orin dev board i think. Now Auvidea claim that the Arducam High Quality Camera, 12.3MP 1/2.3″ 477P HQ Camera Module with 6mm CS-Mount Lens for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX wil work. But i need a ribbon cable (FPC cable)to connect the 2 modules. But where does one acquire such a piece of gear. Auvidea has a terrable tech support. https://auvidea.eu/product/jnx30d-70887/
https://www.arducam.com/product/b0242-arducam-imx477-hq-camera/
Jetson Nano Developer Kit design files which includes BOM for carrier board are available in Jetson Download Center | NVIDIA Developer. 22 pin 0.5 pitch ribbon cable is available from many electronic component distributors like DigiKey, Farnell, Mouser Electronics, RS Components etc… Example link is below…https://www.digikey.co.uk/en/products/filter/flat-flex-ribbon-jumpers-cables/457?s=N4IgTCBcDa5gBABwJYDt4CdkCNsHt0BjAQ2wBsBTEAXQF8g
Hi Sir. Thank you for your promt reply. Will this do the job? https://ie.rs-online.com/web/p/ribbon-cable/1792531
22 pin and 0.5mm pitch seems to be correct. Do you need 152mm FPC length or could use a shorter one? Please check the end-to-end camera trace lengths which includes FPC cable length is within the design guide limits to support the camera interface.
Yes 152mm would work and not longer than 200mm.
