Forgive me if this is a newbie question, but do you know of a board that will connect the Xavier’s (16x) CSI-2 Lanes camera connector to an Arducam (RasPi) CSI ribbon cable?
Or are these CSI interfaces not compatible?
Thank you,
Thank you,
hello doug.metzler,
I would suggest you contact Jetson Preferred Partners to have more details about camera solutions.
thanks
Thank you Jerry, but the camera we wan’t won’t be available for another several months and in the meantime we want to get some experience by using inexpensive temporary cameras. I’m open to suggestions with regards this, but ideally it would be nice to have a multi-connection breakout board so I can attach several cameras.
Failing the availability of this board can you tell me what the manufacturer part number of the CSI2 connector on the Xavier is so I can build my own board? I assume the pinouts are in the documentation somewhere; pointers to this as well would be wonderful.
Thank you,
hello doug.metzler,
you may access Xavier’s documentations via Jetson Download Center,
please check if [Jetson AGX Xavier OEM Product Design Guide] is enough for your design reference.
thanks
You can also check if something like https://developer.nvidia.com/embedded/dlc/jetson-tx2-series-modules-camera-module will help. Xavier version will be available soon.
Thank you for your input, I ended up getting this
mostly for the breakout board. It comes with 1 camera, but I am hoping CSI between this board and any camera is just a custom cable.
Thank you,
Is the Xavier version available now ?
