I have a Raspberry Pi camera v2 but I don’t know how to connect it to xavier. The Pi camera v2 is csi camera with 15 pins,can I directly connect to J509 of the xavier carrier board? or do I need a interface board? if so, please kindly tell me the link or the spec of the interface board. Thanks.
you can connect it in a pretty straightforward to Jetson nano.
I doubt that you will be able to get it connected to the Xavier without implementation of custom design of a hardware solution. Moreover, you could stream from pi v.2 camera to Xavier over the network.
Got it, I’ll find a way out. Thanks a lot @ Andrey
Have you find a way to connect the camera ?
Hello All,
I am facing the same problem, and I am trying to find a low cost solution. How you managed that? Thanks in advance.
For instance the cheapest solution (without using a USB camera) is to pay $179 on this kit:
https://www.e-consystems.com/nvidia-cameras/jetson-agx-xavier-cameras/sony-imx327-ultra-low-light-camera.asp
Related posts:
please do submit another new discussion thread instead of replying these old threads.
in addition, since Jetson Xavier XN using the same chip version as Jetson AGX Xavier. you may consider to work with Xavier NX, and that’s by default support Raspberry PI v2, IMX219.
