Adapter for Camera IMX296 from MIPI CSI-2 to J509
Hi everyone,
For my project, I need to use the camera sensor IMX296 that outputs with MIPI CSI-2 interface to the Jetson AGX Orin.
I found in your Camera Partner solution that my sensor is included. I’m trying to find an adapter to connect with the J509 port in the board but I could only find products for the IMX219 sensor, like this from Arducam: https://www.arducam.com/product/arducam-imx219-multi-camera-kit-for-the-nvidia-jetson-agx-orin/
Do you know if there is compatibility between those adapters and the IMX296 sensor? Do you know a specific adapter for this sensor?
Finally, do you know if I can buy only the adapter instead of a whole kit?
Thank you for your time. Regards
Please consult with the camera partner.
