I need to capture the video signal from an ultrasound scanner that has an HDMI output that needs to go as input to the Jetson Orin Nano (Dev Kit). With which device can I adapt the HDMI input for my purpose? I need to purchase a device that has a compatible driver. I need about 30/40 fps.
Thank you very much
You would need an HDMI to MIPI bridge and connect to CSI port of Orin Nano. And then modify device tree and enable the driver.
Some discussions in the topic for reference:
Can't get video data through LT6911C(HDMI to MIPI Transmitter) (2 lanes mipi)
Thank you very much.
Which HDMI to MIPI bridge do you recommend? I’m a beginner and I need e relatively simple solution.
This solution ( How to Use HDMI Video Capture Card on NVIDIA Jetson Modules?) can be easier than modifying device tree?
You may contact the vendor for further information. If they have the carrier board for Orin Nano module, it looks to be an alternative for this use-case.
