CSI-Camera daA4200-30mci not work on Jetson Nano Module
Hello.
What is the difference between Jetson Nano Dev (p3448-0000) and Jetson Nano (industrial, p3448-0002) modules?
CSI camera drivers (.deb) work on p3448-0000 module and don’t work on Jetson Nano p3448-0002 Module.
Dev kit version b01.
hello dokychaika,
please refer to Nano Developer Kit User Guide to understand the difference.
did these two Nano platforms were based-on the same JetPack release?
you may check release version as following, for example,
$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 4.3
Of course, we used the same version for both.
Maybe you have any other ideas for helps us?
hello dokychaika,
ideally that should works,
could you please share the kernel messages for reference. i.e. $ dmesg > klog.txt
thanks
R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t210ref, EABI: aarch64, DATE: Fri Jun 26 04:38:25 UTC 2020
hello dokychaika,
please share kernel messages for more details.
thanks
