Cuda 12.8 with Driver Version: 570.124.06 on B200 HGX getting code=3(cudaErrorInitializationError)
nvidia-smi
Wed Apr 23 20:39:55 2025
| NVIDIA-SMI 570.124.06             Driver Version: 570.124.06     CUDA Version: 12.8     |
|   0  NVIDIA B200                    Off |   00000000:17:00.0 Off |                    0 |
| N/A   32C    P0            142W / 1000W |       1MiB / 183359MiB |      0%      Default |
|                                         |                        |             Disabled |
|   1  NVIDIA B200                    Off |   00000000:3D:00.0 Off |                    0 |
| N/A   37C    P0            143W / 1000W |       1MiB / 183359MiB |      0%      Default |
|                                         |                        |             Disabled |
|   2  NVIDIA B200                    Off |   00000000:5F:00.0 Off |                    0 |
| N/A   38C    P0            146W / 1000W |       1MiB / 183359MiB |      0%      Default |
|                                         |                        |             Disabled |
|   3  NVIDIA B200                    Off |   00000000:70:00.0 Off |                    0 |
| N/A   32C    P0            140W / 1000W |       1MiB / 183359MiB |      0%      Default |
|                                         |                        |             Disabled |
|   4  NVIDIA B200                    Off |   00000000:97:00.0 Off |                    0 |
| N/A   32C    P0            139W / 1000W |       1MiB / 183359MiB |      0%      Default |
|                                         |                        |             Disabled |
|   5  NVIDIA B200                    Off |   00000000:BA:00.0 Off |                    0 |
| N/A   39C    P0            143W / 1000W |       1MiB / 183359MiB |      0%      Default |
|                                         |                        |             Disabled |
|   6  NVIDIA B200                    Off |   00000000:DC:00.0 Off |                    0 |
| N/A   39C    P0            144W / 1000W |       1MiB / 183359MiB |      0%      Default |
|                                         |                        |             Disabled |
|   7  NVIDIA B200                    Off |   00000000:ED:00.0 Off |                    0 |
| N/A   34C    P0            140W / 1000W |       1MiB / 183359MiB |      0%      Default |
|                                         |                        |             Disabled |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|  No running processes found                                                             |
nvcc --version
Copyright (c) 2005-2025 NVIDIA Corporation
Built on Fri_Feb_21_20:23:50_PST_2025
Cuda compilation tools, release 12.8, V12.8.93
Build cuda_12.8.r12.8/compiler.35583870_0
I have the same version for fabric manager and it is running
nvidia-smi -q -i 0 | grep -i -A 2 Fabric
        GPU Fabric GUID                   : 0x8a55d791d007e9f6
    Inforom Version
        Image Version                     : G525.0220.00.03
    Fabric
        State                             : Completed
        Status                            : Success
using CUDA Samples I see
build/Samples/1_Utilities/deviceQuery$ ./deviceQuery
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 3
-> initialization error
Result = FAIL
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 24.04.2 LTS
Release:        24.04
Codename:       noble
is Cuda 12.8 is incompatible with the driver I am using?
I’m running into similar issues with Blackwell pros, Did you end up figuring this out?
I didn’t solve it with ubuntu 24.04 yet
I am currently using ubuntu 22.04 with 6.5 kernel and it works well
NVIDIA-SMI 570.133.20             Driver Version: 570.133.20     CUDA Version: 12.8
lsb_release -a
Description:    Ubuntu 22.04.5 LTS
Release:        22.04
Codename:       jammy
I had the same issue on HGX B200 8-GPU, with this driver version (and others).
What solved this for me was to add “quiet splash nokaslr” in the kernel boot parameters
