DRIVE OS Version: 7.0.3
Issue Description: Hello, I can’t build the TensorRT-Edge LLM on my Drive AGX Thor Development Kit which has the officially available DriveOS 7.0.3 installed. This only seems to come with Cuda 12.8 Toolkit. When preparing build configuration on the Thor I get the following logs:
cmake .. -DCMAKE_BUILD_TYPE=Release -DTRT_PACKAGE_DIR=/usr -DCMAKE_TOOLCHAIN_FILE=cmake/aarch64_linux_toolchain.cmake -DEMBEDDED_TARGET=auto-thor
– Configurable variable CUDA_CTK_VERSION set to 13.2
– Using CUDA toolkit dir: /usr/local/cuda/targets/aarch64-linux
– The CXX compiler identification is GNU 13.2.0
– The CUDA compiler identification is NVIDIA 12.8.93
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++ - skipped
– Detecting CXX compile features
– Detecting CXX compile features - done
– Configurable variable CUDA_DIR set to /usr/local/cuda/targets/aarch64-linux
– NVTX profiling DISABLED (use -DENABLE_NVTX_PROFILING=ON to enable)
– FMHA Kernels: Excluding SM architectures: EXCLUDE_SM_80;EXCLUDE_SM_86;EXCLUDE_SM_87;EXCLUDE_SM_89;EXCLUDE_SM_100;EXCLUDE_SM_120;EXCLUDE_SM_121
– Configuring done (0.9s)
– Generating done (0.1s)
And when actually building it will fail with the following logs:
[ 92%] Building CUDA object cpp/CMakeFiles/edgellmCore.dir/kernels/int4GroupwiseGemmKernels/int4WoQGemvCuda.cu.o
nvcc fatal : Unsupported gpu architecture ‘compute_110’
make[2]: *** [cpp/CMakeFiles/edgellmCore.dir/build.make:5859: cpp/CMakeFiles/edgellmCore.dir/kernels/contextAttentionKernels/utilKernels.cu.o] Error 1
make[2]: *** Waiting for unfinished jobs…
[ 92%] Building CUDA object cpp/CMakeFiles/edgellmCore.dir/kernels/int4GroupwiseGemmKernels/int4WoqGemmCuda.cu.o
make[2]: *** [cpp/CMakeFiles/edgellmCore.dir/build.make:5874: cpp/CMakeFiles/edgellmCore.dir/kernels/embeddingKernels/embeddingKernels.cu.o] Error 1
make[2]: *** [cpp/CMakeFiles/edgellmCore.dir/build.make:5889: cpp/CMakeFiles/edgellmCore.dir/kernels/int4GroupwiseGemmKernels/int4WoQGemvCuda.cu.o] Error 1
make[2]: *** [cpp/CMakeFiles/edgellmCore.dir/build.make:5904: cpp/CMakeFiles/edgellmCore.dir/kernels/int4GroupwiseGemmKernels/int4WoqGemmCuda.cu.o] Error 1
[ 92%] Building CUDA object cpp/CMakeFiles/edgellmCore.dir/kernels/kvCacheUtilKernels/kvCacheUtilsKernels.cu.o
make[2]: *** [cpp/CMakeFiles/edgellmCore.dir/build.make:5919: cpp/CMakeFiles/edgellmCore.dir/kernels/kvCacheUtilKernels/kvCacheUtilsKernels.cu.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:199: cpp/CMakeFiles/edgellmKernels.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
make[1]: *** [CMakeFiles/Makefile2:225: cpp/CMakeFiles/edgellmCore.dir/all] Error 2
[ 93%] Linking CXX static library libedgellmTokenizer.a
[ 93%] Built target edgellmTokenizer
make: *** [Makefile:91: all] Error 2
How can I fix this issue and get the TensorRT-Edge LLM running? Thank you very much for your support.
