Software Version
DRIVE OS 7.0.3
other
Target Operating System
Linux
QNX
other
Hardware Platform
DRIVE AGX Thor Developer Kit (940-63960-0010-000)
DRIVE AGX Thor Developer Kit (940-63960-0012-000)
other
Host Machine Version
native Ubuntu Linux 24.04 Host installed with DRIVE OS Docker Containers
other native Ubuntu Linux 22.04 Host installed with DRIVE OS Docker Containers
Issue Description
With DRIVE Orin, I can use TensorRT after flashing, but with Drive Thor, I noticed that TensorRT is not already installed by default after flashing.
Regarding Additional Packages, I assume that both of nv-tensorrt-repo-ubuntu2404-cuda12.8-trt*-d7l-cross-ga-*_amd64.deb and nv-tensorrt-repo-ubuntu2404-cuda12.8-trt*-d7l-target-ga-*_arm64.deb TensorRT packages are necessary according this page. If the use case is engine building and inference directly on Drive Thor, not using the cross-compiler, is it correct that only nv-tensorrt-repo-ubuntu2404-cuda12.8-trt*-d7l-target-ga-*_arm64.deb is needed? If there are any other required packages, please let me know.
Regarding the installation procedure, is my understanding correct that I need to store the package in /drive_flashing and then just follow the “Binding and Flashing the Target Manually” steps again? Or other methods?
Also, where can I find nv-tensorrt-repo-ubuntu2404-cuda12.8-trt*-d7l-target-ga-*_arm64.deb etc on NGC? I searched, but couldn’t find it.
Thank you in advance.
Error String
Logs
Provide logs in text box instead of image.
Please paste the complete application log here. If there are multiple logs, please use multiple text box.
