Due to the infiniband driver compatibility reason, our GPU cluster were installed with 64-bit OpenSUSE 11.0 OS, I wonder if CUDA driver and toolkit 2.3 are available for this version of OS?
Currently, versions 2.1 and 2.2 are available for OpenSuSE 11.0. and version 2.3 is available for only OpenSuSE 11.1. However, in order to use the latest version of OpenCL, we like to have version 2.3 for OpenSuSE 11.0.
I tried version 2.3 on OpenSuSE 11.0, but some errors occurred in compiling SDK example programs.
I didn’t encounter this problem, the SDK programs complied successfully without error. I used gcc 4.3 which is default for OpenSuSE 11.1. Here is the output messages from make command in directory NVIDIA_GPU_Computing_SDK/C/common:
In file included from src/bank_checker.cpp:19:
./…/common/inc/bank_checker.h:38: warning: type qualifiers ignored on function return type
./…/common/inc/bank_checker.h:224: warning: type qualifiers ignored on function return type
src/bank_checker.cpp:61: warning: type qualifiers ignored on function return type
src/bank_checker.cpp:263: warning: type qualifiers ignored on function return type
In file included from ./…/common/inc/stopwatch.h:37,
from src/cutil.cpp:53:
./…/common/inc/stopwatch_base.h:75: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_base.h:79: warning: type qualifiers ignored on function return type
In file included from ./…/common/inc/stopwatch_base.h:91,
from ./../common/inc/stopwatch.h:37,
./…/common/inc/stopwatch_base.inl:67: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_base.inl:78: warning: type qualifiers ignored on function return type
In file included from ./…/common/inc/stopwatch.h:44,
./…/common/inc/stopwatch_linux.h:50: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_linux.h:54: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_linux.h:130: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_linux.h:147: warning: type qualifiers ignored on function return type
In file included from src/cutil.cpp:53:
./…/common/inc/stopwatch.h:54: warning: type qualifiers ignored on function return type
In file included from src/cutil.cpp:54:
from src/stopwatch.cpp:36:
In file included from src/stopwatch.cpp:36:
src/stopwatch.cpp:90: warning: type qualifiers ignored on function return type
In file included from src/stopwatch_linux.cpp:19:
