Hi everyone
I’m trying to set up CUDA to work on Fedora Core 10. My hardware config is:
Intel Core i7 920 CPU
3 GB DDR 3 SDRAM (1333 MHz)
Palit GTX 295 Graphics Card (single)
I have downloaded and installed the nVidia driver, which is working fine. The files I have are listed below:
[codebox][vivek@farpoint cuda]$ ls -l
total 107784
-rw-rw-r-- 1 vivek vivek 22619317 2009-05-16 16:39 cudadriver_2.2_linux_32_185.18.08-beta.run
-rw-rw-r-- 1 vivek vivek 1181310 2009-05-16 16:38 cudagdb_2.2_linux_32_rhel5.3.run
-rw-rw-r-- 1 vivek vivek 924289 2009-05-16 16:41 CUDA_Getting_Started_2.2_Linux.pdf
-rw-rw-r-- 1 vivek vivek 48558 2009-05-16 16:37 cudaprof_1.2_readme.html
-rw-rw-r-- 1 vivek vivek 55951278 2009-05-16 16:42 cudasdk_2.2_linux.run
-rw-rw-r-- 1 vivek vivek 28230318 2009-05-16 16:41 cudatoolkit_2.2_linux_32_fedora10.run
-rw-rw-r-- 1 vivek vivek 12476 2009-05-16 16:37 cudatoolkit_eula.txt
-rw-rw-r-- 1 vivek vivek 9414 2009-05-16 16:37 cudatoolkit_release_notes_linux.txt
-rw-rw-r-- 1 vivek vivek 1239966 2009-05-16 16:37 NVIDIA_CUDA_Programming_Guide_2.2.pdf
[vivek@farpoint cuda]$ [/codebox]
I’ve installed the driver, the sdk and then the toolkit with superuser permissions. I have also set the bath in bash_profile. Now, when I log in as root and try to run make, I get the following error messages:
[codebox][root@farpoint NVIDIA_CUDA_SDK]# make
make[1]: Entering directory `/root/NVIDIA_CUDA_SDK/common’
In file included from src/bank_checker.cpp:34:
./…/common/inc/bank_checker.h:52: warning: type qualifiers ignored on function return type
./…/common/inc/bank_checker.h:238: warning: type qualifiers ignored on function return type
src/bank_checker.cpp:75: warning: type qualifiers ignored on function return type
src/bank_checker.cpp:277: warning: type qualifiers ignored on function return type
In file included from ./…/common/inc/stopwatch.h:37,
from src/cutil.cpp:53:
./…/common/inc/stopwatch_base.h:74: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_base.h:78: warning: type qualifiers ignored on function return type
In file included from ./…/common/inc/stopwatch_base.h:91,
from ./../common/inc/stopwatch.h:37,
./…/common/inc/stopwatch_base.inl:85: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_base.inl:96: warning: type qualifiers ignored on function return type
In file included from ./…/common/inc/stopwatch.h:44,
./…/common/inc/stopwatch_linux.h:64: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_linux.h:68: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_linux.h:144: warning: type qualifiers ignored on function return type
./…/common/inc/stopwatch_linux.h:161: warning: type qualifiers ignored on function return type
In file included from src/cutil.cpp:53:
./…/common/inc/stopwatch.h:53: warning: type qualifiers ignored on function return type
In file included from src/cutil.cpp:54:
from src/stopwatch.cpp:36:
In file included from src/stopwatch.cpp:36:
src/stopwatch.cpp:89: warning: type qualifiers ignored on function return type
In file included from src/stopwatch_linux.cpp:34:
a - obj/release/bank_checker.cpp.o
a - obj/release/cmd_arg_reader.cpp.o
a - obj/release/cutil.cpp.o
a - obj/release/stopwatch.cpp.o
a - obj/release/stopwatch_linux.cpp.o
a - obj/release/multithreading.cpp.o
make[1]: Leaving directory `/root/NVIDIA_CUDA_SDK/common’
make -C projects/bicubicTexture/
make[1]: Entering directory `/root/NVIDIA_CUDA_SDK/projects/bicubicTexture’
bicubicTexture.cpp:106: warning: deprecated conversion from string constant to ‘char*’
bicubicTexture.cpp:136: warning: deprecated conversion from string constant to ‘char*’
bicubicTexture.cpp:703: warning: unused parameter ‘argc’
bicubicTexture.cpp:592: warning: ‘shaderCode’ defined but not used
/usr/bin/ld: cannot find -lglut
collect2: ld returned 1 exit status
make[1]: *** […/…/bin/linux/release/bicubicTexture] Error 1
make[1]: Leaving directory `/root/NVIDIA_CUDA_SDK/projects/bicubicTexture’
make: *** [projects/bicubicTexture/Makefile.ph_build] Error 2
[root@farpoint NVIDIA_CUDA_SDK]# [/codebox]
As I’m new to this, can someone please help me figure out the source of the error and correct it.
